victronconnect:start
victronconnect:start [2020-04-23 17:42] – [5.4 How to disable and re-enable Bluetooth] mbosma | victronconnect:start [2020-10-18 05:52] – [10.8 Troubleshooting and FAQ] nlakatos | ||
Line 18: | Line 18: | ||
[[https:// | [[https:// | ||
===== 2. Download and installation ===== | ===== 2. Download and installation ===== | ||
- | VictronConnect is available to users of Windows PCs, macOS X, iOS and Android phones, as well as tablets. | + | VictronConnect is available to users of Windows PCs, macOS X, iOS and Android phones, as well as tablets. |
Also, [[https:// | Also, [[https:// | ||
- | See [[# | + | See [[# |
===== 3. Connecting ===== | ===== 3. Connecting ===== | ||
Line 41: | Line 43: | ||
- | To connect to your Victron product, over Bluetooth, always connect from within VictronConnect. Do not connect from the device's system menu because VictronConnect will not find your Victron product. | + | To connect to your Victron product, over Bluetooth, always connect from within VictronConnect. Do not connect from the phone's system menu because VictronConnect will not find your Victron product. |
Here is how to connect: | Here is how to connect: | ||
- | - Enable the Bluetooth on your phone, tablet or laptop (device). | + | - Enable the Bluetooth on your phone. |
- Open VictronConnect, | - Open VictronConnect, | ||
- On a phone or tablet, pull down the screen, or tap the refresh button to initiate a scan. | - On a phone or tablet, pull down the screen, or tap the refresh button to initiate a scan. | ||
- On a computer or laptop: click the "Scan or Refresh" | - On a computer or laptop: click the "Scan or Refresh" | ||
- | - The first time you attempt to connect the phone will ask to pair with the device. Enter the pin code. The default | + | - The first time you attempt to connect the phone will ask to pair with the Victron product. Enter the PIN code. The default |
- | - Connection | + | - The connection |
- | If connection was not successful please refer to section [[# | + | If the connection was not successful please refer to section [[# |
- | To prevent unauthorised connections to your device | + | To prevent unauthorised connections to your Victron product |
- | To change the PIN code, first complete your connection. Then go to the **Product info** page. To access that page, click the button on the upper right. For some products it will be the settings icon: {{: | + | To change the PIN code, first, complete your connection. Then go to the **Product info** page. To access that page, click the button on the upper right. For some products, it will be the settings icon: {{: |
- | Note that after changing the pin code, all other phones, tablets, and laptops | + | Note that after changing the PIN code, all other phones connected to the Victron product need to have their pairing information refreshed; and first, the old pairing information needs to be removed. See [[#3.4 Bluetooth Smart - Removing from the list of paired devices | section 3.4]] to learn how to remove the pairing information. |
Line 98: | Line 100: | ||
- | To remove the pairing information you will need to go to your device's Bluetooth settings. Watch the videos below to learn how to remove the pairing information from iOS and Android | + | To remove the pairing information you will need to go to your phone's Bluetooth settings. Watch the videos below to learn how to remove the pairing information from iOS and Android: |
- | === Remove Bluetooth pairing on iOS devices: === | + | === Remove Bluetooth pairing on iOS: === |
(click to play, double-click to enter fullscreen mode) | (click to play, double-click to enter fullscreen mode) | ||
{{victronconnect: | {{victronconnect: | ||
- | === Remove Bluetooth pairing on Android | + | === Remove Bluetooth pairing on Android: === |
Line 117: | Line 119: | ||
VictronConnect requires Windows 7, Windows 8 or Windows 10. For older Windows versions, XP and Vista, check our [[victronconnect: | VictronConnect requires Windows 7, Windows 8 or Windows 10. For older Windows versions, XP and Vista, check our [[victronconnect: | ||
- | Note that on Windows, VictronConnect cannot use Bluetooth Smart to connect to a product. Other connection methods, | + | Note that on Windows, VictronConnect cannot use Bluetooth Smart to connect to a product. Other connection methods, |
