victronconnect:ve-smart-networking [2020-01-03 02:47] – [3.1 VE.Smart Networking products compatibility] guy_stewart | victronconnect:ve-smart-networking [2020-02-04 10:43] – [3.2 Limitations] tabreu | ||
Line 57: | Line 57: | ||
==== 3.2 Limitations ==== | ==== 3.2 Limitations ==== | ||
- | * The maximum number of devices which can be connected on one network is 25. | + | * The maximum number of devices which can be connected on one network is 10. |
* VE.Smart Networking is designed for small systems which do not have a [[venus-os: | * VE.Smart Networking is designed for small systems which do not have a [[venus-os: | ||
* The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to // | * The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to // | ||
- | * VE.Smart Networking is not allowed to be created with the charger that already has a CAN network that is also being used to synchronise the charger algorithm with other chargers or if an ESS or an intelligent battery is used on the CAN network. | + | * VE.Smart Networking is not allowed to be created with the charger that already has a CAN network that is also being used to synchronise the charger algorithm with other chargers or if an ESS or an intelligent battery is used on the CAN network |
===== 4. Step by step instructions ===== | ===== 4. Step by step instructions ===== | ||
