vrm_portal:change_log
VRM Portal changelog
2019-07-02
  • Fixed the colors of the legend in the Inverter Output Voltage and Current widget
2019-07-01
  • Improved some translations on VRM
  • Fixed an issue where the widget selector the advanced page was not large enough and did not show all available widgets
2019-06-27
  • Allow vertical resizing for the advanced page widgets
2019-06-18
  • Fixed a bug on the iPad where the screensaver was not overlapping the full screen
2019-06-17
  • Change margins and padding on the advanced page
  • Advanced page drag & drop is now support on more screen resolutions
  • Added the VE.Bus hardware configuration on the system overview page
2019-06-14
  • Date arrows shift now with a full quick range for Today and This X ranges.
  • Date picker and advanced widgets style improvements.
2019-06-12
  • Production report now works for rangers bigger than 31 days
2019-06-11
  • Only show remote support port when remote support is enabled
2019-06-06
  • Added navigation to the Advanced page and one-day interval selection in the datepicker by clicking on the “Started at” value in the Alarm logs
2019-06-05
  • Added interval shifting arrows to the datepicker
2019-06-04
  • Show remote support port on device list page
  • New advanced page: you can now put widgets next to each other and resize graphs on the advanced page
  • Improved datepicker: It's now easier to select common ranges for the datepicker
2019-06-03
  • Fix header buttons disappearing underneath alarm notifications
2019-05-22
  • Device list on the firmware update screen is now more likely to show the correct device name
2019-05-20
  • Back button behaviour is now more consistent on mobile devices
2019-05-17
  • It is now possible to see the current alarm of an installation from the installation page
  • Only non automatic tags are shown on each installation page, saving some space on small screens
2019-05-16
  • Fixed an issue where the down arrow of the remote console was not accessible on some screen resolutions
  • Fixed an issue where the 'No data found' text was not visible for some charts
  • Auto-reloading of the dashboard chart works again
2019-05-14
  • Updated economic report: the columns and the calculation behind them are now more clear
2019-05-02
  • Added an economic report in the reporting section of VRM: you can compare your Victron system with some predefined scenarios
2019-05-01
  • Better error handling for data uploads
2019-04-30
  • Fix bug where installations were marked as alarm on the map on installation overview
2019-04-25
  • Time since last full charge for Battery History widget now shows as hh:mm instead of days
2019-04-19
  • Fix bug with some states in state widgets that were shown incorrectly
2019-04-15
  • Fix a bug where VRM kept reloading and prompting for a new version
2019-04-12
  • New inverter widgets: State, Output voltage and current
  • Added support for multiple services in Remote VEConfigure
  • Added battery charge voltage to BMS charge and discharge limits widget
  • Added phase rotation to VE Bus warnings and alarms widget (if applicable)
  • Added high DC ripple to VE Bus warnings and alarms widget (if applicable)
  • Improved GPS widgets: added current location, it shows a warning if the data is old, and added a terrain mode switch to the map
  • Added generator state widget
  • Added generator state to dashboard generator block
  • Added battery temperature widget
  • Added battery temperature to VE Bus summary widget
2019-03-29
  • New charger widgets: Output voltage and current, Charger state
2019-03-28
  • States with the same name now show as one serie in the state widgets
2019-03-21
  • Two new widgets on the advanced page: Solar Charger PV Voltage and Current, BMS Charge and Discharge limits
2019-02-15
  • Removed VE.Bus Phase Count from the excel and csv downloads. It doesn't add any value and just takes up space.
  • Removed and Log time offset from the excel and csv downloads. It causes many white lines.
2019-01-29
  • Added Octo GX to add installation screen
  • Device list now shows the proper icon for each type of gateway
  • Fixed sorting on the installation overview page
  • Added battery current to the battery block on the dashboard
2019-01-26
  • Redesigned installation overview on mobile
  • Increase System SOC retention time from 6 months to four years.
2019-01-21
  • Fix charts not loading on the dashboard in IE
  • Fixed a bug that made charts reload on the advanced page while they were zoomed in
  • Summary widgets now use the same colors for voltage and current as the graphs on the advanced page
2018-12-12
  • Added the Economic report for comparing cost scenarios.
2018-12-10
  • Added navigation to the installation overview when searching for an installation in the menu search bar.
