victronconnect:ve-smart-networking [2019-12-16 08:41] – tabreu | victronconnect:ve-smart-networking [2020-06-10 02:05] – [4. VE.Smart Product Compatibility] guy_stewart | ||
- | A VE.Smart Network is a wireless network | + | A VE.Smart Network is a wireless |
- | Use VE.Smart to add remote voltage, temperature and/or current sensing to your Victron MPPT Solar Chargers. Connect either a BMV battery monitor | + | Features: |
+ | * Remote Voltage reading | ||
+ | * Temperature sensing | ||
+ | * Current sensing | ||
+ | * Synchronised charging | ||
+ | === Remote voltage-, temperature and/or current sensing === | ||
+ | Use VE.Smart to add remote voltage, temperature and/or current sensing to your Victron MPPT Solar Chargers. Connect either a BMV battery monitor, a SmartShunt, | ||
+ | This video introduces the Smart Battery Sense: \\ | ||
{{youtube> | {{youtube> | ||
- | Use also now the VE.Smart Networking to synchronise the charger algorithms from Solar Chargers and improve even further the charge-efficiency and battery life. This feature is only available on SmartSolars with firmware version equal or higher then v1.47 (Ve.Direct SmartSolars) and v1.04 (Ve.Can SmartSolars). | + | === Synchronised charging === |
+ | Pairing two or more SmartSolar chargers in a VE.Smart Network, enables synchronised charging. This improves the charge efficiency and battery life. | ||
===== 2. Voltage, temperature and current sense - further details ===== | ===== 2. Voltage, temperature and current sense - further details ===== | ||
Line 19: | Line 29: | ||
For lithium batteries the charge-voltages remain the same at all temperatures, | For lithium batteries the charge-voltages remain the same at all temperatures, | ||
- | The battery current is used to allow the tail current setting (see the [[victronconnect: | + | The battery current |
- | ===== 3. Specifications | + | ===== 3. Synchronised charging - further details |
- | ==== 3.1 VE.Smart | + | Connect multiple SmartSolar charge controllers together in a VE.Smart network to make them charge the battery as if they were one large charger. The chargers will synchronise the charge algorithm between themselves, with no further hardware required. They will simultaneously switch from one charge state to another, for example from bulk to absorption. |
+ | Each unit will (and should) regulate its own output current. Which, among others, depends on the output of each PV array, cable resistance and the configured maximum output current of the charger. As such, it is not possible to configure a ' | ||
+ | === Synchronised charging is not always necessary | ||
+ | There are certain system types in which synchronised charging is not necessary: | ||
+ | - ESS Systems with managed batteries: the inverter/ | ||
+ | - ESS Systems with unmanaged batteries: the inverter/ | ||
+ | - Other systems with managed batteries: the battery is already controlling the solar charger. | ||
+ | In all above situations, the solar charger is already being controlled. Managed batteries are CAN-bus connected lithium batteries, as well as other chemistries, | ||
+ | For chargers that are already connected and synchronised over VE.Can, pairing them in a VE.Smart | ||
+ | === How synchronising works on solar chargers === | ||
+ | Synchronising the chargers works in a master-slave manner. The chargers will elect a master among them and that master will be the one to dictate the charge algorithm. As the master cannot be determined by the user, it is important to make sure all chargers belonging to the same network have the **same battery settings**. To know more about the battery settings and some other information, | ||
+ | After being elected, the master will make sure all chargers are on the same charge state and with the same voltage setpoint. As mentioned before, battery charge current is not controlled by the master, but by each of the chargers individually. | ||
+ | At the beginning of the day, the master will measure the battery voltage before any of the other chargers in the network start charging (to find battery idle voltage). This information is used to decide what should be the total absorption time for some types of batteries. The battery idle voltage is shared with the other chargers, as well as the total absorption time, and the elapsed time on the current charge state. That information is important so the charge algorithm can be resumed by the chargers if, for any reason, the master stops charging (i.e. sun went down on its panels, charger was shut down, charger loses contact with the network, etc). | ||
+ | In the absence of battery current sensor, such as the BMV, the chargers on the network will have their output current combined to estimate a better battery charge current. | ||
+ | ===== 4. VE.Smart Product Compatibility ===== | ||
^Product range ^ Compatible ^ Function ^ | ^Product range ^ Compatible ^ Function ^ | ||
- | |BMV-700 | + | |BMV-700 |
- | |BMV-702 | + | |BMV-702 |
|BMV-712 | |BMV-712 | ||
|SmartSolar MPPTs | Yes <sup> (2)</ | |SmartSolar MPPTs | Yes <sup> (2)</ | ||
- | |BlueSolar MPPTs | Yes | Uses received sense data to optimize charging | | + | |BlueSolar MPPTs | Yes (requires [[https:// |
|Phoenix Smart IP43 Charger | |Phoenix Smart IP43 Charger | ||
|Orion-Tr Smart DC-DC Charger Isolated | |Orion-Tr Smart DC-DC Charger Isolated | ||
