victronconnect:start
victronconnect:start [2020-02-04 12:00] – [IMPULSE-II Smart Charger] mbosma | victronconnect:start [2020-02-14 09:17] – [Battery Chargers] mbosma | ||
Line 347: | Line 347: | ||
**Via VE.Direct: | **Via VE.Direct: | ||
- | **[[https:// | + | **[[https:// |
+ | **[[https:// | ||
+ | - Temporarily enabled at power-up for 30s: You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | ||
+ | - Permanently disabled: __Once Bluetooth is disabled, it can not be re-enabled.__ | ||
**[[https:// | **[[https:// | ||
Line 837: | Line 843: | ||
(1) For those with a technical background and wondering how, why and what minimising has to do with this: yes this really works, and relates to a power saving mode that has a side effect on serial communication. | (1) For those with a technical background and wondering how, why and what minimising has to do with this: yes this really works, and relates to a power saving mode that has a side effect on serial communication. | ||
===== 11. Compatible Victron products ===== | ===== 11. Compatible Victron products ===== | ||
- | ==== SmartSolar MPPT Charge controllers | + | ==== Solar Chargers ==== |
+ | === SmartSolar MPPT Charge controllers === | ||
^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | ^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | ||
| MPPT 75/10 | [[https:// | | MPPT 75/10 | [[https:// | ||
Line 866: | Line 875: | ||
The same models, but then with a different part number do support using both the VE.Direct port and the built-in Bluetooth Smart function at the same time. As do all other SmartSolar MPPT models. | The same models, but then with a different part number do support using both the VE.Direct port and the built-in Bluetooth Smart function at the same time. As do all other SmartSolar MPPT models. | ||
- | ==== Blue Smart IP22 Chargers ==== | + | === BlueSolar MPPT Charge controllers === |
- | ^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Charge cycle history ^ Advanced settings ^ | + | |
- | | All Blue Smart IP22 Chargers | No | Yes - Built in | No | No | | + | |
- | | Other Blue Smart IP65 Chargers | No | Yes - Built in | No | No | | + | |
- | ==== Phoenix Smart IP43 Charger ==== | + | |
- | | All Phoenix Smart IP43 Chargers | + | |
- | ==== IMPULSE-II Smart Charger ==== | + | |
- | | BMV-700 | + | |
- | | BMV-702 | + | |
- | | BMV-712 | + | |
- | ==== BlueSolar MPPT Charge controllers | + | |
| MPPT 70/15 | Not compatible || | | MPPT 70/15 | Not compatible || | ||
Line 919: | Line 894: | ||
+ | ==== Battery Chargers ==== | ||
+ | ^ Blue Smart IP22 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All Blue Smart IP22 Chargers | ||
+ | ^ Blue Smart IP65 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | Blue Smart IP65 12/25 Charger | ||
+ | | Blue Smart IP65 24/13 Charger | ||
+ | | Other Blue Smart IP65 Chargers | ||
+ | ^ Blue Smart IP67 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All Blue Smart IP67 Chargers | ||
+ | ^ Phoenix Smart IP43 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All Phoenix Smart IP43 Chargers | Yes | Yes - Built in | Yes | No | No | | ||
+ | ^ IMPULSE-II Smart ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All IMPULSE-II Smart Chargers | ||
+ | | BMV-700 | ||
+ | | BMV-702 | ||
+ | | BMV-712 | ||
Line 970: | Line 970: | ||
This section applies to MultiPlus, MultiPlus-II, | This section applies to MultiPlus, MultiPlus-II, | ||
