victronconnect:start
victronconnect:start [2020-04-06 16:11] – [10.6 Remote device access] mcorluka | victronconnect:start [2021-01-11 13:04] (current) – link was incorrect boekel | ||
- | Welcome | + | |
- | [[https:// | + | |
- | Also, [[https:// | + | |
- | See [[# | + | |
- | ^ Method | + | |
- | | [[ve.direct: | + | |
- | | [[https:// | + | |
- | Use the [[# | + | |
- | {{victronconnect: | + | |
- | | Huawei | + | |
- | | Lenovo | + | |
- | | Samsung | + | |
- | **Warning: | + | |
- | **Device list**\\ | + | |
- | LOCAL - This page shows all the Victron products that have been discovered by your device, and to which a connection can be made. Click on the desired product. | + | |
- | VRM - This page will show a GX device if it is connected to your VRM account. | + | |
- | Clicking on ' | + | |
- | *To access ' | + | |
- | From ' | + | |
- | The ' | + | |
- | From ' | + | |
- | **Windows**\\ | + | |
- | **macOS X**\\ | + | |
- | {{youtube> | + | |
- | ==== 5.4 How to disable Bluetooth ==== | + | |
- | All our products that have Bluetooth built-in, have a feature that allows disabling Bluetooth. Typically the reason for doing so is security, nothing more secure than disabling it. For example on unmanned roadside backup power stations; or other more large scale deployments. | + | |
- | In most cases, it's also possible to re-enable Bluetooth after disabling. For example by using a VE.Direct cable. The only exception is the Lithium Smart batteries: once Bluetooth is disabled on them, it is disabled forever. | + | |
- | === Here is how to disable Bluetooth === | + | |
- | First complete your connection; then go to the **Product info** page. To access that page, click the button on the upper right. For some products, it will be the settings icon: {{: | + | |
- | If the product supports turning Bluetooth off, you will see the field " | + | |
- | Since for our Lithium Smart batteries this change is permanent, the app will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth just enter the code displayed and choose " | + | |
- | ==== 5.5 How to re-enable Bluetooth == | + | |
- | **Via VE.Direct: | + | |
- | **[[https:// | + | |
- | - Temporarily enabled at power-up for 30s: You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | + | |
- | - Permanently disabled: __Once Bluetooth is disabled, it can not be re-enabled.__ | + | |
- | **Chargers with a MODE button:** | + | |
- | Press and hold the MODE button for 10s will reset Bluetooth: | + | |
- | - Reset PIN code | + | |
- | - Clear bonding information | + | |
- | - Blue Smart IP22 | + | |
- | - Blue Smart IP65 | + | |
- | **Smart Battery Protect:** Bluetooth can be disabled/ | + | |
- | selecting **F** (enable) or **h** (disable). Check the product manual for more details. | + | |
- | **Smart BMV-712:** The BMV-712' | + | |
- | through the settings menu. Check the product manual for more details. | + | |
- | **Smart BMS:** Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | + | |
- | **Smart Shunt**: Bluetooth can be re-enabled using a USB-VE.Direct cable. | + | |
- | ==== 5.6 Importing and converting a GX Product Family database File ==== | + | |
- | Go to the " | + | |
- | Check [[# | + | |
- | ^Error | + | |
- | VictronConnect-Remote functionality enables Victron devices with a VE.Direct interface to be accessed remotely through a [[https:// | + | |
- | This powerful new feature allows full device configuration and monitoring from practically anywhere in the world using the VictronConnect app. | + | |
- | The user interface experience is just like the devices were connected locally using Bluetooth or a wired VE.Direct to USB interface. | + | |
- | The VictronConnect-Remote feature is ONLY compatible with devices connected to a GX Device with a VE.Direct interface. | + | |
- | This includes; | + | |
- | * Specific inverters with a VE.Direct interface (Phenix Inverter VE.Direct and Pheonix Inverter Smart) | + | |
- | * Specific mains chargers with a VE.Direct interface (Pheonix Smart IP43) | + | |
- | Devices connected with a VE.Bus interface, such as Multiplus/ | + | |
- | Devices connected using a VE.Can interface, such as Lynx Shunt, Skylla chargers and MPPT solar chargers using a VE.Can interface are also NOT compatible and cannot be configured remotely. | + | |
- | * GX Device - Venus OS FW: v2.40 (However v2.53 recommended for full functionality) | + | |
- | - Confirm that the phone, tablet or PC has VictronConnect installed and that the software version meets or exceeds the minimum requirements - upgrade if necessary | + | |
- | * If using a tablet or PC your browser may also request permission to proceed, if prompted select ‘Open’ | + | |
- | === 10.3.3 GX Device === | + | |
- | 1- Confirm that the GX Device is running Venus OS firmware version that meets or exceeds the minimum requirements - upgrade if necessary | + | |
- | The local tab displays all devices that are within local Bluetooth and wireless LAN range or physically connected to the phone, tablet or PC with VictronConnect (such as with a VE.Direct to USB or MK3 to USB interface cable) | + | |
- | Any installation can be selected to access the VRM online portal or connected devices. | + | |
- | The ‘OVERVIEW’ tab has an image of the GX device, the name of the VRM installation and a direct link to the associated [[https:// | + | |
- | The ‘DEVICES’ tab has a list of all compatible devices that are physically connected to the GX device. | + | |
- | ==== 10.6 Remote device access ==== | + | |
- | When a device is selected it will take a few seconds for a connection to be made, once the connection is established live device information/ | + | |
- | == Device not found == | + | |
- | * VictronConnect-Remote is only compatible with devices that use a VE.Direct interface to the GX device – see the ‘compatibility’ section. | + | |
- | * Ensure that that the missing device is physically connected to the GX device, with the VE.Direct cable properly installed at both ends. | + | |
- | * Ensure that the device is running a recent firmware version. | + | |
- | == Installation/ | + | |
- | * Ensure that the GX device is running the minimum compatible Venus OS firmware version – see the ‘settings’ section. | + | |
- | * Ensure that the phone, tablet or PC is running the minimum compatible VictronConnect software version – see the ‘settings’ section. | + | |
- | == VRM account == | + | |
- | == Systems with no GX device == | + | |
- | * VictronConnect-Remote functionality is not possible unless the system includes a GX device. A GX device can be easily added to any system and there are a [[https:// | + | |
- | * VictronConnect-Remote functionality is not possible unless GX device at the installation site has an active internet connection. | + | |
- | * The use of the VictronConnect-Remote feature will slightly increase the GX device CPU load. | + | |
- | * In some large/ | + | |
- | * It is important to select a GX device that has sufficient performance capability in relation to the system design, for example a Cerbo GX has significantly more processing power than a Color Control GX and is much better suited to large/ | + | |
- | The first step before attempting any of the specific troubleshooting advice below is to power down and then restart all related devices, (this includes phones, tablets, computers and Victron equipment). | + | |
- | 2. [[https:// | + | |
- | ==== 11.2 Bluetooth connection issues on Android devices ==== | + | |
- | See section [[# | + | |
- | cd / | + | |
- | http:// | + | |
- | To do this, | + | |
- | - Select Settings | + | |
- | | MPPT 100/ | + | |
- | | MPPT 150/ | + | |
- | | BMV-700 | + | |
- | | BMV-702 | + | |
- | | BMV-712 | + | |
- | Inverter/ | + | |
victronconnect/start.1586182281.txt.gz · Last modified: 2020-04-06 16:11 by mcorluka