2018-11-22
  • Added Russian as a language (and improved other translations)
  • Added device id to VE.Bus data on the device list page
  • You can now add VRM to your home screen on your Android phone (PWA)
2018-10-26
  • Show more data points on advanced charts when zooming in
  • Renamed username to e-mail
  • Allow firmware updates for devices without any firmware installed
2018-10-19
  • Fixed blocked field in the add installation flow on small screens
2018-10-17
  • Reset zoom on changing the range of the dashboard and advanced graphs
2018-10-16
  • Added mobile scroll indication for the firmware update devices table
2018-09-28
  • Redesigned the Device list page
2018-09-27
  • Added tags list to the Dashboard, Advanced and Device list pages
2018-09-11
  • Added a button to manually remove a device from the device list
2018-09-06
  • Added more data points per pixel on advanced graphs, makes it easier to spot peaks / anomalies
  • Fixed an issue where in some cases state widgets where not updating properly
  • Improved UX on installation tag page, with autocomplete as well
2018-09-05
  • Added tank level widget
  • Added first seen date to device list page
2018-09-04
  • Added search box to location set screen
2018-08-29
  • Removed the control toggle in the Pending invitations table for monitoring users.
2018-08-24
  • Fixed issue for VE.Direct LoRaWAN modules: Battery State “charging” was reported as “discharging”.
  • Fixed issue for VE.Direct LoRaWAN modules: Battery Time-To-Go was reported in minutes instead of hours.
2018-08-14
  • Changed and adjusted graphs visual aspects: labels, transitions, z-indexes, etc.
  • Synchronised and aligned the graphs from the Advanced page.
  • Added a vertical synchronised bar on mouse/touch hover for the time graphs from the Advanced page.
2018-08-03
  • System overview state of charge line and area moved on top of the columns for better visibility.
2018-07-27
  • Improved timezone syncing from the CCGX to VRM
2018-07-16
  • Added 'Reconnect' button to the Remote Console disconnected screen.
2018-05-23
  • Increased stats API endpoint limits for intervals 15mins and hours. This used to be a maximum date range of 2 days, now it is increased to a maximum of 31 days.
  • Updated API docs to explain how to use access tokens
2018-05-22
  • Textual changes and confirmation modals added for the General Settings.
2018-05-16
  • Delete account with email input precaution.
  • Alarm logs now show in the timezone of the installation
2018-04-19
  • Added a new column in the admin diagnostics pages: Data attribute code and replaced the Data attribute id column with the Data attribute code in the installation diagnostics page.
2018-02-27
  • New widget added: Graph - System - PV Yield
2018-02-13
  • Added battery/bms parameters 'High charge current alarm', 'High discharge current alarm', 'Cell Imbalance alarm', 'Internal error alarm' to the list of parameters being watched over by the Automatic alarm monitor. This fixes alarms like this not being shown in the Alarm log on VRM. Note that these alarms only show for devices that support these types of alarms. In this case that will be (some) lithium batteries such as BYD.