==== 4.2 macOS X === | ==== 4.2 macOS X === | ||
Line 126: | Line 128: | ||
To connect to a Victron product with Bluetooth, the Apple Laptop needs to have Bluetooth 4.0 aka Bluetooth Smart. | To connect to a Victron product with Bluetooth, the Apple Laptop needs to have Bluetooth 4.0 aka Bluetooth Smart. | ||
- | ==== 4.3 Android | + | ==== 4.3 Android === |
Android 5.0 is the minimum version required to run VictronConnect. | Android 5.0 is the minimum version required to run VictronConnect. | ||
Line 137: | Line 139: | ||
Android 5 devices with a 64bit CPU will experience a crash at startup due to an issue in the libraries we use to develop VictronConnect. This is not expected to be fixed. A workaround for this issue is to manually install the VictronConnect APK that can be downloaded in the [[https:// | Android 5 devices with a 64bit CPU will experience a crash at startup due to an issue in the libraries we use to develop VictronConnect. This is not expected to be fixed. A workaround for this issue is to manually install the VictronConnect APK that can be downloaded in the [[https:// | ||
- | The pairing does not work on some devices | + | The pairing does not work on some phones |
- | Unfortunately this is a bug in Android over which we have no control, and are therefore unable to fix. | + | Unfortunately, this is a bug in Android over which we have no control, and are therefore unable to fix. |
Line 152: | Line 154: | ||
=== Why is Access to location services required? === | === Why is Access to location services required? === | ||
- | Being sensitive to privacy issues at Victron ourselves, we are not happy with this requirement. But there is nothing we can do about it unfortunately. More information about why its needed to enable the location services is [[https:// | + | Being sensitive to privacy issues at Victron ourselves, we are not happy with this requirement. But there is nothing we can do about it, unfortunately. More information about why it is needed to enable the location services is [[https:// |
Line 178: | Line 180: | ||
VictronConnect works on the following iPhones and iPads running iOS 11 or later: | VictronConnect works on the following iPhones and iPads running iOS 11 or later: | ||
Line 194: | Line 196: | ||
==== 4.6 Archive of previous versions ==== | ==== 4.6 Archive of previous versions ==== | ||
- | It would be nice to forever support all existing versions of Android, iOS, Windows and other systems. But unfortunately | + | It would be nice to forever support all existing versions of Android, iOS, Windows, and other systems. But unfortunately, it is impossible to do so. Therefore, now and then, a new release of VictronConnect doesn' |
- | In such situation, we recommend | + | In such a situation, we recommend |
- | **Warning: | + | **Warning: |
|**OS Version** | **Download link** | | |**OS Version** | **Download link** | | ||
Line 214: | Line 216: | ||
- | LOCAL - This page shows all the Victron products that have been discovered by your device, and to which a connection can be made. Click on the desired product. | + | LOCAL - This page shows all the Victron products that have been discovered by your phone, and to which a connection can be made. Click on the desired product. |
- | VRM - This page will show a GX device | + | VRM - This page will show a GX product |
From ' | From ' | ||
Line 239: | Line 241: | ||
Line 254: | Line 256: | ||
Line 263: | Line 265: | ||
- | The ' | + | The ' |
Line 276: | Line 278: | ||
Line 289: | Line 291: | ||
Line 295: | Line 297: | ||
Line 316: | Line 318: | ||
{{youtube> | {{youtube> | ||
Line 331: | Line 333: | ||
==== 5.4 How to disable and re-enable Bluetooth ==== | ==== 5.4 How to disable and re-enable Bluetooth ==== | ||
- | All our products that have Bluetooth built-in, have a feature that allows disabling Bluetooth. Typically the reason for doing so is security, even though the Bluetooth connection is protected by a PINcode, there is nothing more secure than disabling it. | + | All our products that have Bluetooth built-in, have a feature that allows disabling Bluetooth. Typically the reason for doing so is security, even though the Bluetooth connection is protected by a PIN code, there is nothing more secure than disabling it. |
