victronconnect:start
victronconnect:start [2019-12-12 00:41] – [4.5 Archive of previous versions] jperez | victronconnect:start [2020-08-22 23:33] – [10.8 Troubleshooting and FAQ] nlakatos | ||
Line 6: | Line 6: | ||
VictronConnect is available for Android, iOS, Windows, and macOS X. | VictronConnect is available for Android, iOS, Windows, and macOS X. | ||
- | It can connect to Victron products via Bluetooth, USB and WiFi/ | + | It can connect to Victron products via Bluetooth, USB and WiFi/ |
Line 18: | Line 18: | ||
[[https:// | [[https:// | ||
===== 2. Download and installation ===== | ===== 2. Download and installation ===== | ||
- | VictronConnect is available to users of Windows PCs, macOS X, iOS and Android phones, as well as tablets. | + | VictronConnect is available to users of Windows PCs, macOS X, iOS and Android phones, as well as tablets. |
+ | Also, [[https:// | ||
- | See [[# | + | See [[# |
===== 3. Connecting ===== | ===== 3. Connecting ===== | ||
Line 28: | Line 32: | ||
There are three ways to connect to a Victron product: | There are three ways to connect to a Victron product: | ||
^ Method | ^ Method | ||
- | | Products with built-in | + | | Products with built-in |
| [[ve.direct: | | [[ve.direct: | ||
| [[https:// | | [[https:// | ||
Line 39: | Line 43: | ||
- | To connect to your Victron product, over Bluetooth, always connect from within VictronConnect. Do not connect from the device's system menu because VictronConnect will not find your Victron product. | + | To connect to your Victron product, over Bluetooth, always connect from within VictronConnect. Do not connect from the phone's system menu because VictronConnect will not find your Victron product. |
Here is how to connect: | Here is how to connect: | ||
- | - Enable the Bluetooth on your phone, tablet or laptop (device). | + | - Enable the Bluetooth on your phone. |
- Open VictronConnect, | - Open VictronConnect, | ||
- On a phone or tablet, pull down the screen, or tap the refresh button to initiate a scan. | - On a phone or tablet, pull down the screen, or tap the refresh button to initiate a scan. | ||
- On a computer or laptop: click the "Scan or Refresh" | - On a computer or laptop: click the "Scan or Refresh" | ||
- | - The first time you attempt to connect the phone will ask to pair with the device. Enter the pin code. The default | + | - The first time you attempt to connect the phone will ask to pair with the Victron product. Enter the PIN code. The default |
- | - Connection | + | - The connection |
- | If connection was not successful please refer to section [[# | + | If the connection was not successful please refer to section [[# |
- | To prevent unauthorised connections to your device | + | To prevent unauthorised connections to your Victron product |
- | To change the PIN code, first complete your connection. Then go to the **Product info** page. To access that page, click the button on the upper right. For some products it will be the settings icon: {{: | + | To change the PIN code, first, complete your connection. Then go to the **Product info** page. To access that page, click the button on the upper right. For some products, it will be the settings icon: {{: |
- | Note that after changing the pin code, all other phones, tablets, and laptops | + | Note that after changing the PIN code, all other phones connected to the Victron product need to have their pairing information refreshed; and first, the old pairing information needs to be removed. See [[#3.4 Bluetooth Smart - Removing from the list of paired devices | section 3.4]] to learn how to remove the pairing information. |
Line 75: | Line 79: | ||
=== Blue Smart Chargers IP22 === | === Blue Smart Chargers IP22 === | ||
- | On the device list: Press and hold the product description | + | On the device list: tap or click the three-dots menu on the right side of the product description. A menu will pop up offering a 'Reset PIN code' option. Click that, and enter the PUK code. The PUK code can be found on the product label, on the back of the product. |
It can also be done on the charger itself:\\ | It can also be done on the charger itself:\\ | ||
Line 83: | Line 85: | ||
=== Blue Smart Chargers IP67 === | === Blue Smart Chargers IP67 === | ||
=== Smart Solar Charger === | === Smart Solar Charger === | ||
=== BMV-712 Smart === | === BMV-712 Smart === | ||
=== Smart LiFePO4 Batteries === | === Smart LiFePO4 Batteries === | ||
+ | === SmartShunts === | ||
+ | On the device list: tap or click the three-dots menu on the right side of the product description. A menu will pop up offering a 'Reset PIN code' option. Click that, and enter the PUK code. The PUK code can be found on the product label, on the back of the product. | ||
- | To remove the pairing information you will need to go to your device's Bluetooth settings. Watch the videos below to learn how to remove the pairing information from iOS and Android | + | To remove the pairing information you will need to go to your phone's Bluetooth settings. Watch the videos below to learn how to remove the pairing information from iOS and Android: |
