victronconnect:start
victronconnect:start [2020-07-01 16:29] – [MultiPlus, EasySolar, Quattro, Phoenix Inverter with VE.Bus, and similar products] evandromr | victronconnect:start [2020-08-22 23:33] – [10.8 Troubleshooting and FAQ] nlakatos | ||
Line 746: | Line 746: | ||
VictronConnect-Remote functionality enables Victron products with a VE.Direct interface to be accessed remotely through a [[https:// | VictronConnect-Remote functionality enables Victron products with a VE.Direct interface to be accessed remotely through a [[https:// | ||
- | This powerful | + | This powerful feature allows full product configuration and monitoring from practically anywhere in the world using the VictronConnect app. |
The user interface experience is just like the products were connected locally using Bluetooth or a wired VE.Direct to USB interface. | The user interface experience is just like the products were connected locally using Bluetooth or a wired VE.Direct to USB interface. | ||
+ | A video demonstrating the feature is available here: | ||
+ | {{youtube> | ||
==== 10.2 Compatibility ==== | ==== 10.2 Compatibility ==== | ||
Line 895: | Line 899: | ||
== VictronConnect Remote troubleshooting == | == VictronConnect Remote troubleshooting == | ||
- | VictronConnect will report errors encountered during communication attempts with VRM in a message box with an error code. The code can have one of the following value: | + | VictronConnect will report errors encountered during communication attempts with VRM in a message box with an error code (e.g. #R999, or #V2). The numeric part of the code can have one of the following value: |
^Error ^Description^ | ^Error ^Description^ | ||
- | |-100 | Call to retrieve a list of child devices expired (60 seconds). The most common cause is a bad internet connection. | | + | |999 | Call to retrieve a list of child devices expired (60 seconds). The most common cause is a bad internet connection. | |
| 1 | No link to VRM can be established. Check if the internet is present and try again. | | | 1 | No link to VRM can be established. Check if the internet is present and try again. | | ||
- | | 2 | VRM encountered temporary difficulties. Try again in a while. | | + | | 2 | VRM encountered temporary difficulties. Try again in a while. It could also indicate issues with your credentials. | |
| 5 | The local system ran out of resources. Free some system resources and try again. | | | 5 | The local system ran out of resources. Free some system resources and try again. | | ||
| 8 | An error occurred with the network (e.g., the network cable was accidentally plugged out). | | | 8 | An error occurred with the network (e.g., the network cable was accidentally plugged out). | | ||
Line 944: | Line 948: | ||
==== 11.2 Bluetooth connection issues on Android ==== | ==== 11.2 Bluetooth connection issues on Android ==== | ||
- | === Step 1: Check that your phoneis | + | === Step 1: Check that your phone is supported === |
See section [[# | See section [[# | ||
Line 971: | Line 975: | ||
Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code. | Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code. | ||
+ | On Android it is also possible that other apps prevent the PIN code pop-up from showing, even when pairing in the Android Bluetooth settings menu. One such an app is "FrSky Free Link", which even blocks pairing with Bluetooth headsets. In this case, the thing to do is remove the problematic app. This can be done by uninstalling apps one by one (starting with apps that use or connect to Bluetooth devices), removing all apps or even resetting the phone to factory defaults. When the Victron products are paired to the phone/ | ||
The default pin-code is 000000, six times zero. | The default pin-code is 000000, six times zero. | ||
=== Step 7. Try another phone at first === | === Step 7. Try another phone at first === |
