Both sides previous revision Previous revision Next revision | Previous revision Last revision Both sides next revision | ||
victronconnect:start [2020-07-22 11:06] thiemovanengelen [11.2 Bluetooth connection issues on Android] |
victronconnect:start [2020-10-27 14:40] marmour |
- | Welcome | + | |
- | [[https:// | + | |
- | Also, [[https:// | + | |
- | See [[# | + | |
- | ^ Method | + | |
- | | [[ve.direct: | + | |
- | | [[https:// | + | |
- | Use the [[# | + | |
- | To connect to your Victron product, over Bluetooth, always connect from within VictronConnect. Do not connect from the phone' | + | |
- | - Enable the Bluetooth on your phone. | + | |
- | - The first time you attempt to connect the phone will ask to pair with the Victron product. Enter the PIN code. The default PIN code is 000000 | + | |
- | - The connection is complete. | + | |
- | If the connection was not successful please refer to section [[# | + | |
- | To prevent unauthorised connections to your Victron product we recommend you change the PIN code. Avoid using obvious PIN codes such as 111111 or 123456. | + | |
- | To change the PIN code, first, complete your connection. Then go to the **Product info** page. To access that page, click the button on the upper right. For some products, it will be the settings icon: {{: | + | |
- | On this page, select the change PIN code button. | + | |
- | Note that after changing the PIN code, all other phones connected to the Victron product need to have their pairing information refreshed; and first, the old pairing information needs to be removed. See [[#3.4 Bluetooth Smart - Removing from the list of paired devices | section 3.4]] to learn how to remove the pairing information. | + | |
- | You may want or need to remove a product from the list of Bluetooth paired devices on your phone. For example, if the PIN code of your product has been changed on a different phone. | + | |
- | To remove the pairing information you will need to go to your phone' | + | |
- | === Remove Bluetooth pairing on iOS: === | + | |
- | {{victronconnect: | + | |
- | === Remove Bluetooth pairing on Android: === | + | |
- | Note that on Windows, VictronConnect cannot use Bluetooth Smart to connect to a product. Other connection methods, such as USB, or LAN and WiFi do work properly. | + | |
- | ==== 4.3 Android === | + | |
- | The pairing does not work on some phones running Android 5. The PIN code popup does not appear, or it appears without a text field to enter the PIN code. If you have this situation, your phone might report that it has been paired with the Victron product - but it has not. | + | |
- | Unfortunately, | + | |
- | Android 5 and later requires access permission for VictronConnect to the (coarse) location services. Otherwise it can not scan for the Bluetooth products. | + | |
- | Note that after enabling location services, the GPS itself, can be switched off again: the Android location services are more than GPS. Bluetooth, and WiFi-, scan results can technically also be used to approximate the phone' | + | |
- | Despite the above, you can be sure that Victron is not interested in, nor tracking your location. | + | |
- | Being sensitive to privacy issues at Victron ourselves, we are not happy with this requirement. But there is nothing we can do about it, unfortunately. More information about why it is needed to enable the location services is [[https:// | + | |
- | | Huawei | + | |
- | | Lenovo | + | |
- | | Samsung | + | |
- | *Assumes the phone runs the latest firmware released by the manufacturer. | + | |
- | It would be nice to forever support all existing versions of Android, iOS, Windows, and other systems. But unfortunately, | + | |
- | In such a situation, we recommend updating your phone to the latest OS. For situations where that is not possible we make these older versions available: | + | |
- | **Warning: | + | |
- | **Device list**\\ | + | |
- | LOCAL - This page shows all the Victron products that have been discovered by your phone, and to which a connection can be made. Click on the desired product. | + | |
- | VRM - This page will show a GX product if it is connected to your VRM account. | + | |
- | Clicking on ' | + | |
- | *To access ' | + | |
- | From ' | + | |
- | Clicking on the Phoenix Inverter allows you to view dynamic data such as power-draw of connected loads; a power bar will show how hard your inverter is working, and you will find information such as battery voltage, etc. | + | |
- | The Blue Smart IP65 battery charger comes with Bluetooth already built-in. When the Blue Smart charger is powered-up it will be discoverable using the VictronConnect app on your phone. (Except Windows PC - See **3.1 Windows PC**, above). | + | |
- | The ' | + | |
- | Lithium Batteries Smart have Bluetooth built-in. Clicking on the Lithium battery from the Device list will allow you to view live data about the battery status, voltage, and temperature. You will also see the voltage of each cell - which is an essential guide to battery health. | + | |
