victronconnect:ve-smart-networking [2019-02-09 00:34] – [3.1 VE.Smart Networking compatible products] mvader | victronconnect:ve-smart-networking [2019-08-15 12:36] – replace venus-device with GX device guy_stewart | ||
Line 44: | Line 44: | ||
Note that when listed as not compatible; they will also not become compatible later. The incompatibility is due to a hardware limitation in those devices. | Note that when listed as not compatible; they will also not become compatible later. The incompatibility is due to a hardware limitation in those devices. | ||
+ | Also note that connecting a VE.Direct Bluetooth Smart dongle (ASS030536011) to an incompatible SmartSolar charger, will **enable** VE.Smart Networking support for the SmartSolar (Voltage and Temperature sense). In such scenario the internal Bluetooth interface of the SmartSolar should not be used anymore as communication errors may occur - instead the VE.Direct Bluetooth Smart dongle is to be used when connecting by phone or tablet. | ||
==== 3.2 Limitations ==== | ==== 3.2 Limitations ==== | ||
* The maximum number of devices which can be connected on one network is 25. | * The maximum number of devices which can be connected on one network is 25. | ||
- | * VE.Smart Networking is designed for small systems which do not have a [[venus-os: | + | * VE.Smart Networking is designed for small systems which do not have a [[venus-os: |
* The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to // | * The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to // | ||
===== 4. Step by step instructions ===== | ===== 4. Step by step instructions ===== | ||
Line 99: | Line 101: | ||
Yes. In this instance it will simply act as a voltage- and temperature-measuring device. Note that the functionality is limited in that it does not (yet) show the graphs or other data which would normally be generated from these measurements. | Yes. In this instance it will simply act as a voltage- and temperature-measuring device. Note that the functionality is limited in that it does not (yet) show the graphs or other data which would normally be generated from these measurements. | ||
- | === Q6: Can I use Smart Battery Sense in systems already controlled by a CCGX/Venus GX? === | + | === Q6: Can I use Smart Battery Sense in systems already controlled by a GX device (eg CCGX/VenusGX)? === |
- | No. The CCGX/ | + | No. The GX device |
