vrm_portal:alarms
vrm_portal:alarms [2019-01-25 13:55] – [3. User configurable alarms] guy_stewartvrm_portal:alarms [2023-09-01 18:00] (current) mvader
Line 37: Line 37:
   * Low battery alarm   * Low battery alarm
   * Overload alarm   * Overload alarm
 +  * AC Input phase rotation (for three phase systems)
 === 2.1.2 BMV, Lynx Shunt VE.Can and other batteries=== === 2.1.2 BMV, Lynx Shunt VE.Can and other batteries===
Line 54: Line 55:
   * High charge current alarm   * High charge current alarm
   * High discharge current alarm   * High discharge current alarm
-  * Cell Imbalance alarm +  * Cell imbalance alarm
-  * Internal error alarm+  * Internal failure alarm
 === 2.1.3 Solar charger === === 2.1.3 Solar charger ===
Line 83: Line 84:
   * Digital input   * Digital input
 +=== 2.1.7 Generator start/stop ===
 +  * Generator not detected at AC-input. See [[ccgx:generator_start_stop|]] for details
 ===== 3. User configurable alarms ===== ===== 3. User configurable alarms =====
Line 133: Line 138:
-===== DISQUS ===== +===== 6. VRM Error messages =====
-~~DISQUS~~+
 +==== Data from unauthenticated device has been received ====
 +When transmitting data to the VRM Portal, the device sending the data needs to authenticate itself against VRM. It does this using VRM Authentication tokens.
 +If either one of those tokens does not match the ones stored in the VRM back-end, then the transmitted data is rejected by VRM, and an error message is shown on the VRM portal. The error message looks like this:
 +{{ :vrm_portal:unauthenticated.png?nolink&600 |}}
 +These are the causes:
 +  - GX device has been reset to factory defaults, using the venus-data.tgz file as instructed in the manuals. For older GX devices, CCGX, Venus GX, Octo GX, and also older batches of Cerbo GX as well as older batches of MP-II GX and ES-II GX, this will lead to this error message on VRM.
 +  - Hacker trying to send false data to VRM.
 +  - GX device storage corruption (data partition).
 +  - RaspberryPi that has a new sdcard or is re-imaged.
 +For "1. GX device factory reset" as well as for "4. RaspberryPi", the solution is to reset the tokens, using the Reset Tokens button in General -> Settings.
 +It is thereafter not needed to restart the GX device.
 +If that does not resolve it, contact your Victron dealer.
vrm_portal/alarms.1548420907.txt.gz · Last modified: 2019-01-25 13:55 by guy_stewart