In most cases, it's also possible to re-enable Bluetooth after disabling. For example by using a VE.Direct cable. | In most cases, it's also possible to re-enable Bluetooth after disabling. For example by using a VE.Direct cable. | ||
There are, however, a few exceptions: | There are, however, a few exceptions: | ||
+ | * The [[# | ||
+ | * The [[# | ||
- | __Blue Smart IP67 Charger__ | + | === Finding the Bluetooth menu === |
- | The Blue Smart IP67 Charger range allows two options: | + | First, complete your connection; then go to the **Product info** page by clicking the button on the upper right: |
- | * Disable Bluetooth **permanently**. This option is **irreversible** and VictronConnect will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth, enter the code displayed and choose " | + | |
- | * Enable Bluetooth at power-up and disable it after 30 seconds | + | |
- | __Lithium Smart batteries__ | + | |
- | Once Bluetooth is disabled, it is disabled **permanently** and is **irreversible**. This means that VictronConnect will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth, enter the code displayed and choose " | + | |
- | === Finding the bluetooth menu === | + | |
- | First complete your connection; then go to the **Product info** page by clicking the button on the upper right: | + | |
* For some products, it will be the settings icon: {{: | * For some products, it will be the settings icon: {{: | ||
Line 356: | Line 350: | ||
If the product has the feature that Bluetooth can be disabled, you will see the field " | If the product has the feature that Bluetooth can be disabled, you will see the field " | ||
- | For some products a Disable button is shown instead of a toggle switch. | + | For some products, a Disable button is shown instead of a toggle switch. |
=== How to re-enable Bluetooth === | === How to re-enable Bluetooth === | ||
There are a few different ways to re-enable Bluetooth depending on your product, always check the manual of your product for more detailed instructions: | There are a few different ways to re-enable Bluetooth depending on your product, always check the manual of your product for more detailed instructions: | ||
Line 366: | Line 360: | ||
== Re-enable Bluetooth using VE.Direct == | == Re-enable Bluetooth using VE.Direct == | ||
- | Connect the product with a VE.Direct to USB cable to your PC or Android device | + | Connect the product with a VE.Direct to USB cable to your phone and use VictronConnect to re-enable Bluetooth in the **Product Info** page (see [[# |
== Re-enable Bluetooth using the MODE button on the product == | == Re-enable Bluetooth using the MODE button on the product == | ||
Line 372: | Line 366: | ||
Press and hold the MODE button on the product for 10 seconds will perform a Bluetooth reset. This means that the following actions will be executed: | Press and hold the MODE button on the product for 10 seconds will perform a Bluetooth reset. This means that the following actions will be executed: | ||
* Bluetooth will be re-enabled | * Bluetooth will be re-enabled | ||
- | * The connected Bluetooth | + | * The connected Bluetooth |
- | * The PIN code is reset to its [[victronconnect: | + | * The PIN code is reset to its [[# |
- | * The pairing information is cleared; this requires [[victronconnect: | + | * The pairing information is cleared; this requires [[victronconnect: |
- | **[[https:// | + | == Lithium Smart batteries == |
+ | The product page can be found [[https:// | ||
+ | Once Bluetooth is disabled, it is disabled | ||
+ | == Phoenix Smart IP43 Chargers == | ||
Once Bluetooth is disabled, there are multiple ways to re-enable it again: | Once Bluetooth is disabled, there are multiple ways to re-enable it again: | ||
- | - Using the MODE button. See below. | + | - Using the [[# |
- | - Connect the product with a VE.Direct to USB cable to your PC or Android device and use VictronConnect to re-enable Bluetooth in the **Product Info** page (see instructions above on how to reach the Product info page). | + | - Using a [[# |
- | **[[https:// | + | == Blue Smart IP22 Chargers == |
+ | Once Bluetooth is disabled, it can be re-enabled with the [[# | ||
- | **[[https:// | + | == Blue Smart IP65 Chargers == |
- | - Temporarily enabled at power-up for 30s: You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | + | The product page can be found [[https:// |
- | - Permanently disabled: __Once | + | Once Bluetooth is disabled, it can be re-enabled |
