victronconnect:start
victronconnect:start [2020-03-20 04:53] – [10.1 Common Bluetooth problems and how to solve them] guy_stewart | victronconnect:start [2020-03-24 13:16] – [4.3 Android devices] jperez | ||
Line 135: | Line 135: | ||
=== Notes for Android 5 === | === Notes for Android 5 === | ||
+ | Android 5 devices with a 64bit CPU will experience a crash at startup due to an issue in the libraries we use to develop VictronConnect. This is not expected to be fixed. A workaround for this issue is to manually install the VictronConnect APK that can be downloaded in the [[https:// | ||
The pairing does not work on some devices running Android 5. The pin code popup does not appear, or it appears without a text field to enter the PIN code. If you have this situation on your device, the phone/ | The pairing does not work on some devices running Android 5. The pin code popup does not appear, or it appears without a text field to enter the PIN code. If you have this situation on your device, the phone/ | ||
