vrm_portal:change_log
Next revision Both sides next revision
vrm_portal:change_log [2019-10-30 12:46]
thlassche
vrm_portal:change_log [2019-11-14 15:03]
thlassche
 ====== VRM Portal changelog ====== ====== VRM Portal changelog ======
 +=== 2019-11-14===
 +  * Change the battery voltage graph line color on the dashboard, so it's easier to distinguish SOC and battery voltage
 +=== 2019-11-11===
 +  * Fix axis configuration on the dashboard when there are only minor changes in the data of the graphs
 +=== 2019-11-06===
 +  * Added a battery temperature graph widget for solar chargers
 +  * Added battery temperature to the solar charger summary widget
 === 2019-10-30=== === 2019-10-30===
   * Add EasySolar II GX and MultiPlus II GX to the add installation screen   * Add EasySolar II GX and MultiPlus II GX to the add installation screen
vrm_portal/change_log.txt · Last modified: 2020-03-18 17:05 by thlassche