- | From ' | + | |
- | **Windows**\\ | + | |
- | Here is a VictronConnect app screenshot from a PC using a version of the Microsoft Windows operating system showing information from an MPPT. | + | |
- | **macOS X**\\ | + | |
- | Here is a VictronConnect app screenshot from a PC running the Mac Operating System showing information from an MPPT. | + | |
- | {{youtube> | + | |
- | ==== 5.3 Renaming your products ==== | + | |
- | It is possible to change the name of your Victron product to make identification easier. This is especially useful if you have multiple products, such as 3 MPPTs and 2 BMV' | + | |
- | To change the name: First, complete your connection; then go to the **Product info** page. To access that page, click the button on the upper right. For some products, it will be the settings icon: {{: | + | |
- | ==== 5.4 How to disable and re-enable Bluetooth ==== | + | |
- | All our products that have Bluetooth built-in, have a feature that allows disabling Bluetooth. Typically the reason for doing so is security, even though the Bluetooth connection is protected by a PIN code, there is nothing more secure than disabling it. | + | |
- | In most cases, it's also possible to re-enable Bluetooth after disabling. For example by using a VE.Direct cable. | + | |
- | There are, however, a few exceptions: | + | |
- | * The [[# | + | |
- | === Finding the Bluetooth menu === | + | |
- | First, complete your connection; then go to the **Product info** page by clicking the button on the upper right: | + | |
- | * For some products, it will be the settings icon: {{: | + | |
- | * For other products you'll find the {{: | + | |
- | If the product has the feature that Bluetooth can be disabled, you will see the field " | + | |
- | For some products, a Disable button is shown instead of a toggle switch. | + | |
- | === How to re-enable Bluetooth === | + | |
- | == Re-enable Bluetooth using VE.Direct == | + | |
- | Connect the product with a VE.Direct to USB cable to your phone and use VictronConnect to re-enable Bluetooth in the **Product Info** page (see [[# | + | |
- | == Re-enable Bluetooth using the MODE button on the product == | + | |
- | Press and hold the MODE button on the product for 10 seconds will perform a Bluetooth reset. This means that the following actions will be executed: | + | |
- | * Bluetooth will be re-enabled | + | |
- | * The connected Bluetooth product will be disconnected | + | |
- | * The PIN code is reset to its [[# | + | |
- | * The pairing information is cleared; this requires [[victronconnect: | + | |
- | == Lithium Smart batteries == | + | |
- | The product page can be found [[https:// | + | |
- | Once Bluetooth is disabled, it is disabled **permanently** and is **irreversible**. This means that VictronConnect will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth, enter the code displayed, and choose " | + | |
- | == Phoenix Smart IP43 Chargers == | + | |
- | - Using the [[# | + | |
- | - Using a [[# | + | |
- | == Blue Smart IP22 Chargers == | + | |
- | Once Bluetooth is disabled, it can be re-enabled with the [[# | + | |
- | == Blue Smart IP65 Chargers == | + | |
- | == Blue Smart IP67 Chargers == | + | |
- | For these chargers there are two options: | + | |
- | * Disable Bluetooth **permanently**. This option is **irreversible** and VictronConnect will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth, enter the code displayed and choose " | + | |
- | * Enable Bluetooth for 30 seconds at power-up. This allows you to connect to the product and to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | + | |
- | == SmartSolar MPPTs == | + | |
- | Bluetooth can be re-enabled by connecting a VE.Direct to USB cable to your phone and following [[# | + | |
- | **Smart Battery Protect**\\ | + | |
- | Bluetooth can be disabled/ | + | |
- | **Smart BMV-712**\\ | + | |
- | The BMV-712' | + | |
- | **Smart BMS**\\ | + | |
- | Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | + | |
- | **Smart Shunt**\\ | + | |
- | VictronConnect for Mac OSX and Windows allows you to import and convert the database log file (that is created by the VenusOS on the GX Product Family) to a Microsoft Excel XLSX file. This can be useful if the site is remote and without an internet connection to upload the file to the [[https:// | + | |
- | ==== 7.1 Save, load, share and manage settings ==== | + | |
- | Connect your phone to the Victron product, go to the ' | + | |
- | When the file is loaded, the changes are not immediately applied to make it possible to review them first. The differences between the product' | + | |
- | The Settings file manager is located in the main menu, and shows all stored settings: | + | |
- | From here files can be opened, shared or removed: | + | |
- | ==== 7.2 Settings files and the demo library ==== | + | |