- | === Remove Bluetooth pairing on iOS devices: === | + | === Remove Bluetooth pairing on iOS: === |
(click to play, double-click to enter fullscreen mode) | (click to play, double-click to enter fullscreen mode) | ||
{{victronconnect: | {{victronconnect: | ||
- | === Remove Bluetooth pairing on Android | + | === Remove Bluetooth pairing on Android: === |
Line 123: | Line 119: | ||
VictronConnect requires Windows 7, Windows 8 or Windows 10. For older Windows versions, XP and Vista, check our [[victronconnect: | VictronConnect requires Windows 7, Windows 8 or Windows 10. For older Windows versions, XP and Vista, check our [[victronconnect: | ||
- | Note that on Windows, VictronConnect cannot use Bluetooth Smart to connect to a product. Other connection methods, | + | Note that on Windows, VictronConnect cannot use Bluetooth Smart to connect to a product. Other connection methods, |
==== 4.2 macOS X === | ==== 4.2 macOS X === | ||
Line 132: | Line 128: | ||
To connect to a Victron product with Bluetooth, the Apple Laptop needs to have Bluetooth 4.0 aka Bluetooth Smart. | To connect to a Victron product with Bluetooth, the Apple Laptop needs to have Bluetooth 4.0 aka Bluetooth Smart. | ||
- | ==== 4.3 Android | + | ==== 4.3 Android === |
Android 5.0 is the minimum version required to run VictronConnect. | Android 5.0 is the minimum version required to run VictronConnect. | ||
Line 141: | Line 137: | ||
=== Notes for Android 5 === | === Notes for Android 5 === | ||
- | The pairing does not work on some devices running | + | Android 5 devices with a 64bit CPU will experience a crash at startup due to an issue in the libraries we use to develop VictronConnect. This is not expected to be fixed. A workaround for this issue is to manually install |
- | Unfortunately this is a bug in Android over which we have no control, and are therefore unable to fix. | + | The pairing does not work on some phones running Android 5. The PIN code popup does not appear, or it appears without a text field to enter the PIN code. If you have this situation, your phone might report that it has been paired with the Victron product - but it has not. |
+ | Unfortunately, this is a bug in Android over which we have no control, and are therefore unable to fix. | ||
Line 156: | Line 154: | ||
=== Why is Access to location services required? === | === Why is Access to location services required? === | ||
- | Being sensitive to privacy issues at Victron ourselves, we are not happy with this requirement. But there is nothing we can do about it unfortunately. More information about why its needed to enable the location services is [[https:// | + | Being sensitive to privacy issues at Victron ourselves, we are not happy with this requirement. But there is nothing we can do about it, unfortunately. More information about why it is needed to enable the location services is [[https:// |
Line 182: | Line 180: | ||
VictronConnect works on the following iPhones and iPads running iOS 11 or later: | VictronConnect works on the following iPhones and iPads running iOS 11 or later: | ||
Line 192: | Line 190: | ||
Unfortunately Apple iPhone/iPad doesn' | Unfortunately Apple iPhone/iPad doesn' | ||
- | ==== 4.5 Archive of previous versions | + | ==== 4.5 Linux ==== |
- | It would be nice to forever support all existing versions of Android, iOS, Windows and other systems. But unfortunately its impossible to do so. Therefore, now and then, a new release of VictronConnect doesn' | + | Details [[https:// |
- | In such situation, we recommend to update your phone/ | + | ==== 4.6 Archive of previous |
- | **Warning: | + | It would be nice to forever support all existing versions of Android, iOS, Windows, and other systems. But unfortunately, |
+ | In such a situation, we recommend updating your phone to the latest OS. For situations where that is not possible we make these older versions available: | ||
+ | **Warning: | ||
|**OS Version** | **Download link** | | |**OS Version** | **Download link** | | ||
Line 205: | Line 207: | ||
| Android 4.3 to 4.4.4 x86 architecture | | Android 4.3 to 4.4.4 x86 architecture | ||
| macOS 10.9 (OS X Mavericks) | [[https:// | | macOS 10.9 (OS X Mavericks) | [[https:// | ||
+ | | macOS 10.10, 10.11 & 10.12 (OS X Yosemite / Sierra) | [[https:// | ||
Line 212: | Line 215: | ||
- | This page shows all the Victron products that have been discovered by your device, and to which a connection can be made. Click on the desired product. | ||
- | {{: | + | LOCAL - This page shows all the Victron products that have been discovered by your phone, and to which a connection can be made. Click on the desired product. |
+ | VRM - This page will show a GX product if it is connected to your VRM account. | ||
From ' | From ' | ||
Line 233: | Line 241: | ||
Line 248: | Line 256: | ||
Line 257: | Line 265: | ||
- | The ' | + | The ' |
Line 270: | Line 278: | ||
Line 283: | Line 291: | ||
Line 289: | Line 297: | ||
Line 297: | Line 305: | ||