- | **[[https:// | + | == Blue Smart IP67 Chargers == |
+ | For these chargers there are two options: | ||
+ | * Enable Bluetooth for 30 seconds at power-up. This allows you to connect | ||
- | **Smart Battery Protect:** Bluetooth can be disabled/re-enabled by connecting | + | == SmartSolar MPPTs == |
- | selecting **F** (enable) or **h** (disable). Check the product manual for more details. | + | The product page can be found [[https:// |
+ | Bluetooth can be re-enabled by connecting | ||
- | **Smart | + | **Smart |
- | through | + | The product page can be found [[https:// |
+ | Bluetooth can be disabled/ | ||
+ | The BMV-712's onboard | ||
- | **Smart Shunt**: Bluetooth can be re-enabled | + | **Smart BMS**\\ |
+ | Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | ||
+ | **Smart Shunt**\\ | ||
+ | Bluetooth can be re-enabled | ||
==== 5.5 Importing and converting a GX Product Family database File ==== | ==== 5.5 Importing and converting a GX Product Family database File ==== | ||
- | VictronConnect for Mac OSX and Windows allows you to import and convert the database log file (that is created by the VenusOS on the GX Product Family | + | VictronConnect for Mac OSX and Windows allows you to import and convert the database log file (that is created by the VenusOS on the GX Product Family) to a Microsoft Excel XLSX file. This can be useful if the site is remote and without an internet connection to upload the file to the [[https:// |
Line 417: | Line 432: | ||
===== 7. Settings files ===== | ===== 7. Settings files ===== | ||
+ | ==== 7.1 Save, load, share and manage settings ==== | ||
This feature allows you to save product settings to a file so that they can be loaded onto the Victron product you are connected to ...or another product, at a later time. | This feature allows you to save product settings to a file so that they can be loaded onto the Victron product you are connected to ...or another product, at a later time. | ||
Line 422: | Line 439: | ||
Line 429: | Line 446: | ||
- | When the file is loaded the changes | + | When the file is loaded, the changes |
Line 440: | Line 457: | ||
** Settings file manager ** | ** Settings file manager ** | ||
- | The Settings file manager is located in the main menu. | + | The Settings file manager is located in the main menu, and shows all stored settings: |
- | From here files can be opened, shared or removed. | + | From here files can be opened, shared or removed: |
- | ** Open settings file ** | ||
- | When opening a file from the settings file manager | + | ==== 7.2 Settings files and the demo library ==== |
+ | The demo library can be a great tool for an installer to create a set of settings, and then share it to a customer whom can then apply it to their product. | ||
+ | Note that whilst saving settings from the demo library is possible, loading settings from within the demo library is not possible. | ||
+ | ==== 7.3 Limitation in opening | ||
+ | There are two methods to open a previously stored settings-file: | ||
+ | - From the settings file manager, as in the above screenshot, to see the settings without having to be connected to the product. A snapshot of all data, including voltage readings, history data, and so forth, will be loaded and visible to inspect. | ||
+ | - From the product | ||
- | There is a constraint for opening files in this mode: The settings file must have been created | + | Note that the first method only works when the settings file is created |
- | This constraint only applies when opening files from the settings file manager for inspection. Loading files from a product settings page to restore it is always possible as long as VictronConnect version is equal or greater | ||
===== 8. Demo feature ===== | ===== 8. Demo feature ===== | ||
Line 467: | Line 493: | ||
Line 479: | Line 505: | ||
Line 485: | Line 511: | ||
- | __What about updating Firmware on VE.Bus | + | __What about updating Firmware on VE.Bus |
Please follow this [[https:// | Please follow this [[https:// | ||
Line 491: | Line 517: | ||
- | A firmware update - when available - will need to be completed in order to continue | + | If an update is available but is not mandatory, you will be able to see your product' |
+ | A firmware update - when available - will need to be completed in order to change settings on your Victron product | ||
