victronconnect:start
victronconnect:start [2020-03-20 04:53] – [10.1 Common Bluetooth problems and how to solve them] guy_stewart | victronconnect:start [2020-04-05 13:07] – [5.1 Screenshots (click to enlarge)] jono | ||
Line 135: | Line 135: | ||
=== Notes for Android 5 === | === Notes for Android 5 === | ||
+ | Android 5 devices with a 64bit CPU will experience a crash at startup due to an issue in the libraries we use to develop VictronConnect. This is not expected to be fixed. A workaround for this issue is to manually install the VictronConnect APK that can be downloaded in the [[https:// | ||
The pairing does not work on some devices running Android 5. The pin code popup does not appear, or it appears without a text field to enter the PIN code. If you have this situation on your device, the phone/ | The pairing does not work on some devices running Android 5. The pin code popup does not appear, or it appears without a text field to enter the PIN code. If you have this situation on your device, the phone/ | ||
Line 212: | Line 214: | ||
- | This page shows all the Victron products that have been discovered by your device, and to which a connection can be made. Click on the desired product. | ||
- | {{: | + | LOCAL - This page shows all the Victron products that have been discovered by your device, and to which a connection can be made. Click on the desired product. |
+ | VRM - This page will show a GX device if it is connected to your VRM account. | ||
**Battery Monitor pages**:\\ | **Battery Monitor pages**:\\ |