**Blue Smart IP65 Charger ** | **Blue Smart IP65 Charger ** | ||
- | This video will show you how to download the VictronConnect app onto a smart phone (in the video we use an iPhone). It will also show you how to use the app to view information and control the settings of a BlueSmart | + | This video will show you how to download the VictronConnect app onto a smart phone (in the video we use an iPhone). It will also show you how to use the app to view information and control the settings of a Blue Smart IP65 charger. |
Line 310: | Line 318: | ||
{{youtube> | {{youtube> | ||
Line 323: | Line 331: | ||
- | ==== 5.4 How to disable Bluetooth ==== | + | ==== 5.4 How to disable |
- | All our products that have Bluetooth built-in, have a feature that allows disabling Bluetooth. Typically the reason for doing so is security, nothing more secure than disabling it. For example on unmanned roadside backup power stations; or other more large scale deployments. | + | All our products that have Bluetooth built-in, have a feature that allows disabling Bluetooth. Typically the reason for doing so is security, |
- | In most cases, it's also possible to re-enable Bluetooth after disabling. For example by using a VE.Direct cable. The only exception is the Lithium Smart batteries: once Bluetooth is disabled on them, it is disabled forever. | + | In most cases, it's also possible to re-enable Bluetooth after disabling. For example by using a VE.Direct cable. |
- | Here is how to disable Bluetooth: First complete your connection; then go to the **Product info** page. To access that page, click the button on the upper right. For some products, it will be the settings icon: {{: | + | There are, however, a few exceptions: |
+ | * The [[# | ||
+ | * The [[# | ||
- | For other products you'll find the {{: | + | === Finding |
- | If the product supports turning Bluetooth off, you will see the field " | + | First, complete your connection; then go to the **Product info** page by clicking |
- | For **most** of our products, | + | * For some products, |
+ | * For other products | ||
- | == How to re-enable | + | If the product has the feature that Bluetooth can be disabled, you will see the field " |
- | // | + | For some products, a Disable button is shown instead of a toggle switch. |
+ | === How to re-enable Bluetooth === | ||
There are a few different ways to re-enable Bluetooth depending on your product, always check the manual of your product for more detailed instructions: | There are a few different ways to re-enable Bluetooth depending on your product, always check the manual of your product for more detailed instructions: | ||
- | **Via VE.Direct: | + | == Re-enable Bluetooth |
- | **Smart Chargers:** In all smart chargers, Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds | + | Connect the product with a VE.Direct to USB cable to your phone and use VictronConnect |
- | //Chargers with a MODE button: // | + | == Re-enable Bluetooth using the MODE button |
- | Press and hold the MODE button for 10s will reset Bluetooth: | + | Press and hold the MODE button |
- | | + | * The PIN code is reset to its [[# |
- | - Blue Smart IP22 | + | |
- | **Smart Battery Protect:** Bluetooth | + | == Lithium |
- | selecting | + | The product page can be found [[https:// |
+ | Once Bluetooth is disabled, it is disabled | ||
- | **Smart BMV-712:** The BMV-712' | + | == Phoenix Smart IP43 Chargers == |
- | through the settings menu. Check the product manual for more details. | + | The product page can be found [[https:// |
+ | Once Bluetooth is disabled, there are multiple ways to re-enable it again: | ||
+ | - Using the [[# | ||
+ | - Using a [[# | ||
+ | == Blue Smart IP22 Chargers == | ||
+ | The product page can be found [[https:// | ||
+ | Once Bluetooth is disabled, it can be re-enabled with the [[# | ||
+ | == Blue Smart IP65 Chargers == | ||
+ | == Blue Smart IP67 Chargers == | ||
+ | For these chargers there are two options: | ||
+ | * Disable Bluetooth **permanently**. This option is **irreversible** and VictronConnect will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth, enter the code displayed and choose " | ||
+ | * Enable Bluetooth for 30 seconds at power-up. This allows you to connect to the product and to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | ||
+ | == SmartSolar MPPTs == | ||
+ | Bluetooth can be re-enabled by connecting a VE.Direct to USB cable to your phone and following [[# | ||
+ | **Smart Battery Protect**\\ | ||
+ | Bluetooth can be disabled/ | ||
+ | **Smart BMV-712**\\ | ||
+ | The BMV-712' | ||
+ | **Smart BMS**\\ | ||
+ | Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | ||
+ | **Smart Shunt**\\ | ||
==== 5.5 Importing and converting a GX Product Family database File ==== | ==== 5.5 Importing and converting a GX Product Family database File ==== | ||
- | VictronConnect for Mac OSX and Windows allows you to import and convert the database log file (that is created by the VenusOS on the GX Product Family | + | VictronConnect for Mac OSX and Windows allows you to import and convert the database log file (that is created by the VenusOS on the GX Product Family) to a Microsoft Excel XLSX file. This can be useful if the site is remote and without an internet connection to upload the file to the [[https:// |
Line 373: | Line 422: | ||