- | The demo library can be a great tool for an installer to create a set of settings, and then share it to a customer whom can then apply it to their product. | + | |
- | Note that whilst saving settings from the demo library is possible, loading settings from within the demo library is not possible. | + | |
- | ==== 7.3 Limitation in opening older settings files ==== | + | |
- | There are two methods to open a previously stored settings-file: | + | |
- | - From the settings file manager, as in the above screenshot, to see the settings without having to be connected to the product. A snapshot of all data, including voltage readings, history data, and so forth, will be loaded and visible to inspect. | + | |
- | - From the product settings pages, only possible when connected to a product. | + | |
- | Note that the first method only works when the settings file is created with the exact same VictronConnect version that was used to store the file. To open a file made with an older VictronConnect version, use the second method: connect the same product, and then load the settings. | + | |
- | * Create a specific product setup, save it ...and then send it to a customer so that they have those settings on their phone, and can install them on their Victron product. | + | |
- | __What about updating Firmware on VE.Bus products such as MultiPlus and Quattro? | + | |
- | First, connect to the product, then go to the **Product info** page. Under the Firmware version if you will see a text informing you if you are using the latest available version or if there is an update available. If a new version is available you can start the update process by pressing the " | + | |
- | Some firmware versions are mandatory, when you connect to the product VictronConnect will prompt to update immediately in case there is a mandatory version available. | + | |
- | Or, when not close to the product, open the Demo library, and select the product. The Product info page will show the latest available version that is shipped with VictronConnect. | + | |
- | After connecting your product, VictronConnect will automatically check whether a mandatory update is available, and in that case, you will be guided through the update procedure before doing anything else. | + | |
- | If an update is available but is not mandatory, you will be able to see your product' | + | |
- | A firmware update - when available - will need to be completed in order to change settings on your Victron product using VictronConnect. | + | |
- | The previous chapter explained how VictronConnect will automatically update to the latest firmware version. Besides that, it is also possible to update a product with a file that you supply yourself. | + | |
- | * Update to a very recent version, that's already available on [[https:// | + | |
- | * Update a product to a special or unreleased version. | + | |
- | With your phone and Victron product connected to VictronConnect, | + | |
- | There is no need to worry about using a wrong file - VictronConnect will always first check if the file matches the product. And if wrong, it will show a "wrong firmware file error" | + | |
- | The process is slightly different from the Windows/ | + | |
- | Firstly, you need to add the desired firmware file to the VictronConnect firmware library. Firmware files can be added to the library from an email attachment, web browser, Dropbox, file browser, and any kind of app that can handle files. For both iOS and Android the procedure to add the file is the same: go to the app that contains the firmware file, tap on it, and open it with VictronConnect. VictronConnect will be opened and show: "File added to the firmware library" | + | |
- | If the message doesn' | + | |
- | In case you are not sure which file to use, it is not a problem to add multiple files to the library. In the next step, VictronConnect will automatically only show the files that match with the connected product. | + | |
- | * **Note for iOS**: The current version of Google Chrome for iOS fails to download " | + | |
- | * **Note for Android**: VictronConnect needs to be running before opening files. | + | |
- | Open VictronConnect and, without closing it, switch to the app containing the file, select it, and choose to open it with VictronConnect. | + | |
- | Here are screenshot showing the detailed steps: | + | |
- | Now, after adding the firmware file to the library, go to the " | + | |
- | Select the desired file from the list, see next screenshot - it shows one entry in the list: | + | |
- | Note that the update mechanism will detect-and-reject firmware files which are not targeted for the current product: there is no need to worry about loading a wrong firmware file. | + | |
- | Once selected you will be guided through the update process: | + | |
- | In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible and check that the Bluetooth function is enabled on your phone. | + | |
- | Check [[# | + | |
- | ^Error | + | |
