victronconnect:ve-smart-networking [2020-05-15 17:24] – Design update of introduction, created a list of the items so they are easier to overview danjul | victronconnect:ve-smart-networking [2020-05-29 06:30] – [2. Voltage, temperature and current sense - further details] mvader |
A VE.Smart Network is a wireless communication network between Victron products. It is a wireless technology using Bluetooth Smart. | A VE.Smart Network is a wireless communication network between Victron products. It is a wireless technology using Bluetooth Smart. |
Features enabled by VE.Smart are, | Features: |
* Remote Voltage reading | * Remote Voltage reading |
* Temperature sensing | * Temperature sensing |
=== Remote voltage-, temperature and/or current sensing === | === Remote voltage-, temperature and/or current sensing === |
Use VE.Smart to add remote voltage, temperature and/or current sensing to your Victron MPPT Solar Chargers. Connect either a BMV battery monitor - or the new [[https://www.victronenergy.com/accessories/smart-battery-sense|Smart Battery Sense]], to a Solar Charger. The Solar Charger will receive the available information from the battery , like battery voltage and temperature (depending on the sensor) information, and use that data to optimize its charge parameters. This will improve charging-efficiency and prolong battery life. | Use VE.Smart to add remote voltage, temperature and/or current sensing to your Victron MPPT Solar Chargers. Connect either a BMV battery monitor, a SmartShunt, or the new [[https://www.victronenergy.com/accessories/smart-battery-sense|Smart Battery Sense]], to a Solar Charger. The Solar Charger will receive the available information from the battery , like battery voltage and temperature (depending on the sensor) information, and use that data to optimize its charge parameters. This will improve charging-efficiency and prolong battery life. |
=== Synchronised charging === | === Synchronised charging === |
Use also now the VE.Smart Networking to synchronise the charger algorithms from Solar Chargers and improve even further the charge-efficiency and battery life. This feature is only available on SmartSolars with firmware version equal or higher then v1.47 (Ve.Direct SmartSolars) and v1.04 (Ve.Can SmartSolars). | Pairing two or more SmartSolar chargers in a VE.Smart Network, enables synchronised charging. This improves the charge efficiency and battery life. |
===== 2. Voltage, temperature and current sense - further details ===== | ===== 2. Voltage, temperature and current sense - further details ===== |
For lithium batteries the charge-voltages remain the same at all temperatures, as long as it’s not //too// cold. Its better to not charge Ltihium batteries below 5C, to prevent them from being damaged and degraded. | For lithium batteries the charge-voltages remain the same at all temperatures, as long as it’s not //too// cold. Its better to not charge Ltihium batteries below 5C, to prevent them from being damaged and degraded. |
The battery current is used to allow the tail current setting (see the [[victronconnect:mppt-solarchargers#battery_settings|Solar Charger Manual]] for more details) to be used more precisely as, by having the actual battery current, the Solar Charger can decide better if absorption phase should stop and go to equalisation/float phase. | The battery current data is used to allow the tail current setting (see the [[victronconnect:mppt-solarchargers#battery_settings|Solar Charger Manual]] for more details) to be used more precisely as, by having the actual battery current, the Solar Charger can decide better if absorption phase should stop and go to equalisation/float phase. |
===== 3. Synchronised charging - further details ===== | ===== 3. Synchronised charging - further details ===== |
For chargers that are already connected and synchronised over VE.Can, pairing them in a VE.Smart Network is not necessary. In case they __are__ paired, the pairing will be ignored. | For chargers that are already connected and synchronised over VE.Can, pairing them in a VE.Smart Network is not necessary. In case they __are__ paired, the pairing will be ignored. |
=== How does synchronising works on solar chargers === | === How synchronising works on solar chargers === |
Synchronising the chargers works in a master-slave manner. The chargers will elect a master among them and that master will be the one to dictate the charge algorithm. As the master cannot be determined by the user, it is important to make sure all chargers belonging to the same network have the **same battery settings**. To know more about the battery settings and some other information, check the [[https://www.victronenergy.com/live/victronconnect:mppt-solarchargers|VictronConnect solar charger manual]]. | Synchronising the chargers works in a master-slave manner. The chargers will elect a master among them and that master will be the one to dictate the charge algorithm. As the master cannot be determined by the user, it is important to make sure all chargers belonging to the same network have the **same battery settings**. To know more about the battery settings and some other information, check the [[https://www.victronenergy.com/live/victronconnect:mppt-solarchargers|VictronConnect solar charger manual]]. |
After being elected, the master will make sure all chargers are on the same charge state and with the same voltage setpoint. As mentioned before, battery charge current is not controlled by the master, but by each of the chargers individually. | After being elected, the master will make sure all chargers are on the same charge state and with the same voltage setpoint. As mentioned before, battery charge current is not controlled by the master, but by each of the chargers individually. |