2017-12-18
  • New widget added: Graph - Solar Charger Loadoutput Current
  • Displaying time to go only when necessary and accurate
  • Fixed a few Spanish and Portuguese translation terms
2017-11-13
  • New widget added: System Overview - DC System
2017-10-19
  • Timezone update using the gateway's timezone or user setting if it is not updated on the device
  • Added combined summary and graph widget type and an example for the Temperature Sensor
2017-10-04
  • Adjusted GPS widget offering logic to show it only when are valid coordinates
2017-10-03
  • Added icons for Charger and Temperature Sensor in device list
  • Show extended gateway information for all Venus OS devices
2017-09-15
  • Added icons for Grid Meter in device list
  • Adjusted the API docs (added system overview command documentation)
2017-09-12
  • Added instance id to the alarm wizard, so you can see the difference between devices better
2017-09-07
  • Show stats of uploaded CCGX databases, so you know what happened
  • Only show total of PV Inverter Status if there are multiple phases
  • Only offer battery history widget if there is a BMV or Lynx shunt available
  • Optimized some InfluxDB queries
2017-08-03
  • Added LoRaWAN module to add installation screen
2017-08-02
  • Added more values to device list for PV inverter and VE.Bus
  • Improved share a site model, works better on your phone now
2017-07-25
  • Instead of showing N/A on dashboard when a value is not available, we now fallback to other values if possible
  • Made some adjustments to the legend of live feed graph, to correctly reflect what is plotted
  • Hide the graph selector on the dashboard when only one graph is available
2017-07-20
  • Altered the user overview of in installation so it works properly on your mobile phone
  • Made adjustments to installation overview, it now better reflects new gateway types and only shows data when it's there
  • State widgets, hours of AC calculation and GPS tracks download are now also loaded from Influx, reducing load times
  • Added a summary widget for Tanks on the advanced page
2017-07-12
  • Changing the installation name is now reflected properly in the menu
2017-06-28
  • Improved readability of VRM API docs
2017-06-27
  • Fixed a possible issue while saving notes
2017-06-19
  • Switched backend for graphs to Influx, greatly increasing load speed on advanced page
2017-06-13
  • Fixed an issue where some share URLs did not work properly
2017-06-07
  • Fixed an issue with the XLS export and more recent versions Office
2017-05-31
  • Admins now must approve a new user when he/she adds an installation (first user of an installation can still add the installation directly)
2017-05-16
  • You can now press and hold buttons on the remote console
2017-04-21
  • Improved datepicker on advanced page
2017-04-13
  • Enabled Venus GX on add installation page
2017-04-06
  • To increase security, installation administrators now must approve new users that added that installation.
2017-03-31
  • Added Remote on LAN IP to device list
2017-03-29
  • Made error messages of alarm add wizard more clear
2017-03-28
  • Dashboard now shows every hour on the x-axis of the graphs
2017-02-27
  • Added a kWh download option on the advanced screen
2017-02-15
  • Improved the speed of XLSX data downloads
  • Removed the total from the live feed graph, it did not make sense there (it is still there on the consumption and solar graphs)
2017-02-01
  • Improved the add installation screen: it is now easier to add an installation for different device types
  • Make graph tooltips transparent so the underlying graph stays visible
2017-01-25
  • Better error handling when the backend is unavailable
2017-01-24
  • Added current month to year overview on dashboard
2017-01-23
  • Fixed an issue where tooltips of the advanced tab graphs did not respect the installation timezone
  • Improvements to registration flow: autologin after e-mail has been verified
  • Improvements to reset password flow: autologin after password has been reset and prefill form with e-mailadress
2017-01-19
  • Zoom state on advanced tab is now reset when a date range is selected that lies outside the zoom state range
  • Clicking on an installation name in the menu now directly leads to the installation dashboard, saves you a click when switching installations
2017-01-18
  • Fixed an issue where the tags API endpoint could return an empty document
2017-01-13
  • Added an option to disable the alarm rate limiter if it is active for your installation
2017-01-12
  • Added an option to replace a broken CCGX with a new one. While keeping the old history.
2017-01-11
  • Fixed an issue on Samsung Mobile devices that could cause the menu to disappear
2017-01-10
  • Fixed an issue that caused some installations to disappear from Victron World
  • Fixed an issue where the current date was unselectable on the advanced tab
  • Improved the scaling of battery voltage graphs
  • Fix photo size on user uploaded photos
  • Added totals to the tooltips of the graphs on the dashboard page
  • Only show 'no data found' if we are not loading
  • Allow up to 64MB downloads for CCGX data files. Since these can also be zipped, 64MB is really lots of data (more than a year in most cases)
2017-01-09
  • Fix some validation errors while creating an alarm through the wizard
2017-01-06
  • Added an option to subscribe to the VRM newsletter on the landingpage
2017-01-04
  • Fixed an issue where wrong translations could lead to KEY_NOT_FOUND errors
  • Increased the speed of the advanced tab by smarter loading of the graphs
2017-01-03
  • Use last timestamp as Last connection info on top of advanced tab
  • Fix bug in alarm hysteresis validation
2017-12-23
  • Fixed the Victron World link on the frontpage
2016-12-22
  • Added genset data to AC source column on installation overview
  • Added multi phase support VE.BUS Warnings and alarms widget
  • Added last hour option to advanced tab date dropdown (with auto data reload every minute)
  • Fixed an issue that resulted in an error (Failed to process file) while uploading a CCGX file
2016-12-20
  • Added ability to upload CCGX files in ZIP and GZIP format
2016 Nov. - New VRM API
2016-09-09
  • Added “Solar Charger Voltage and Current” graph to the advanced tab.
