victronconnect:ve-smart-networking [2019-02-09 00:34] – [3.1 VE.Smart Networking compatible products] mvader | victronconnect:ve-smart-networking [2019-10-01 12:44] – [3.1 VE.Smart Networking compatible products] mvader | ||
Line 21: | Line 21: | ||
==== 3.1 VE.Smart Networking compatible products ==== | ==== 3.1 VE.Smart Networking compatible products ==== | ||
- | ^Product range ^ Compatible ^ [[https:// | + | ^Product range ^ Compatible ^ Function ^ |
- | |BMV-700 | + | |BMV-700 |
- | |BMV-702 | + | |BMV-702 |
- | |BMV-712 | + | |BMV-712 |
- | |SmartSolar MPPTs | Yes <sup> (2)</ | + | |SmartSolar MPPTs | Yes <sup> (2)</ |
- | |BlueSolar MPPTs | Yes | Yes | Uses received sense data to optimize charging | | + | |BlueSolar MPPTs | Yes | Uses received sense data to optimize charging | |
+ | |Phoenix Smart IP43 Charger | ||
+ | |Orion-Tr Smart DC-DC Charger Isolated | ||
- To measure battery temperature, | - To measure battery temperature, | ||
Line 43: | Line 44: | ||
|SmartSolar MPPT 250/ | |SmartSolar MPPT 250/ | ||
- | Note that when listed as not compatible; they will also not become compatible later. The incompatibility is due to a hardware limitation in those devices. | + | Note that when listed as **Incompatible**, |
==== 3.2 Limitations ==== | ==== 3.2 Limitations ==== | ||
* The maximum number of devices which can be connected on one network is 25. | * The maximum number of devices which can be connected on one network is 25. | ||
- | * VE.Smart Networking is designed for small systems which do not have a [[venus-os: | + | * VE.Smart Networking is designed for small systems which do not have a [[venus-os: |
* The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to // | * The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to // | ||
===== 4. Step by step instructions ===== | ===== 4. Step by step instructions ===== | ||
Line 99: | Line 104: | ||
Yes. In this instance it will simply act as a voltage- and temperature-measuring device. Note that the functionality is limited in that it does not (yet) show the graphs or other data which would normally be generated from these measurements. | Yes. In this instance it will simply act as a voltage- and temperature-measuring device. Note that the functionality is limited in that it does not (yet) show the graphs or other data which would normally be generated from these measurements. | ||
- | === Q6: Can I use Smart Battery Sense in systems already controlled by a CCGX/Venus GX? === | + | === Q6: Can I use Smart Battery Sense in systems already controlled by a GX device (eg CCGX/VenusGX)? === |
- | No. The CCGX/ | + | No. The GX device |