|Blue Smart Chargers IP22, IP65 and IP67 | No | Not yet supported, may be compatible in the future | | |Blue Smart Chargers IP22, IP65 and IP67 | No | Not yet supported, may be compatible in the future | | ||
+ | |VE.Bus Smart Dongle | ||
- To measure battery temperature, | - To measure battery temperature, | ||
- | - Check the table below to see which models are incompatible with this feature. | + | - Early production batches of some models are not VE.Smart capable. |
- | - Synchronised charging is available on the SmartSolar on version v1.47 or higher except for the models listed on the table below | + | - Synchronised charging is available on the SmartSolar on version v1.47 or higher except for the models listed on the table below. |
+ | - Synchronised charging on VE.Smart is only available on SmartSolar Chargers. It is not possible to enable synchronised charging when using a VE.Direct Bluetooth Smart dongle. | ||
+ | ===== 5. Limitations ===== | ||
- | === First production batches of SmartSolar MPPTs do not support VE.Smart Networking === | + | * The maximum number of devices which can be connected on one network is 10. |
+ | * VE.Smart Networking is designed for small systems which do not have a [[venus-os: | ||
+ | * The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to // | ||
+ | * It is not possible to measure multiple battery temperatures/ | ||
+ | ==== SmartSolar MPPTs that do not support VE.Smart Networking | ||
All currently shipping SmartSolar MPPTs support VE.Smart Networking. However some older versions of those models do **not** support VE.Smart Networking. Those devices will also not become compatible later with a firmware update: the incompatibility is due to a hardware limitation in those devices. There is a work around: connect a [[https:// | All currently shipping SmartSolar MPPTs support VE.Smart Networking. However some older versions of those models do **not** support VE.Smart Networking. Those devices will also not become compatible later with a firmware update: the incompatibility is due to a hardware limitation in those devices. There is a work around: connect a [[https:// | ||
^Product | ^Product | ||
|VE.Direct Bluetooth Smart dongle | |VE.Direct Bluetooth Smart dongle | ||
Line 53: | Line 97: | ||
+ | ===== 6. Step by step instructions ===== | ||
+ | We recommend you configure the Smart Battery Sense, or BMV first ...and //then// add one or more solar chargers to that network. You can read the Smart Battery Sense manual [[https:// | ||
- | ==== 3.2 Limitations ==== | + | ==== 6.1 Setup the Smart Battery Sense or BMV ==== |
- | * The maximum number of devices which can be connected on one network is 25. | + | |
- | * VE.Smart Networking is designed for small systems which do not have a [[venus-os: | + | |
- | * VE.Smart Networking is not allowed to be created with the charger that already has a CAN network that is also being used to synchronise the charger algorithm with other chargers or if an ESS or an intelligent battery is used on the CAN network. | + | |
- | ===== 4. Step by step instructions ===== | + | |
- | We recommend you configure the Smart Battery Sense, or BMV first ...and //then// add one or more solar chargers to that network. You can read the Smart Battery Sense manual [[https:// | + | |
- | ==== 4.1 Setup the Smart Battery Sense or BMV ==== | + | |
Open [[victronconnect: | Open [[victronconnect: | ||
Line 72: | Line 110: | ||
- | ==== 4.2 Join the Solar Chargers to the network ==== | + | ==== 6.2 Join the Solar Chargers to the network ==== |
Go back and navigate to the //Solar charger//, then click // | Go back and navigate to the //Solar charger//, then click // | ||
Line 79: | Line 117: | ||
- | ==== 4.3 Verify operation ==== | + | |
+ | ==== 6.3 Verify operation ==== | ||
When everything is working OK, you will be able to see that the VE.Smart Networking page of the Solar Charger is receiving data: | When everything is working OK, you will be able to see that the VE.Smart Networking page of the Solar Charger is receiving data: | ||
Line 90: | Line 129: | ||
Clicking on that icon will show the network status. | Clicking on that icon will show the network status. | ||
+ | The current LED State will also blink every 4 seconds when a VE.Smart Network is configured and the charger is receiving data. | ||
+ | ===== 7. FAQ ===== | ||
=== Q1: Can several MPPTs be paired to one Smart Battery Sense or BMV? === | === Q1: Can several MPPTs be paired to one Smart Battery Sense or BMV? === | ||
- | Yes. If SmartSolars are connected to the same network, they will also synchronize their charger algorithms. | + | Yes. And, when SmartSolars are connected to the same network, they will also synchronize their charge state. |
=== Q2: Is VE.Smart Networking disrupted if I connect a smartphone to it at the same time? === | === Q2: Is VE.Smart Networking disrupted if I connect a smartphone to it at the same time? === | ||
Line 110: | Line 152: | ||
=== Q5: Can I use Smart Battery Sense in systems already controlled by a GX device (eg CCGX/ | === Q5: Can I use Smart Battery Sense in systems already controlled by a GX device (eg CCGX/ | ||
- | No. The GX device already has voltage sensing (soon they will have temperature sensing too). Adding | + | Yes, but keep in mind that if, voltage or temperature information is also present on the GX Device, the charger will use that information in favor of the information coming from the Smart Battery Sense. The GX device already has, in most cases, |
~~DISQUS~~ | ~~DISQUS~~ |