At the beginning of the day, the master will measure the battery voltage before any of the other chargers, in the network, starts charging (called battery idle voltage). This information is used to decide what should be the absorption total time for some types of batteries. The battery idle voltage shared with the other chargers, as well as the absorption total time of the day and the elapsed time on the current charge state. Those information are important so the charge algorithm can be resumed by the chargers if, for any reason, the master stop charging (i.e. sun went down on its panels, charger was shut down, charger was removed from the network, etc.). | At the beginning of the day, the master will measure the battery voltage before any of the other chargers in the network start charging (to find battery idle voltage). This information is used to decide what should be the total absorption time for some types of batteries. The battery idle voltage is shared with the other chargers, as well as the total absorption time, and the elapsed time on the current charge state. That information is important so the charge algorithm can be resumed by the chargers if, for any reason, the master stops charging (i.e. sun went down on its panels, charger was shut down, charger loses contact with the network, etc). |
In the absence of battery current sensor, as the BMV, the chargers on the network will have their output current added to estimate a better battery charge current. This way, the tail current setting, that is intended to finish the charge cycle earlier, can be used more precisely. | |
| In the absence of battery current sensor, such as the BMV, the chargers on the network will have their output current combined to estimate a better battery charge current. This improves the precision of the tail current setting, a feature intended to finish the charge cycle earlier if necessary. |
===== 4. VE.Smart Product Compatibility ===== | ===== 4. VE.Smart Product Compatibility ===== |
* The maximum number of devices which can be connected on one network is 10. | * The maximum number of devices which can be connected on one network is 10. |
* VE.Smart Networking is designed for small systems which do not have a [[venus-os:start|GX device]] - such as a Color Control GX or Venus GX. In systems which have a [[venus-os:start|GX device]], do not use VE.Smart Networking - [[https://www.victronenergy.com/live/victronconnect:ve-smart-networking#faq|See FAQ 6.]] If for some reason, the same information is being received by the charger over BLE and VE.Can/VE.Direct, the information coming over BLE (through VE.Smart Networking) will be ignored. | * VE.Smart Networking is designed for small systems which do not have a [[venus-os:start|GX device]] - such as a Color Control GX or Venus GX - controlling the chargers (e.g. in an ESS system) - [[https://www.victronenergy.com/live/victronconnect:ve-smart-networking#faq|See FAQ Q5]]. In systems which the [[venus-os:start|GX device]] is used for logging purposes only, VE.Smart Networking can be used to allow chargers to synchronise, or even receive information from sensors. Keep in mind that if, for some reason, the same information (i.e. voltage sense) is being received by the charger over BLE and VE.Can/VE.Direct, the information coming over BLE (through VE.Smart Networking) will be ignored. |
* The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to //VictronConnect//. | * The transmitter range will be found to be the same as the Bluetooth range - as experienced when connecting a device to //VictronConnect//. |
* It is not possible to measure multiple battery temperatures/voltages/charge currents: only one Smart Battery Sense, or one BMV can be used in a system. Having multiple sensors connected to different batteries can lead to charging issues as overcharging or heating up the batteries. Always make sure to have your sensors/chargers on the VE.Smart Networking connected to the same battery. If, by accident, two or more sensors (e.g. Smart Battery Sense and/or BMV) are connected to the same VE.Smart Networking, a priority mechanism is used to decide which battery temperature, battery voltage and battery current should be used by the charger. The priority mechanism is first based on the type of sensor (e.g. BMV has higher priority than the Smart Battery Sense), and second based on the serial number of the sensor. At the end, only one information will be used by the charger. | * It is not possible to measure multiple battery temperatures/voltages/charge currents: only one Smart Battery Sense, or one BMV can be used in a system. Having multiple sensors connected to different batteries can lead to charging issues as overcharging or heating up the batteries. Always make sure to have your sensors/chargers on the VE.Smart Networking connected to the same battery. If, by accident, two or more sensors (e.g. Smart Battery Sense and/or BMV) are connected to the same VE.Smart Networking, a priority mechanism is used to decide which battery temperature, battery voltage and battery current should be used by the charger. The priority mechanism is first based on the type of sensor (e.g. BMV has higher priority than the Smart Battery Sense), and second based on the serial number of the sensor. At the end, only one information will be used by the charger. |
=== Q5: Can I use Smart Battery Sense in systems already controlled by a GX device (eg CCGX/VenusGX)? === | === Q5: Can I use Smart Battery Sense in systems already controlled by a GX device (eg CCGX/VenusGX)? === |
No. The GX device already has voltage sensing (soon they will have temperature sensing too). Adding Smart Battery Sense to the installation will confuse the voltage-sensing data. For further information please see: [[https://www.victronenergy.com/live/ccgx:start#dvcc_-_distributed_voltage_and_current_control|CCGX/Distributed Voltage and Current Control.]] | Yes, but keep in mind that if, voltage or temperature information is also present on the GX Device, the charger will use that information in favor of the information coming from the Smart Battery Sense. The GX device already has, in most cases, voltage sensing (soon they will have temperature sensing too), so adding a Smart Battery Sense to the installation is not necessary. For further information please see: [[https://www.victronenergy.com/live/ccgx:start#dvcc_-_distributed_voltage_and_current_control|CCGX/Distributed Voltage and Current Control.]] |
===== DISQUS ===== | ===== DISQUS ===== |
~~DISQUS~~ | ~~DISQUS~~ |