This feature is not available in the iOS and Android mobile versions of VictronConnect. | This feature is not available in the iOS and Android mobile versions of VictronConnect. | ||
Line 385: | Line 432: | ||
===== 7. Settings files ===== | ===== 7. Settings files ===== | ||
+ | ==== 7.1 Save, load, share and manage settings ==== | ||
This feature allows you to save product settings to a file so that they can be loaded onto the Victron product you are connected to ...or another product, at a later time. | This feature allows you to save product settings to a file so that they can be loaded onto the Victron product you are connected to ...or another product, at a later time. | ||
Line 390: | Line 439: | ||
Line 397: | Line 446: | ||
- | When the file is loaded the changes | + | When the file is loaded, the changes |
Line 408: | Line 457: | ||
** Settings file manager ** | ** Settings file manager ** | ||
- | The Settings file manager is located in the main menu. | + | The Settings file manager is located in the main menu, and shows all stored settings: |
- | From here files can be opened, shared or removed. | + | From here files can be opened, shared or removed: |
- | ** Open settings file ** | ||
- | When opening a file from the settings file manager a snapshot of the product at the point the setting file was saved is shown. | + | ==== 7.2 Settings files and the demo library ==== |
- | There is a constraint | + | The demo library can be a great tool for an installer to create a set of settings, and then share it to a customer whom can then apply it to their product. |
+ | Note that whilst saving settings from the demo library is possible, loading settings from within the demo library is not possible. | ||
+ | ==== 7.3 Limitation in opening | ||
+ | There are two methods to open a previously stored settings-file: | ||
+ | - From the settings file manager, as in the above screenshot, to see the settings without having to be connected to the product. A snapshot of all data, including voltage readings, history data, and so forth, will be loaded and visible to inspect. | ||
+ | - From the product settings pages, | ||
+ | Note that the first method only works when the settings | ||
- | This constraint only applies when opening files from the settings file manager for inspection. Loading files from a product settings page to restore it is always possible as long as VictronConnect version is equal or greater | ||
===== 8. Demo feature ===== | ===== 8. Demo feature ===== | ||
Line 435: | Line 493: | ||
Line 447: | Line 505: | ||
Line 453: | Line 511: | ||
- | __What about updating Firmware on VE.Bus | + | __What about updating Firmware on VE.Bus |
Please follow this [[https:// | Please follow this [[https:// | ||
Line 459: | Line 517: | ||
- | A firmware update - when available - will need to be completed in order to continue | + | If an update is available but is not mandatory, you will be able to see your product' |
+ | A firmware update - when available - will need to be completed in order to change settings on your Victron product | ||
__Will I need to reconfigure my MPPT or BMV after the update?__ | __Will I need to reconfigure my MPPT or BMV after the update?__ | ||
Line 479: | Line 541: | ||
Line 496: | Line 560: | ||
- | Due to limitations on a mobile device the process is slightly different from the Windows/MacOS routine. | + | The process is slightly different from the Windows/macOS routine, |
- | Firstly, you need to add the desired firmware | + | |
- | **Note for iOS**: The current version | + | Firstly, you need to add the desired firmware file to the VictronConnect firmware library. Firmware files can be added to the library from an email attachment, web browser, Dropbox, file browser, and any kind of app that can handle files. For both iOS and Android the procedure |
- | **Note for Android**: VictronConnect needs to be running before opening files. | + | If the message doesn' |
- | Open VictronConnect and, without closing it, switch to the app containing | + | |
+ | In case you are not sure which file to use, it is not a problem to add multiple files to the library. In the next step, VictronConnect will automatically only show the files that match with the connected product. | ||
- | On both iOS and Android, go to the app that contains the firmware file, tap on it, and open it with VictronConnect. | + | Here are screenshot showing |
Line 513: | Line 578: | ||
- | Go to the " | + | |
Line 533: | Line 596: | ||
==== 9.3 Troubleshooting firmware updates ==== | ==== 9.3 Troubleshooting firmware updates ==== | ||
- | A troubleshooting guide relevant to firmware updates can be found in [[# | + | A troubleshooting guide relevant to firmware updates can be found in [[# |
==== 9.4 Error codes ==== | ==== 9.4 Error codes ==== | ||
Line 539: | Line 602: | ||
In spite of our painstaking efforts, sometimes errors occur. But don't worry, it is always possible to recover your product. | In spite of our painstaking efforts, sometimes errors occur. But don't worry, it is always possible to recover your product. | ||