__Will I need to reconfigure my MPPT or BMV after the update?__ | __Will I need to reconfigure my MPPT or BMV after the update?__ | ||
Line 511: | Line 541: | ||
Line 528: | Line 560: | ||
Line 545: | Line 578: | ||
- | Go to the " | + | |
Line 571: | Line 602: | ||
In spite of our painstaking efforts, sometimes errors occur. But don't worry, it is always possible to recover your product. | In spite of our painstaking efforts, sometimes errors occur. But don't worry, it is always possible to recover your product. | ||
- | In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible and check that the Bluetooth function is enabled on your phone/ | + | In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible and check that the Bluetooth function is enabled on your phone. |
- | Sometimes you may need to [[# | + | Sometimes you may need to [[# |
In the following list, you can check possible errors and descriptions. | In the following list, you can check possible errors and descriptions. | ||
Line 713: | Line 744: | ||
==== 10.1 Introduction ==== | ==== 10.1 Introduction ==== | ||
- | VictronConnect-Remote functionality enables Victron | + | VictronConnect-Remote functionality enables Victron |
- | This powerful | + | This powerful feature allows full product |
+ | The user interface experience is just like the products were connected locally using Bluetooth or a wired VE.Direct to USB interface. | ||
+ | A video demonstrating the feature is available here: | ||
+ | {{youtube> | ||
- | The user interface experience is just like the devices were connected locally using Bluetooth or a wired VE.Direct to USB interface. | ||
==== 10.2 Compatibility ==== | ==== 10.2 Compatibility ==== | ||
- | The VictronConnect-Remote feature is ONLY compatible with devices | + | The VictronConnect-Remote feature is ONLY compatible with products |
This includes; | This includes; | ||
Line 729: | Line 764: | ||
* Specific mains chargers with a VE.Direct interface (Phoenix Smart IP43) | * Specific mains chargers with a VE.Direct interface (Phoenix Smart IP43) | ||
- | Devices | + | Products |
==== 10.3 Setup ==== | ==== 10.3 Setup ==== | ||
Line 738: | Line 773: | ||
* VictronConnect SW: v5.20 | * VictronConnect SW: v5.20 | ||
- | * GX Device | + | * GX Product- Venus OS FW: v2.40 (However v2.53 recommended for full functionality) |
=== 10.3.2 VictronConnect === | === 10.3.2 VictronConnect === | ||
- | - Confirm that the phone, tablet or PC has VictronConnect installed and that the software version meets or exceeds the minimum requirements - upgrade if necessary | + | - Confirm that the phone has VictronConnect installed and that the software version meets or exceeds the minimum requirements - upgrade if necessary |
- Authorize VictronConnect to access your VRM account; | - Authorize VictronConnect to access your VRM account; | ||
* Open the VictronConnect app | * Open the VictronConnect app | ||
Line 751: | Line 786: | ||
- | * If using a tablet or PC your browser may also request permission to proceed, if prompted select ‘Open’ | + | * If using a tablet or PC your browser may also request permission to open VictronConnect, if prompted select ‘Open’ |
- | === 10.3.3 GX Device | + | === 10.3.3 GX Product |
- | 1- Confirm that the GX Device | + | 1- Confirm that the GX Product |
2- Enable ‘VRM two-way communication’ under Device List > Settings > VRM Online Portal | 2- Enable ‘VRM two-way communication’ under Device List > Settings > VRM Online Portal | ||
==== 10.4 Local Tab ==== | ==== 10.4 Local Tab ==== | ||
- | The local tab displays all devices | + | The local tab displays all products |
Line 772: | Line 807: | ||
The VRM tab displays all VRM installations associated with the VRM user profile. | The VRM tab displays all VRM installations associated with the VRM user profile. | ||
- | Any installation can be selected to access the VRM online portal or connected | + | Any installation can be selected to access the VRM online portal or connected |
Line 780: | Line 815: | ||
=== 10.5.1 Overview Tab === | === 10.5.1 Overview Tab === | ||
- | The ‘OVERVIEW’ tab has an image of the GX device, the name of the VRM installation and a direct link to the associated [[https:// | + | The ‘OVERVIEW’ tab has an image of the GX product, the name of the VRM installation, and a direct link to the associated [[https:// |
