victronconnect:start
victronconnect:start [2020-02-14 09:17] – [Battery Chargers] mbosma | victronconnect:start [2020-10-27 14:40] – marmour | ||
- | Welcome | + | |
- | [[https:// | + | |
- | See [[# | + | |
- | ^ Method | + | |
- | | [[ve.direct: | + | |
- | | [[https:// | + | |
- | Use the [[# | + | |
- | {{victronconnect: | + | |
- | | Huawei | + | |
- | | Lenovo | + | |
- | | Samsung | + | |
- | ==== 4.5 Archive of previous versions ==== | + | |
- | **Warning: | + | |
- | **Device list**\\ | + | |
- | Clicking on ' | + | |
- | *To access ' | + | |
- | From ' | + | |
- | The ' | + | |
- | From ' | + | |
- | **Windows**\\ | + | |
- | **macOS X**\\ | + | |
- | {{youtube> | + | |
- | ==== 5.4 How to disable Bluetooth ==== | + | |
- | All our products that have Bluetooth built-in, have a feature that allows disabling Bluetooth. Typically the reason for doing so is security, nothing more secure than disabling it. For example on unmanned roadside backup power stations; or other more large scale deployments. | + | |
- | In most cases, it's also possible to re-enable Bluetooth after disabling. For example by using a VE.Direct cable. The only exception is the Lithium Smart batteries: once Bluetooth is disabled on them, it is disabled forever. | + | |
- | Here is how to disable Bluetooth: First complete your connection; then go to the **Product info** page. To access that page, click the button on the upper right. For some products, it will be the settings icon: {{: | + | |
- | If the product supports turning Bluetooth off, you will see the field " | + | |
- | For **most** of our products, Bluetooth can be re-enabled (see below how to re-enabled it), but for our Lithium Smart batteries this change is **__permanent__** and you'll be asked to enter a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth just enter the code displayed and choose " | + | |
- | == How to re-enable Bluetooth == | + | |
- | **Via VE.Direct: | + | |
- | **[[https:// | + | |
- | - Temporarily enabled at power-up for 30s: You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | + | |
- | - Permanently disabled: __Once Bluetooth is disabled, it can not be re-enabled.__ | + | |
- | **Chargers with a MODE button:** | + | |
- | Press and hold the MODE button for 10s will reset Bluetooth: | + | |
- | - Reset PIN code | + | |
- | - Clear bonding information | + | |
- | - Blue Smart IP22 | + | |
- | - Blue Smart IP65 | + | |
- | **Smart Battery Protect:** Bluetooth can be disabled/ | + | |
- | selecting **F** (enable) or **h** (disable). Check the product manual for more details. | + | |
- | **Smart BMV-712:** The BMV-712' | + | |
- | through the settings menu. Check the product manual for more details. | + | |
- | **Smart BMS:** Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | + | |
- | Go to the " | + | |
- | Check [[# | + | |
- | ^Error | + | |
- | ==== 10.1 Common Bluetooth problems and how to solve them === | + | |
- | 2. [[https:// | + | |
- | ==== 10.2 Bluetooth connection issues on Android devices ==== | + | |
- | See section [[# | + | |
- | ==== 10.4 VE.Direct USB driver problem on macOS X 10.9 (Mavericks) ==== | + | |
- | cd / | + | |
- | http:// | + | |
- | ==== 10.5 VictronConnect on Windows doesn' | + | |
- | ==== 10.6 VictronConnect on Android doesn' | + | |
- | ==== 10.7 How to create a VictronConnect Service Report ==== | + | |
- | To do this, | + | |
- | - Select Settings | + | |
- | ==== 10.8 VE.Bus firmware update fails at 5% on macOS ==== | + | |
- | ===== 11. Compatible Victron products ===== | + | |
- | | MPPT 100/ | + | |
- | | MPPT 150/ | + | |
- | | BMV-700 | + | |
- | | BMV-702 | + | |
- | | BMV-712 | + | |
- | Inverter/ | + | |