- | In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible and check that the Bluetooth function is enabled on your phone/ | + | In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible and check that the Bluetooth function is enabled on your phone. |
- | Sometimes you may need to [[# | + | Sometimes you may need to [[# |
In the following list, you can check possible errors and descriptions. | In the following list, you can check possible errors and descriptions. | ||
Line 675: | Line 738: | ||
|X45 |Update Error. Vreg Ack error: Invalid instance. Please check the connection and try again.| | |X45 |Update Error. Vreg Ack error: Invalid instance. Please check the connection and try again.| | ||
|X46 |Update Error. Vreg Ack error. Please check the connection and try again.| | |X46 |Update Error. Vreg Ack error. Please check the connection and try again.| | ||
- | ===== 10. Troubleshooting ===== | ||
- | ==== 10.1 Common Bluetooth problems and how to solve them === | ||
- | == I cannot find my device | + | ===== 10. VictonConnect-Remote (VC-R) – Configuration and monitoring via VRM ===== |
+ | ==== 10.1 Introduction ==== | ||
+ | VictronConnect-Remote functionality enables Victron products with a VE.Direct interface to be accessed remotely through a [[https:// | ||
+ | This powerful feature allows full product configuration and monitoring from practically anywhere in the world using the VictronConnect app. | ||
+ | The user interface experience is just like the products were connected locally using Bluetooth or a wired VE.Direct to USB interface. | ||
+ | A video demonstrating the feature is available here: | ||
+ | {{youtube> | ||
+ | ==== 10.2 Compatibility ==== | ||
+ | The VictronConnect-Remote feature is ONLY compatible with products connected to a GX product with a VE.Direct interface. | ||
+ | This includes; | ||
+ | * MPPT solar chargers with a VE.Direct interface (SmartSolar and BlueSolar) | ||
+ | * Battery monitors with a VE.Direct interface (BMV and SmartShunt) | ||
+ | * Specific inverters with a VE.Direct interface (Phoenix Inverter VE.Direct and Phoenix Inverter Smart) | ||
+ | * Specific mains chargers with a VE.Direct interface (Phoenix Smart IP43) | ||
+ | Products connected with a VE.Bus interface, such as Multiplus/ | ||
+ | Products connected using a VE.Can interface, such as Lynx Shunt, Skylla chargers, and MPPT solar chargers using a VE.Can interface are also NOT compatible and cannot be configured remotely. | ||
+ | ==== 10.3 Setup ==== | ||
+ | === 10.3.1 Minimum Requirements === | ||
+ | * VictronConnect SW: v5.20 | ||
+ | * GX Product- Venus OS FW: v2.40 (However v2.53 recommended for full functionality) | ||
+ | === 10.3.2 VictronConnect === | ||
+ | - Confirm that the phone has VictronConnect installed and that the software version meets or exceeds the minimum requirements - upgrade if necessary | ||
+ | - Authorize VictronConnect to access your VRM account; | ||
+ | * Open the VictronConnect app | ||
+ | * Swipe across to the VRM tab, then select ‘SIGN IN TO VRM’ | ||
+ | * Complete your email address and VRM password, then select ‘Authorize Victron Connect’ | ||
+ | * If using a tablet or PC your browser may also request permission to open VictronConnect, | ||
+ | === 10.3.3 GX Product === | ||
+ | 1- Confirm that the GX Product is running Venus OS firmware version that meets or exceeds the minimum requirements - upgrade if necessary | ||
+ | 2- Enable ‘VRM two-way communication’ under Device List > Settings > VRM Online Portal | ||
+ | ==== 10.4 Local Tab ==== | ||
+ | The local tab displays all products that are within local Bluetooth and wireless LAN range or physically connected to the phone with VictronConnect (such as with a VE.Direct to USB or MK3 to USB interface cable) | ||
+ | ==== 10.5 VRM Tab ==== | ||
+ | The VRM tab displays all VRM installations associated with the VRM user profile. | ||
+ | Any installation can be selected to access the VRM online portal or connected products. | ||
+ | When a VRM installation is selected it will take a few seconds for a connection to be made, once the connection is established two tabs will appear, an ‘OVERVIEW’ tab and a ‘DEVICES’ tab. | ||
+ | === 10.5.1 Overview Tab === | ||
+ | The ‘OVERVIEW’ tab has an image of the GX product, the name of the VRM installation, | ||
+ | === 10.5.2 Devices Tab === | ||
+ | The ‘DEVICES’ tab has a list of all compatible products that are physically connected to the GX product. | ||
+ | If using a tablet or PC, the ‘DEVICES’ tab is shown as a panel on the right side of the same screen. | ||
+ | ==== 10.6 Remote product access ==== | ||
+ | When a product is selected it will take a few seconds for a connection to be made, once the connection is established live product information/ | ||
+ | Immediately after initial connection settings and historical data will be downloaded, during this time a cloud symbol will remain in the upper right corner (this typically takes less than 30 seconds). | ||
+ | Settings cannot be accessed until the cloud symbol is replaced by the normal settings gear symbol. | ||
+ | ==== 10.7 Signing out ==== | ||
+ | To disable the link between VictronConnect-Remote and your VRM account, expand the main menu and then select ‘Settings’. | ||
