victronconnect:ve-smart-networking [2018-07-02 13:34] – [2. Voltage and temperature sense - further details] mvader | victronconnect:ve-smart-networking [2020-11-05 08:31] – marmour | ||
- | ====== VE.Smart Networking ====== | + | Moved to: https:// |
- | A VE.Smart Network is a wireless network which allows a number of Victron products | + | |
- | Use VE.Smart to add remote voltage- and temperature- sensing to your Victron MPPT Solar Chargers. Connect either a BMV battery monitor - or the new [[https:// | + | |
- | {{youtube> | + | |
- | ===== 2. Voltage and temperature sense - further details ===== | + | |
- | The battery voltage data is used to compensate for voltage-drop over the battery cables. This ensures that the battery is charged with the exact voltage as configured in the charger - instead of a lower voltage due to resistance in the wiring. | + | |
- | The battery temperature data is used to adjust the charge voltages. When cold, a lead/acid battery typically needs a higher charge-voltage ...and a lower charge-voltage when it's hot. | + | |
- | For lithium batteries the charge-voltages remain the same at all temperatures, | + | |
- | ===== 3. Specifications ===== | + | |
- | ==== 3.1 VE.Smart Networking compatible products ==== | + | |
- | ^Product range ^ Compatible ^ Function | + | |
- | |BMV-700 | + | |
- | |BMV-702 | + | |
- | |BMV-712 | + | |
- | |SmartSolar MPPTs | Yes <sup> (3)</ | + | |
- | |BlueSolar MPPTs | Yes <sup> (1)</ | + | |
- | - Requires the [[https:// | + | |
- | - To measure battery temperature, | + | |
- | - Check the table below to see which models support this feature. | + | |
- | Older versions of our hardware do not support VE.Smart Networking. A list of the older // | + | |
- | ^Product | + | |
- | |VE.Direct Bluetooth Smart dongle | + | |
- | |SmartSolar MPPT 150/85 Tr |SCC010085210 |SCC115085211 | | + | |
- | |SmartSolar MPPT 150/85 MC4 | + | |
- | |SmartSolar MPPT 150/100 Tr | + | |
- | |SmartSolar MPPT 150/100 MC4 |SCC010100310 |SCC115110311 | | + | |
- | |SmartSolar MPPT 250/ | + | |
- | ==== 3.2 Limitations ==== | + | |
- | * The maximum number of devices which can be connected on one network is 25. | + | |
- | * VE.Smart Networking is designed for small systems which do not have a Venus-device - such as a Color Control GX or Venus GX. In systems which have a Venus-device, | + | |
- | ===== 4. Step by step instructions ===== | + | |
- | We recommend you configure the Smart Battery Sense, or BMV first ...and //then// add one or more solar chargers to that network. You can read the Smart Battery Sense manual [[https:// | + | |
- | ==== 4.1 Setup the Smart Battery Sense or BMV ==== | + | |
- | Open [[victronconnect: | + | |
- | Click //Create Network//, enter a name. Click //Save// and wait for the ' | + | |
- | ==== 4.2 Join the Solar Chargers to the network ==== | + | |
- | Go back and navigate to the //Solar charger//, then click // | + | |
- | Wait for the ' | + | |
- | ==== 4.3 Verify operation ==== | + | |
- | When everything is working OK, you will be able to see that the VE.Smart Networking page of the Solar Charger is receiving data: | + | |
- | Also the network icon {{: | + | |
- | Clicking on that icon will show the network status. | + | |
- | === Q1: Will you be adding wireless parallel charging as a feature? === | + | |
- | Yes we will - though we do not have a date for its introduction yet. | + | |
- | === Q2: Can several MPPTs be paired to one Smart Battery Sense or BMV? === | + | |
- | Yes. | + | |
- | === Q3: Is VE.Smart Networking disrupted if I connect a smartphone to it at the same time? === | + | |
- | Not at all. It is possible to connect with a smart phone, computer or tablet, at the same time. | + | |
- | === Q4: Will you add the same functionality to the BlueSmart Charger product range? === | + | |
- | Yes we will - though the exact functionality, | + | |
- | === Q5: Can Smart Battery Sense be used as a standalone product? === | + | |
- | Yes. In this instance it will simply act as a voltage- and temperature-measuring device. Note that the functionality is limited in that it does not (yet) show the graphs or other data which would normally be generated from these measurements. | + | |
- | === Q6: Can I use Smart Battery Sense in systems already controlled by a CCGX/Venus GX? === | + | |
- | No. The CCGX/Venus GX already has voltage sensing (soon they will have temperature sensing too). Adding Smart Battery Sense to the installation will confuse the voltage-sensing data. For further information please see: [[https:// | + | |