2016-06-07
  • Added row indicating unit to the CSV- and Excel data downloads.
2016-06-06
  • Updated Spanish translations.
  • Added “VE.Bus” prefix to “State” and “DC Voltage and Current” advanced tab items.
2016-06-03
  • Renamed two items on the advanced tab:
    • “Warnings and Alarms” to “VE.Bus Warnings and Alarms”
    • “Historic data” to “Battery history”
  • Added production history data to the battery history block.
2016-05-11
  • The AC Input and Output Frequency graphs now show horizontal grid lines every 10 Hz, for easy reference to the most common standard frequencies.
2016-04-12
  • The Upload CCGX file now accepts data files with data older then 6 months.
2016-03-31
  • Fixed an issue where on the last day (31) of the month, on the Solar Yield an Consumption tab, clicking the last month button would not display the data of the last month.
2016-03-11
  • Remedied an issue where some graphs showed gaps in the data where no actual gaps in logging occured.
2016-03-07
  • Site admins now have to possibility to permanently remove a site plus all its data.
2016-02-01
  • The time range selected in the advanced tab is now persistent, so your preferred time range will stay selected across page reloads and even between different sites.
2016-01-15
  • There is a new link on the top menu, Upload CCGX file. Use it to upload .sqlite files which are stored by the CCGX on a SDcard or USB stick. This fixes the issue where, even when configured to log to SDcard or USB-stick, it was necessary to first, only once, connect the CCGX to the internet. With the new change, you'll be able to add the site to your account a few minutes after uploading your data file. More information in the CCGX manual, chapter 2.2.2.
2015-12-08
  • Alarms settings now allow for decimal and negative values.
2015-12-04
  • Implemented a new login feature for use with the VRM app.
2015-12-02
  • A lot of changes were implemented over the past few months to support the new Remote Console functionality, released with CCGX v1.30.
2015-11-30
  • Increased the number of data points we load for all graphs, eliminating averaging of values in the graphs when viewing 24 hours of data.
2015-11-17
  • Updated the Danish translations.
2015-10-30
  • Significant performance improvement to data export; initial testing shows downloading a CSV file now takes up to ten times less time.
  • Fixed issues with the total line summing in graphs with overlapping gaps.
2015-10-26
  • Also added the cumulative total line to the PV Inverter Yield graph.
  • Added a correction for the correct display of times in a graph which contain a change of time zone (due to DST).
2015-10-23
  • Added a cumulative total line to graphs which contain summable data, which can be toggled using the label in the header of the graph.
  • Changed the layout of the PV Inverter widget to improve readability.
  • Fixed an issue with the VE.Bus State graph displaying non-existing data points when a gap in the data logging was detected.
  • Show absolute times instead of relative times when the last update is more than six hours ago.
2015-10-20
  • Optimization in retrieval of yearly data for the solar yield and consumption graphs, reduced loading time from about 25 seconds to near zero.
2015-10-19
  • Added initial support for the upcoming “Remote Console” functionality for CCGX-owners.
2015-10-12
  • When available, connection identifiers (or instance numbers) are shown on the alarm log
2015-09-22
  • Combined SOC and the TTG on the Battery status widget on the advanced tab: it fits in one widget so no longer scrolls
  • Entering Company name is no longer required for new users during registration
  • Remember filled out email on opening forgot password form
2015-09-11
  • Fixed zooming out on any graph, not just the graph that the zoom was performed on.
  • Only zoom on the X-axis, making sure data is always in view on other graphs.
  • Only show one phase for frequency since they're all the same.
  • Fixed “today” button misbehaving when the page was open overnight.
2015-09-08
  • Instead of having data for each phase on a separate tab, have it all together in one tab. Click the phase on the top to show/hide each phase. Adding a cumulative total as a stacked graph is also on the todo list.
2015-09-03
  • Automatically determine the best number of x-axis ticks for the graphs. This fixes the weird looking times on the bottom of the graphs.
vrm_portal/change_log.1562094616.txt.gz · Last modified: 2019-07-02 21:10 (external edit)