+ | In the settings page select ‘SIGN OUT’ and then select ‘OK’ in the prompt window to confirm. | ||
+ | After signing out VictronConnect-Remote will no longer have access to the VRM account or any of the associated VRM installations. To reinstate access the log in procedure needs to be repeated. | ||
+ | ==== 10.8 Troubleshooting and FAQ ==== | ||
+ | == Product not found == | ||
+ | * VictronConnect-Remote is only compatible with products that use a VE.Direct interface to the GX product – see the ‘compatibility’ section. | ||
+ | * Ensure that that the missing product is physically connected to the GX product, with the VE.Direct cable properly installed at both ends. | ||
+ | * Ensure that the product is running a recent firmware version. | ||
+ | == Installation/ | ||
+ | * Confirm that the installation is currently online and communicating with the VRM online portal. | ||
+ | * Ensure that the installation is linked to the VRM account used during initial VictronConnect-Remote sign in to VRM. | ||
+ | * Ensure that ‘VRM two-way communication’ is enabled – see the ‘settings’ section. | ||
+ | * Ensure that the GX product is running the minimum compatible Venus OS firmware version – see the ‘settings’ section. | ||
+ | == VictronConnect has no VRM tab == | ||
+ | * Ensure that the phone is running the minimum compatible VictronConnect software version – see the ‘settings’ section. | ||
+ | == VRM account == | ||
+ | * It is necessary to have an active VRM account linked to your installation and any others that you intend to monitor or configure using VictronConnect-Remote - creating a new account is quick and easy. | ||
+ | * For further information in relation to VRM (Victron Remote Management) see [[https:// | ||
+ | == Systems with no GX product == | ||
+ | * VictronConnect-Remote functionality is not possible unless the system includes a GX product. A GX product can be easily added to any system and there are a [[https:// | ||
+ | == Installations with no internet connection == | ||
+ | * VictronConnect-Remote functionality is not possible unless the GX product at the installation site has an active internet connection. | ||
+ | * For remote sites without an existing internet connection or with mobile installations, | ||
+ | == Large systems == | ||
+ | * The use of the VictronConnect-Remote feature will slightly increase the GX product CPU load. | ||
+ | * In some large/ | ||
+ | * It is important to select a GX product that has sufficient performance capability in relation to the system design, for example, a Cerbo GX has significantly more processing power than a Color Control GX and is much better suited to large/ | ||
+ | == VictronConnect Remote troubleshooting == | ||
+ | VictronConnect will report errors encountered during communication attempts with VRM in a message box with an error code (e.g. #R999, or #V2). The numeric part of the code can have one of the following value: | ||
+ | ^Error ^Description^ | ||
+ | |999 | Call to retrieve a list of child devices expired (60 seconds). The most common cause is a bad internet connection. | | ||
+ | | 1 | No link to VRM can be established. Check if the internet is present and try again. | | ||
+ | | 2 | VRM encountered temporary difficulties. Try again in a while. It could also indicate issues with your credentials. | | ||
+ | | 8 | An error occurred with the network (e.g., the network cable was accidentally plugged out). | | ||
+ | | 13 | Proxy authentication error. VictronConnect does not support communication over proxy. | | ||
+ | | 14 | Failed to establish a secure connection to VRM. | | ||
+ | |65538| VRM MQTT broker is not responding. Please try again in a while. | | ||
+ | There are also other error codes that could be reported. They are a result of internal errors in VictronConnect and/or VRM. In case these errors persist after a retry, please create a " | ||
+ | VictronConnect Remote is establishing communication with a range of services on the ' | ||
+ | ===== 11. Troubleshooting ===== | ||
+ | ==== 11.1 Common Bluetooth problems and how to solve them === | ||
+ | The #1 first step before attempting any of the specific troubleshooting advice below is to power down and then restart all related devices. This includes closing the software, restarting the phone, and Victron product. This will solve most issues. | ||
+ | For example, with Victron MPPTs you must isolate the MPPT from both battery and solar voltage so that no lights appear, before reconnecting it again. | ||
+ | == I cannot find my product | ||
- | * Make sure your device | + | * Make sure your product |
- | * If a firmware update failed, the device | + | * If a firmware update failed, the product |
- | * Only one device | + | * Only one phone can be connected to a product at the same time. Make sure that no other phone is already connected. |
- | * Make sure you are attempting to connect from //within// VictronConnect - not from the system menu of your phone/ | + | * Make sure you are attempting to connect from //within// VictronConnect - not from the system menu of your phone. If you have connected from the system menu: close VictronConnect, |