Line 787: | Line 822: | ||
=== 10.5.2 Devices Tab === | === 10.5.2 Devices Tab === | ||
- | The ‘DEVICES’ tab has a list of all compatible | + | The ‘DEVICES’ tab has a list of all compatible |
Line 795: | Line 830: | ||
- | ==== 10.6 Remote | + | ==== 10.6 Remote |
- | When a device | + | When a product |
Line 825: | Line 860: | ||
==== 10.8 Troubleshooting and FAQ ==== | ==== 10.8 Troubleshooting and FAQ ==== | ||
- | == Device | + | == Product |
- | * VictronConnect-Remote is only compatible with devices | + | * VictronConnect-Remote is only compatible with products |
- | * Ensure that that the missing | + | * Ensure that that the missing |
- | * Ensure that the device | + | * Ensure that the product |
- | == Installation/ | + | == Installation/ |
* Confirm that the installation is currently online and communicating with the VRM online portal. | * Confirm that the installation is currently online and communicating with the VRM online portal. | ||
* Ensure that the installation is linked to the VRM account used during initial VictronConnect-Remote sign in to VRM. | * Ensure that the installation is linked to the VRM account used during initial VictronConnect-Remote sign in to VRM. | ||
* Ensure that ‘VRM two-way communication’ is enabled – see the ‘settings’ section. | * Ensure that ‘VRM two-way communication’ is enabled – see the ‘settings’ section. | ||
- | * Ensure that the GX device | + | * Ensure that the GX product |
== VictronConnect has no VRM tab == | == VictronConnect has no VRM tab == | ||
- | * Ensure that the phone, tablet or PC is running the minimum compatible VictronConnect software version – see the ‘settings’ section. | + | * Ensure that the phone is running the minimum compatible VictronConnect software version – see the ‘settings’ section. |
== VRM account == | == VRM account == | ||
Line 847: | Line 882: | ||
* For further information in relation to VRM (Victron Remote Management) see [[https:// | * For further information in relation to VRM (Victron Remote Management) see [[https:// | ||
- | == Systems with no GX device | + | == Systems with no GX product |
- | * VictronConnect-Remote functionality is not possible unless the system includes a GX device. A GX device | + | * VictronConnect-Remote functionality is not possible unless the system includes a GX product. A GX product |
== Installations with no internet connection == | == Installations with no internet connection == | ||
- | * VictronConnect-Remote functionality is not possible unless GX device | + | * VictronConnect-Remote functionality is not possible unless |
- | * For remote sites without an existing internet connection or with mobile installations, | + | * For remote sites without an existing internet connection or with mobile installations, |
== Large systems == | == Large systems == | ||
- | * The use of the VictronConnect-Remote feature will slightly increase the GX device | + | * The use of the VictronConnect-Remote feature will slightly increase the GX product |
- | * In some large/ | + | * In some large/ |
- | * It is important to select a GX device | + | * It is important to select a GX product |
+ | == VictronConnect Remote troubleshooting == | ||
+ | VictronConnect will report errors encountered during communication attempts with VRM in a message box with an error code (e.g. #R999, or #V2). The numeric part of the code can have one of the following value: | ||
+ | ^Error ^Description^ | ||
+ | |999 | Call to retrieve a list of child devices expired (60 seconds). The most common cause is a bad internet connection. | | ||
+ | | 1 | No link to VRM can be established. Check if the internet is present and try again. | | ||
+ | | 2 | VRM encountered temporary difficulties. Try again in a while. It could also indicate issues with your credentials. | | ||
+ | | 3 | Error accessing network. Please check your network connection. | | ||
+ | | 8 | An error occurred with the network (e.g., the network cable was accidentally plugged out). | | ||
+ | | 13 | Proxy authentication error. VictronConnect does not support communication over proxy. | | ||
+ | | 14 | Failed to establish a secure connection to VRM. | | ||
+ | |65538| VRM MQTT broker is not responding. Please try again in a while. | | ||
