victronconnect:ve-smart-networking
VE.Smart Networking
1. Introduction
A VE.Smart Network is a wireless network which allows a number of Victron products to exchange information. It is a wireless technology using Bluetooth Smart.
Use VE.Smart to add remote voltage- and temperature- sensing to your Victron MPPT Solar Chargers. Connect either a BMV battery monitor - or the new Smart Battery Sense, to a Solar Charger. The Solar Charger will receive battery voltage & temperature information, and use that data to optimize its charge parameters. This will improve charging-efficiency and prolong battery life.
2. Voltage and temperature sense - further details
The battery voltage data is used to compensate for voltage-drop over the battery cables. This ensures that the battery is charged with the exact voltage as configured in the charger - instead of a lower voltage due to resistance in the wiring.
The battery temperature data is used to adjust the charge voltages. When cold, a lead/acid battery typically needs a higher charge-voltage …and a lower charge-voltage when it's hot.
For lithium batteries the charge-voltages remain the same at all temperatures, as long as it’s not too cold. Its better to not charge Ltihium batteries below 5C, to prevent them from being damaged and degraded.
3. Specifications
3.1 VE.Smart Networking compatible products
Product range Compatible Requires VE.Direct Bluetooth Smart dongle Function
BMV-700 Yes Yes Voltage-sense
BMV-702 Yes Yes Voltage-sense, and (optionally) temperature (1)
BMV-712 Yes No, has built in bluetooth Voltage-sense, and (optionally) temperature (1)
SmartSolar MPPTs Yes (2) No, has built in bluetooth Uses received sense data to optimize charging
BlueSolar MPPTs Yes Yes Uses received sense data to optimize charging
  1. To measure battery temperature, the BMV series temperature sensor is required.
  2. Check the table below to see which models are incompatible with this feature.
All new SmartSolar MPPT's support VE.Smart Networking. However some older versions of our hardware do not support VE.Smart Networking. A list of the older incompatible products and part-numbers - together with the newer compatible part numbers for those previously incompatible products is as follows :
Product Old Incompatible Part-number New Compatible Part-number
VE.Direct Bluetooth Smart dongle ASS030536010 ASS030536011
SmartSolar MPPT 150/85 Tr SCC010085210 SCC115085211
SmartSolar MPPT 150/85 MC4 SCC010085310 SCC115085311
SmartSolar MPPT 150/100 Tr SCC010100210 SCC115110211
SmartSolar MPPT 150/100 MC4 SCC010100310 SCC115110311
SmartSolar MPPT 250/85 SCC125085210 (before s/n HQ1811)
SCC125085310 (before s/n HQ1811)
SCC125085210 (after s/n HQ1811)
SCC125085310 (after s/n HQ1811)
SmartSolar MPPT 250/100 SCC125110210 (before s/n HQ1811)
SCC125110310 (before s/n HQ1811)
SCC125110210 (after s/n HQ1811)
SCC125110310 (after s/n HQ1811)
3.2 Limitations
  • The maximum number of devices which can be connected on one network is 25.
  • VE.Smart Networking is designed for small systems which do not have a Venus-device - such as a Color Control GX or Venus GX. In systems which have a Venus-device, do not use VE.Smart Networking - See FAQ 6.
  • The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to VictronConnect.
4. Step by step instructions
We recommend you configure the Smart Battery Sense, or BMV first …and then add one or more solar chargers to that network. You can read the Smart Battery Sense manual here.
4.1 Setup the Smart Battery Sense or BMV
Open VictronConnect, connect the device, and then navigate to Settings and select VE.Smart Networking.
Click Create Network, enter a name. Click Save and wait for the 'OK' to show up.
4.2 Join the Solar Chargers to the network
Go back and navigate to the Solar charger, then click Settings followed by VE.Smart Networking followed by Join Existing. Now select the network which you created at the previous step.
Wait for the 'OK' to show.
4.3 Verify operation
When everything is working OK, you will be able to see that the VE.Smart Networking page of the Solar Charger is receiving data:
Also the network icon will be shown on the main page:
Clicking on that icon will show the network status.
5. FAQ
Q1: Will you be adding wireless parallel charging as a feature?
Yes we will - though we do not have a date for its introduction yet.
Q2: Can several MPPTs be paired to one Smart Battery Sense or BMV?
Yes.
Q3: Is VE.Smart Networking disrupted if I connect a smartphone to it at the same time?
Not at all. It is possible to connect with a smart phone, computer or tablet, at the same time.
Q4: Will you add the same functionality to the BlueSmart Charger product range?
Yes we will - though the exact functionality, and the models to be included has yet to be determined.
Q5: Can Smart Battery Sense be used as a standalone product?
Yes. In this instance it will simply act as a voltage- and temperature-measuring device. Note that the functionality is limited in that it does not (yet) show the graphs or other data which would normally be generated from these measurements.
Q6: Can I use Smart Battery Sense in systems already controlled by a CCGX/Venus GX?
No. The CCGX/Venus GX already has voltage sensing (soon they will have temperature sensing too). Adding Smart Battery Sense to the installation will confuse the voltage-sensing data. For further information please see: CCGX/Distributed Voltage and Current Control.
victronconnect/ve-smart-networking.1548044302.txt.gz · Last modified: 2019-01-21 05:18 by guy_stewart