- | == I can see but not connect to my device | + | == I can see but not connect to my product |
- | - Make sure you are trying to connect to the right device. See [[start# | + | - Make sure you are trying to connect to the right product. See [[start# |
- | - Make sure your device | + | - Make sure your product |
- | - Make sure that Bluetooth is still enabled | + | - Make sure that Bluetooth is still enabled |
- | - The Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the device, or if your Victron | + | - Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the product, or if your Victron |
- | - If you are using an Android phone/tablet, check [[start# | + | - If you are using an Android phone, check [[start# |
=== Connection fails around 20% === | === Connection fails around 20% === | ||
- | [[https:// | + | - Make sure you are up to date with the latest version of VictronConnect. |
- | ==== 10.2 Bluetooth connection issues on Android | + | - [[https:// |
+ | - Then [[https:// | ||
+ | - Force close the VictronConnect app. Instructions: | ||
+ | - Reconnecting in VictronConnect using the default PIN 000000 | ||
- | === Step 1: Check that your device is supported | + | ==== 11.2 Bluetooth connection issues on Android ==== |
- | See section [[# | + | === Step 1: Check that your phone is supported === |
+ | See section [[# | ||
=== Step 2: Check the Android version === | === Step 2: Check the Android version === | ||
Line 710: | Line 960: | ||
- | On Android 5 and later VictronConnect needs access to the device | + | On Android 5 and later VictronConnect needs access to the phone' |
Line 716: | Line 966: | ||
=== Step 4. Enable Location (or GPS) functionality in the system settings === | === Step 4. Enable Location (or GPS) functionality in the system settings === | ||
- | For Bluetooth scanning to work, the Location (or GPS) functionality on the device | + | For Bluetooth scanning to work, the Location (or GPS) functionality on the phone needs to be enabled. |
- | === Step 5. Search & connect from within VictronConnect | + | === Step 5. Search & connect from within VictronConnect, and NOT from the system Bluetooth menu === |
=== Step 6. Pin-code pop-up never shows === | === Step 6. Pin-code pop-up never shows === | ||
- | On some Android phones, the pin-code pop-up dialog doesn' | + | On some Android phones, the PIN code pop-up dialog doesn' |
Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code. | Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code. | ||
+ | On Android it is also possible that other apps prevent the PIN code pop-up from showing, even when pairing in the Android Bluetooth settings menu. One such an app is "FrSky Free Link", which even blocks pairing with Bluetooth headsets. In this case, the thing to do is remove the problematic app. This can be done by uninstalling apps one by one (starting with apps that use or connect to Bluetooth devices), removing all apps or even resetting the phone to factory defaults. When the Victron products are paired to the phone/ | ||
The default pin-code is 000000, six times zero. | The default pin-code is 000000, six times zero. | ||
=== Step 7. Try another phone at first === | === Step 7. Try another phone at first === | ||
- | If you are still experiencing difficulties, | + | If you are still experiencing difficulties, |
- | When successfully connected using another | + | When successfully connected using another |
- | First of all, its good to know that you can always restart the firmware | + | ==== 11.3 Problems during |
- | Keep your mobile device as close to the product as possible. If the update | + | First of all, it's good to know that you can always restart |
- | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. If the update fails even after many attempts, try using another phone or tablet | + | Keep your phone as close to the product as possible. If the update fails due to Bluetooth connectivity problems, and if your phone is already paired to a product, try and remove the pairing completely from your phone' |
+ | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. If the update fails even after many attempts, try using another phone or tablet, if possible an Apple iOS phone - they usually work without any issues. After the update, you may find that you can use the phone with which you were having difficulty. | ||
- | When the firmware update fails at 4% or less, VictronConnect cannot make the device | + | When the firmware update fails at 4% or less, VictronConnect cannot make the product |
__ Solution for Blue Smart IP65 Chargers __ | __ Solution for Blue Smart IP65 Chargers __ | ||
Line 762: | Line 1016: | ||
* The firmware update screen will appear again. You should now be able to update the dongle to the latest firmware version. | * The firmware update screen will appear again. You should now be able to update the dongle to the latest firmware version. | ||
- | ==== 10.4 VE.Direct USB driver problem on macOS X 10.9 (Mavericks) ==== | + | ==== 11.4 VE.Direct USB driver problem on macOS X 10.9 (Mavericks) ==== |
The driver included in macOS X 10.9 " | The driver included in macOS X 10.9 " | ||
