Both sides previous revisionPrevious revision | Next revisionBoth sides next revision |
victronconnect:ve-smart-networking [2019-10-01 12:33] – guy_stewart | victronconnect:ve-smart-networking [2019-10-01 12:44] – [3.1 VE.Smart Networking compatible products] mvader |
==== 3.1 VE.Smart Networking compatible products ==== | ==== 3.1 VE.Smart Networking compatible products ==== |
^Product range ^ Compatible ^ [[https://www.victronenergy.com/accessories/ve-direct-bluetooth-smart-dongle|Requires VE.Direct Bluetooth Smart dongle]] ^ Function ^ | ^Product range ^ Compatible ^ Function ^ |
|BMV-700 | Yes | Yes | Voltage-sense | | |BMV-700 | Yes (requires [[https://www.victronenergy.com/accessories/ve-direct-bluetooth-smart-dongle|dongle accessory]]) | Transmit voltage-sense | |
|BMV-702 | Yes | Yes | Voltage-sense, and (optionally) temperature <sup> (1)</sup> | | |BMV-702 | Yes (requires [[https://www.victronenergy.com/accessories/ve-direct-bluetooth-smart-dongle|dongle accessory]]) | Transmit voltage-sense, and (optionally) temperature <sup> (1)</sup> | |
|BMV-712 | Yes | No, has built in bluetooth | Voltage-sense, and (optionally) temperature <sup> (1)</sup> | | |BMV-712 | Yes | Transmit voltage-sense, and (optionally) temperature <sup> (1)</sup> | |
|SmartSolar MPPTs | Yes <sup> (2)</sup>| No, has built in bluetooth | Uses received sense data to optimize charging | | |SmartSolar MPPTs | Yes <sup> (2)</sup> | Uses received sense data to optimize charging | |
|BlueSolar MPPTs | Yes | Yes | Uses received sense data to optimize charging | | |BlueSolar MPPTs | Yes | Uses received sense data to optimize charging | |
|Phoenix Smart IP43 Charger | No | - | Not yet supported, may be compatible in the future | | |Phoenix Smart IP43 Charger | No | Not yet supported, may be compatible in the future | |
|Orion-Tr Smart DC-DC Charger Isolated | No | - | Not yet supported, may be compatible in the future | | |Orion-Tr Smart DC-DC Charger Isolated | No | Not yet supported, may be compatible in the future | |
- To measure battery temperature, the [[https://www.victronenergy.com/accessories/temperature-sensor-for-bmv-702|BMV series temperature sensor is required]]. | - To measure battery temperature, the [[https://www.victronenergy.com/accessories/temperature-sensor-for-bmv-702|BMV series temperature sensor is required]]. |
|SmartSolar MPPT 250/100 |SCC125110210 (before s/n HQ1811) \\ SCC125110310 (before s/n HQ1811)|SCC125110210 (after s/n HQ1811) \\ SCC125110310 (after s/n HQ1811) | | |SmartSolar MPPT 250/100 |SCC125110210 (before s/n HQ1811) \\ SCC125110310 (before s/n HQ1811)|SCC125110210 (after s/n HQ1811) \\ SCC125110310 (after s/n HQ1811) | |
Note that when listed as not compatible; they will also not become compatible later. The incompatibility is due to a hardware limitation in those devices. | Note that when listed as **Incompatible**, that model will also not become compatible later. The incompatibility is due to a hardware limitation in those devices. There is a work around: connecting a [[https://www.victronenergy.com/accessories/ve-direct-bluetooth-smart-dongle|VE.Direct Bluetooth Smart dongle]] to such (by itself incompatible) SmartSolar charger model, will **enable** VE.Smart Networking support. Both Voltage and Temperature sense will work. In such scenario the internal Bluetooth interface of the SmartSolar should not be used anymore as communication errors may occur - instead the VE.Direct Bluetooth Smart dongle is to be used when connecting by phone or tablet. |
Also note that connecting a VE.Direct Bluetooth Smart dongle (ASS030536011) to an incompatible SmartSolar charger, will **enable** VE.Smart Networking support for the SmartSolar (Voltage and Temperature sense). In such scenario the internal Bluetooth interface of the SmartSolar should not be used anymore as communication errors may occur - instead the VE.Direct Bluetooth Smart dongle is to be used when connecting by phone or tablet. | |
