vrm_portal:change_log
vrm_portal:change_log [2024-03-28 11:33] – aleximb | vrm_portal:change_log [2024-03-28 11:54] (current) – aleximb | ||
* Update mechanism: Fix edge cases of the update mechanism: do not refresh when the VNC Remote console is open. | * Update mechanism: Fix edge cases of the update mechanism: do not refresh when the VNC Remote console is open. | ||
* Translations: | * Translations: | ||
=== 2024-03-27 === | === 2024-03-27 === | ||
* Android and iOS: there is now a new status widget with chart ranges and the old version as an alternative | * Android and iOS: there is now a new status widget with chart ranges and the old version as an alternative |
vrm_portal/change_log.txt · Last modified: 2024-03-28 11:54 by aleximb