+ | There are also other error codes that could be reported. They are a result of internal errors in VictronConnect and/or VRM. In case these errors persist after a retry, please create a " | ||
+ | VictronConnect Remote is establishing communication with a range of services on the ' | ||
===== 11. Troubleshooting ===== | ===== 11. Troubleshooting ===== | ||
Line 867: | Line 920: | ||
==== 11.1 Common Bluetooth problems and how to solve them === | ==== 11.1 Common Bluetooth problems and how to solve them === | ||
- | The first step before attempting any of the specific troubleshooting advice below is to power down and then restart all related devices, (this includes | + | The #1 first step before attempting any of the specific troubleshooting advice below is to power down and then restart all related devices. This includes |
- | == I cannot find my device | + | For example, with Victron MPPTs you must isolate the MPPT from both battery and solar voltage so that no lights appear, before reconnecting it again. |
+ | == I cannot find my product | ||
- | * Make sure your device | + | * Make sure your product |
- | * If a firmware update failed, the device | + | * If a firmware update failed, the product |
- | * Only one device | + | * Only one phone can be connected to a product at the same time. Make sure that no other phone is already connected. |
- | * Make sure you are attempting to connect from //within// VictronConnect - not from the system menu of your phone/ | + | * Make sure you are attempting to connect from //within// VictronConnect - not from the system menu of your phone. If you have connected from the system menu: close VictronConnect, |
- | == I can see but not connect to my device | + | == I can see but not connect to my product |
- | - Make sure you are trying to connect to the right device. See [[start# | + | - Make sure you are trying to connect to the right product. See [[start# |
- | - Make sure your device | + | - Make sure your product |
- | - Make sure that Bluetooth is still enabled | + | - Make sure that Bluetooth is still enabled |
- | - The Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the device, or if your Victron | + | - Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the product, or if your Victron |
- | - If you are using an Android phone/tablet, check [[start# | + | - If you are using an Android phone, check [[start# |
=== Connection fails around 20% === | === Connection fails around 20% === | ||
- | 1. Make sure you are up to date with the latest version of VictronConnect. | + | - Make sure you are up to date with the latest version of VictronConnect. |
+ | - [[https:// | ||
+ | - Then [[https:// | ||
+ | - Force close the VictronConnect app. Instructions: | ||
+ | - Reconnecting in VictronConnect using the default PIN 000000 | ||
- | 2. [[https:// | + | ==== 11.2 Bluetooth |
- | 3. Then [[https:// | + | === Step 1: Check that your phone is supported === |
- | 4. Force close the VictronConnect app, and then try reconnecting in VictronConnect using the default PIN 000000 | + | See section [[# |
- | ==== 11.2 Bluetooth connection issues on Android devices ==== | + | |
- | See section [[# | + | |
=== Step 2: Check the Android version === | === Step 2: Check the Android version === | ||
Line 908: | Line 961: | ||
- | On Android 5 and later VictronConnect needs access to the device | + | On Android 5 and later VictronConnect needs access to the phone' |
Line 914: | Line 967: | ||
=== Step 4. Enable Location (or GPS) functionality in the system settings === | === Step 4. Enable Location (or GPS) functionality in the system settings === | ||
- | For Bluetooth scanning to work, the Location (or GPS) functionality on the device | + | For Bluetooth scanning to work, the Location (or GPS) functionality on the phone needs to be enabled. |
- | === Step 5. Search & connect from within VictronConnect | + | === Step 5. Search & connect from within VictronConnect, and NOT from the system Bluetooth menu === |
=== Step 6. Pin-code pop-up never shows === | === Step 6. Pin-code pop-up never shows === | ||
- | On some Android phones, the pin-code pop-up dialog doesn' | + | On some Android phones, the PIN code pop-up dialog doesn' |
Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code. | Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code. | ||