- | VictronConnect-Remote functionality enables Victron products with a VE.Direct interface to be accessed remotely through a [[https:// | + | |
- | This powerful feature allows full product configuration and monitoring from practically anywhere in the world using the VictronConnect app. | + | |
- | The user interface experience is just like the products were connected locally using Bluetooth or a wired VE.Direct to USB interface. | + | |
- | A video demonstrating the feature is available here: | + | |
- | The VictronConnect-Remote feature is ONLY compatible with products connected to a GX product with a VE.Direct interface. | + | |
- | This includes; | + | |
- | * Specific inverters with a VE.Direct interface (Phoenix Inverter VE.Direct and Phoenix Inverter Smart) | + | |
- | * Specific mains chargers with a VE.Direct interface (Phoenix Smart IP43) | + | |
- | Products connected with a VE.Bus interface, such as Multiplus/ | + | |
- | Products connected using a VE.Can interface, such as Lynx Shunt, Skylla chargers, and MPPT solar chargers using a VE.Can interface are also NOT compatible and cannot be configured remotely. | + | |
- | * GX Product- Venus OS FW: v2.40 (However v2.53 recommended for full functionality) | + | |
- | - Confirm that the phone has VictronConnect installed and that the software version meets or exceeds the minimum requirements - upgrade if necessary | + | |
- | * If using a tablet or PC your browser may also request permission to open VictronConnect, | + | |
- | === 10.3.3 GX Product === | + | |
- | 1- Confirm that the GX Product is running Venus OS firmware version that meets or exceeds the minimum requirements - upgrade if necessary | + | |
- | The local tab displays all products that are within local Bluetooth and wireless LAN range or physically connected to the phone with VictronConnect (such as with a VE.Direct to USB or MK3 to USB interface cable) | + | |
- | Any installation can be selected to access the VRM online portal or connected products. | + | |
- | The ‘OVERVIEW’ tab has an image of the GX product, the name of the VRM installation, | + | |
- | The ‘DEVICES’ tab has a list of all compatible products that are physically connected to the GX product. | + | |
- | ==== 10.6 Remote product access ==== | + | |
- | When a product is selected it will take a few seconds for a connection to be made, once the connection is established live product information/ | + | |
- | == Product not found == | + | |
- | * VictronConnect-Remote is only compatible with products that use a VE.Direct interface to the GX product – see the ‘compatibility’ section. | + | |
- | * Ensure that that the missing product is physically connected to the GX product, with the VE.Direct cable properly installed at both ends. | + | |
- | * Ensure that the product is running a recent firmware version. | + | |
- | == Installation/ | + | |
- | * Ensure that the GX product is running the minimum compatible Venus OS firmware version – see the ‘settings’ section. | + | |
- | * Ensure that the phone is running the minimum compatible VictronConnect software version – see the ‘settings’ section. | + | |
- | == VRM account == | + | |
- | == Systems with no GX product == | + | |
- | * VictronConnect-Remote functionality is not possible unless the system includes a GX product. A GX product can be easily added to any system and there are a [[https:// | + | |
- | * VictronConnect-Remote functionality is not possible unless the GX product at the installation site has an active internet connection. | + | |
- | * The use of the VictronConnect-Remote feature will slightly increase the GX product CPU load. | + | |
- | * In some large/ | + | |
- | * It is important to select a GX product that has sufficient performance capability in relation to the system design, for example, a Cerbo GX has significantly more processing power than a Color Control GX and is much better suited to large/ | + | |
- | == VictronConnect Remote troubleshooting == | + | |
- | VictronConnect will report errors encountered during communication attempts with VRM in a message box with an error code. The code can have one of the following value: | + | |
- | |-100 | Call to retrieve a list of child devices expired (60 seconds). The most common cause is a bad internet connection. | | + | |
- | | 1 | No link to VRM can be established. Check if the internet is present and try again. | | + | |
- | | 2 | VRM encountered temporary difficulties. Try again in a while. | | + | |
- | | 5 | The local system ran out of resources. Free some system resources and try again. | | + | |
- | | 8 | An error occurred with the network (e.g., the network cable was accidentally plugged out). | | + | |
- | | 13 | Proxy authentication error. VictronConnect does not support communication over proxy. | | + | |
- | | 14 | Failed to establish a secure connection to VRM. | | + | |
- | |65538| VRM MQTT broker is not responding. Please try again in a while. | | + | |
