vrm_portal:change_log
Next revision Both sides next revision
vrm_portal:change_log [2019-11-06 11:41]
thlassche
vrm_portal:change_log [2019-11-11 11:44]
thlassche
 ====== VRM Portal changelog ====== ====== VRM Portal changelog ======
 +=== 2019-11-11===
 +  * Fix axis configuration on the dashboard when there are only minor changes in the data of the graphs
 === 2019-11-06=== === 2019-11-06===
   * Added a battery temperature graph widget for solar chargers   * Added a battery temperature graph widget for solar chargers
vrm_portal/change_log.txt · Last modified: 2020-09-25 10:46 by thlassche
