victronconnect:start [2019-12-20 16:17] – [10.6 VictronConnect on Android doesn't show files oppened from email or file manager apps] marmour | victronconnect:start [2020-01-22 15:32] – [5.4 How to disable Bluetooth] guy_stewart |
| Android 4.3 to 4.4.4 x86 architecture | [[https://www.victronenergy.com/upload/software/VictronConnect-v5.8-x86.apk|VictronConnect 5.8]] | | | Android 4.3 to 4.4.4 x86 architecture | [[https://www.victronenergy.com/upload/software/VictronConnect-v5.8-x86.apk|VictronConnect 5.8]] | |
| macOS 10.9 (OS X Mavericks) | [[https://nocache.victronenergy.com/upload/software/VictronConnect-3.2.dmg|VictronConnect 3.2]] | | | macOS 10.9 (OS X Mavericks) | [[https://nocache.victronenergy.com/upload/software/VictronConnect-3.2.dmg|VictronConnect 3.2]] | |
| | macOS 10.10, 10.11 & 10.12 (OS X Yosemite / Sierra) | [[https://www.victronenergy.com/upload/software/VictronConnect_v5.8.dmg|VictronConnect 5.8]] | |
**Via VE.Direct:** Connect the product with a VE.Direct to USB cable to your PC or Android device and use VictronConnect to re-enable Bluetooth in the **Product Info** page (see instructions above on how to reach the Product info page). | **Via VE.Direct:** Connect the product with a VE.Direct to USB cable to your PC or Android device and use VictronConnect to re-enable Bluetooth in the **Product Info** page (see instructions above on how to reach the Product info page). |
**Smart Chargers:** In all smart chargers, Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | **[[https://www.victronenergy.com/chargers|Blue and Phoenix Smart Chargers]]:** In all smart battery chargers, Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. |
//Chargers with a MODE button: // | **[[https://www.victronenergy.com/solar-charge-controllers|SmartSolar MPPTs]]:** Connect the product with a VE.Direct to USB cable to your PC or Android device and use VictronConnect to re-enable Bluetooth in the **Product Info** page (see instructions above on how to reach the Product info page). |
| **Chargers with a MODE button:** |
Press and hold the MODE button for 10s will reset Bluetooth: | Press and hold the MODE button for 10s will reset Bluetooth: |
- Disconnect active device | - Disconnect active device |
=== Connection fails around 20% === | === Connection fails around 20% === |
[[https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_removing_from_the_list_of_paired_devices|Remove the device from the paired devices list]] in the phones Bluetooth settings. [[https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_changing_the_pin_code|Then change the PIN code.]] | 1. Make sure you are up to date with the latest version of VictronConnect. |
| 2. [[https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_removing_from_the_list_of_paired_devices|Remove the device from the paired devices list]] in the phones Bluetooth settings. |
| 3. Then [[https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_resetting_the_pin_code|Reset the PIN code]]. |
| 4. Force close the VictronConnect app, and then try reconnecting in VictronConnect using the default PIN 000000 |
| 5. Then [[https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_changing_the_pin_code| change the PIN code.]] |
==== 10.2 Bluetooth connection issues on Android devices ==== | ==== 10.2 Bluetooth connection issues on Android devices ==== |