- | There are also other error codes that could be reported. They are a result of internal errors in VictronConnect and/or VRM. In case these errors persist after a retry, please create a " | + | |
- | VictronConnect Remote is establishing communication with a range of services on the ' | + | |
- | The #1 first step before attempting any of the specific troubleshooting advice below is to power down and then restart all related devices. This includes closing the software, restarting the phone, and Victron product. This will solve most issues. | + | |
- | For example, with Victron MPPTs you must isolate the MPPT from both battery and solar voltage so that no lights appear, before reconnecting it again. | + | |
- | == I cannot find my product listed == | + | |
- | * Make sure your product is in range. | + | |
- | * If a firmware update failed, the product //Custom Name// might have reverted to its original name and serial number, check if that is the case. Once the update is completed, the //Custom Name// will be back. See more tips about troubleshooting firmware updates on [[start# | + | |
- | * Only one phone can be connected to a product at the same time. Make sure that no other phone is already connected. | + | |
- | * Make sure you are attempting to connect from //within// VictronConnect - not from the system menu of your phone. If you have connected from the system menu: close VictronConnect, | + | |
- | == I can see but not connect to my product == | + | |
- | - Make sure you are trying to connect to the right product. See [[start# | + | |
- | - Make sure your product is in range. It can be that you are close enough to see the product but not close enough to connect to it. | + | |
- | - Make sure that Bluetooth is still enabled on your phone. If Bluetooth was disabled after scanning, you may be able to see your product listed but you won't be able to connect to it. | + | |
- | - Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the product, or if your Victron product has been connected to too many phones. The product will only remember the last 10 phones connected to it. To solve this, remove the pairing completely from your phone system menu. Then open VictronConnect and re-pair the product and your phone. Watch these instructional videos to learn how to remove the pairing on {{victronconnect: | + | |
- | - If you are using an Android phone, check [[start# | + | |
- | - Make sure you are up to date with the latest version of VictronConnect. | + | |
- | - [[https:// | + | |
- | - Then [[https:// | + | |
- | - Force close the VictronConnect app. Instructions: | + | |
- | - Reconnecting in VictronConnect using the default PIN 000000 | + | |
- | ==== 11.2 Bluetooth connection issues on Android ==== | + | |
- | === Step 1: Check that your phone is supported === | + | |
- | See section [[# | + | |
- | On Android 5 and later VictronConnect needs access to the phone' | + | |
- | For Bluetooth scanning to work, the Location (or GPS) functionality on the phone needs to be enabled. | + | |
- | === Step 5. Search & connect from within VictronConnect, | + | |
- | On some Android phones, the PIN code pop-up dialog doesn' | + | |
- | When successfully connected using another phone, VictronConnect will automatically update the firmware in the Victron Bluetooth product. After the firmware has been updated you may find that you can use the Android phone with which you were experiencing difficulties. | + | |
- | Keep your phone as close to the product as possible. If the update fails due to Bluetooth connectivity problems, and if your phone is already paired to a product, try and remove the pairing completely from your phone' | + | |
- | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. If the update fails even after many attempts, try using another phone or tablet, if possible an Apple iOS phone - they usually work without any issues. After the update, you may find that you can use the phone with which you were having difficulty. | + | |
- | When the firmware update fails at 4% or less, VictronConnect cannot make the product switch to the update mode. | + | |
- | cd / | + | |
- | http:// | + | |
- | Please note that this service report is for Victron internal use and is not able to be read or used for any other purpose than developer troubleshooting. | + | |
- | To do this, | + | |
- | - Select Settings | + | |
- | - Save, email, or copy the file to Victron, via email or the Victron Community. | + | |
- | If you require more detailed power system diagnostic information, | + | |
- | | MPPT 100/ | + | |
- | | MPPT 150/ | + | |
- | | BMV-700 | + | |
- | | BMV-702 | + | |
- | | BMV-712 | + | |
- | In order to keep this section short, all these products are referred to as VE.Bus products. | + | |
- | The minimal required version of the VE.Bus products are 19xx111 for European units and 20xx111 for 120V, which were released in 2007. Older models, 18xxxxx are not supported. | + | |
- | Inverter/ | + | |
