vrm_portal:change_log
Last revision Both sides next revision
vrm_portal:change_log [2020-07-09 11:36]
thlassche
vrm_portal:change_log [2020-10-02 16:00]
thlassche
 ====== VRM Portal changelog ====== ====== VRM Portal changelog ======
 +=== 2020-10-02===
 +  * Add GlobalLink 520 support to VRM
 +=== 2020-10-01===
 +  * Add an option to quickly remove a widget from the advanced page
 +  * Add an option to show range values in advanced graphs (helps find peaks when looking at long ranges of data)
 +=== 2020-09-29===
 +  * Fix Fahrenheit conversions for summary widgets
 +  * Fix dashboard view for Internet Explorer 11
 +=== 2020-09-28===
 +  * Add option to change relay state for GlobalLink devices
 +=== 2020-09-25===
 +  * Show the grid graph on the dashboard as horizontal graph is there is no grid feed in
 +=== 2020-09-22===
 +  * Launch realtime dashboard for more types of installations
 +=== 2020-09-21===
 +  * New realtime installation dashboard for supported installations
 +=== 2020-09-02===
 +  * Add internal temperature widget
 +=== 2020-08-21===
 +  * Add pulse meter support
 +=== 2020-08-17===
 +  * Fix a bug in widget grouping for some installations
 +=== 2020-07-29===
 +  * Improve tooltip synchronisation for the Advanced page charts
 +=== 2020-07-28===
 +  * Make installation overview more readable for a lot of installations
 +  * Align labels of the state widgets with the graph charts for easier analysis
 +  * Improve login screen autocompletion and usability
 +=== 2020-07-27===
 +  * Add (optional) tank level column to system overview
 +  * Improve site share links experience
 +=== 2020-07-14===
 +  * Add an option to create periodic email reports for all report types
 +  * Fixed an issue where some summary widgets displayed no data while there was data present
 +=== 2020-07-13===
 +  * Show 'no data' when summary widgets don't have any data for the given installation
 +  * Add charger AC power and current widgets
 +  * Add digital inputs to the device list
 +  * Add digital input state widget
 +=== 2020-07-09===
 +  * Fix bug with enums displaying numerically on the dashboard in some cases
 === 2020-07-07=== === 2020-07-07===
   * Add Fahrenheit support for VRM in the profile settings   * Add Fahrenheit support for VRM in the profile settings
vrm_portal/change_log.txt · Last modified: 2020-10-12 09:00 by thlassche