+ | On Android it is also possible that other apps prevent the PIN code pop-up from showing, even when pairing in the Android Bluetooth settings menu. One such an app is "FrSky Free Link", which even blocks pairing with Bluetooth headsets. In this case, the thing to do is remove the problematic app. This can be done by uninstalling apps one by one (starting with apps that use or connect to Bluetooth devices), removing all apps or even resetting the phone to factory defaults. When the Victron products are paired to the phone/ | ||
The default pin-code is 000000, six times zero. | The default pin-code is 000000, six times zero. | ||
=== Step 7. Try another phone at first === | === Step 7. Try another phone at first === | ||
- | If you are still experiencing difficulties, | + | If you are still experiencing difficulties, |
+ | When successfully connected using another phone, VictronConnect will automatically update the firmware in the Victron Bluetooth product. After the firmware has been updated you may find that you can use the Android phone with which you were experiencing difficulties. | ||
- | When successfully connected using another device, VictronConnect will automatically update the firmware in the Victron Bluetooth device. After the firmware has been updated you may find that you can use the Android device with which you were experiencing difficulties. | ||
==== 11.3 Problems during firmware updating ==== | ==== 11.3 Problems during firmware updating ==== | ||
First of all, it's good to know that you can always restart the firmware update procedure. The update process will be restarted each time you connect to the product. | First of all, it's good to know that you can always restart the firmware update procedure. The update process will be restarted each time you connect to the product. | ||
- | Keep your mobile device | + | Keep your phone as close to the product as possible. If the update fails due to Bluetooth connectivity problems, and if your phone is already paired to a product, try and remove the pairing completely from your phone' |
- | Watch these instructional videos to learn how to remove the pairing on {{ : | + | Watch these instructional videos to learn how to remove the pairing on {{ : |
- | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. If the update fails even after many attempts, try using another phone or tablet | + | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. If the update fails even after many attempts, try using another phone or tablet, if possible an Apple iOS phone - they usually work without any issues. After the update, you may find that you can use the phone with which you were having difficulty. |
- | When the firmware update fails at 4% or less, VictronConnect cannot make the device | + | When the firmware update fails at 4% or less, VictronConnect cannot make the product |
__ Solution for Blue Smart IP65 Chargers __ | __ Solution for Blue Smart IP65 Chargers __ | ||
Line 981: | Line 1038: | ||
- | ==== 11.5 VictronConnect on Windows doesn' | + | ==== 11.5 VictronConnect on Windows doesn' |
Line 997: | Line 1054: | ||
If you are experiencing issues with VictronConnect or your Victron product, you may be asked to create a " | If you are experiencing issues with VictronConnect or your Victron product, you may be asked to create a " | ||
+ | Please note that this service report is for Victron internal use and is not able to be read or used for any other purpose than developer troubleshooting. | ||
To do this, | To do this, | ||
Line 1006: | Line 1064: | ||
- Select Settings | - Select Settings | ||
- Click or tap CREATE SERVICE REPORT | - Click or tap CREATE SERVICE REPORT | ||
- | - Save, email or copy the file to Victron, via email or the Victron Community. | + | - Save, email, or copy the file to Victron, via email or the Victron Community. |
+ | If you require more detailed power system diagnostic information, | ||
==== 11.8 VE.Bus firmware update fails at 5% on macOS ==== | ==== 11.8 VE.Bus firmware update fails at 5% on macOS ==== | ||
Line 1148: | Line 1207: | ||
- | This section applies to MultiPlus, MultiPlus-II, | + | This section applies to MultiPlus, MultiPlus-II, |
- | In order to keep this section short, all these devices | + | In order to keep this section short, all these products |
- | The minimal required version of the VE.Bus | + | The minimal required version of the VE.Bus |
Line 1165: | Line 1224: | ||