Line 783: | Line 1037: | ||
- | ==== 10.5 VictronConnect on Windows doesn' | + | ==== 11.5 VictronConnect on Windows doesn' |
Line 789: | Line 1043: | ||
The necessary drivers are available in the [[https:// | The necessary drivers are available in the [[https:// | ||
- | ==== 10.6 VictronConnect on Android doesn' | + | ==== 11.6 VictronConnect on Android doesn' |
- | VictronConnect needs to be running before | + | VictronConnect needs to be running before |
- | Open VictronConnect and without closing it switch to the app containing the file, select it an choose to open it with VictronConnect. | + | Open VictronConnect and without closing it switch to the app containing the file, select it and choose to open it with VictronConnect. |
- | ==== 10.7 How to create a VictronConnect Service Report ==== | + | ==== 11.7 How to create a VictronConnect Service Report ==== |
If you are experiencing issues with VictronConnect or your Victron product, you may be asked to create a " | If you are experiencing issues with VictronConnect or your Victron product, you may be asked to create a " | ||
+ | Please note that this service report is for Victron internal use and is not able to be read or used for any other purpose than developer troubleshooting. | ||
To do this, | To do this, | ||
Line 808: | Line 1063: | ||
- Select Settings | - Select Settings | ||
- Click or tap CREATE SERVICE REPORT | - Click or tap CREATE SERVICE REPORT | ||
- | - Save, email or copy the file to Victron, via email or the Victron Community. | + | - Save, email, or copy the file to Victron, via email or the Victron Community. |
- | ==== 10.8 VE.Bus firmware update fails at 5% on macOS ==== | + | If you require more detailed power system diagnostic information, |
+ | ==== 11.8 VE.Bus firmware update fails at 5% on macOS ==== | ||
There is a known issue that makes VE.Bus firmware updates randomly fail on some macOS laptops. We are working on it; a new VictronConnect version fixing this issue is expected in the near future. Meanwhile this is the workaround for this: | There is a known issue that makes VE.Bus firmware updates randomly fail on some macOS laptops. We are working on it; a new VictronConnect version fixing this issue is expected in the near future. Meanwhile this is the workaround for this: | ||
Line 822: | Line 1078: | ||
(1) For those with a technical background and wondering how, why and what minimising has to do with this: yes this really works, and relates to a power saving mode that has a side effect on serial communication. | (1) For those with a technical background and wondering how, why and what minimising has to do with this: yes this really works, and relates to a power saving mode that has a side effect on serial communication. | ||
- | ===== 11. Compatible Victron products ===== | ||
- | ==== SmartSolar MPPT Charge controllers | + | ===== 12. Compatible Victron products ===== |
+ | ==== Solar Chargers ==== | ||
+ | === SmartSolar MPPT Charge controllers === | ||
^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | ^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | ||
| MPPT 75/10 | [[https:// | | MPPT 75/10 | [[https:// | ||
Line 851: | Line 1110: | ||
The same models, but then with a different part number do support using both the VE.Direct port and the built-in Bluetooth Smart function at the same time. As do all other SmartSolar MPPT models. | The same models, but then with a different part number do support using both the VE.Direct port and the built-in Bluetooth Smart function at the same time. As do all other SmartSolar MPPT models. | ||
- | ==== Blue Smart IP22 Chargers ==== | + | === BlueSolar MPPT Charge controllers === |
- | | All Blue Smart IP22 Chargers | No | Yes - Built in | | + | |
- | | All Blue Smart IP65 Chargers | + | |
- | ==== Phoenix Smart IP43 Charger ==== | + | |
- | | All Phoenix Smart IP43 Chargers | + | |
- | | BMV-700 | + | |
- | | BMV-702 | + | |
- | | BMV-712 | + | |
- | ==== BlueSolar MPPT Charge controllers | + | |
| MPPT 70/15 | Not compatible || | | MPPT 70/15 | Not compatible || | ||
Line 899: | Line 1129: | ||
+ | ==== Battery Chargers ==== | ||
+ | ^ Blue Smart IP22 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All Blue Smart IP22 Chargers | ||
+ | ^ Blue Smart IP65 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | Blue Smart IP65 12/25 Charger | ||
+ | | Blue Smart IP65 24/13 Charger | ||
+ | | Other Blue Smart IP65 Chargers | ||
+ | ^ Blue Smart IP67 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All Blue Smart IP67 Chargers | ||
+ | ^ Phoenix Smart IP43 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All Phoenix Smart IP43 Chargers | Yes | Yes - Built in | Yes | No | No | | ||
+ | ^ IMPULSE-II Smart ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All IMPULSE-II Smart Chargers | ||
+ | | BMV-700 | ||
+ | | BMV-702 | ||
+ | | BMV-712 | ||
Line 940: | Line 1195: | ||
Line 954: | Line 1205: | ||
- | This section applies to MultiPlus, MultiPlus-II, | ||
- | In order to keep this section short, all these devices | + | This section applies to MultiPlus, MultiPlus-II, |
+ | In order to keep this section short, all these products | ||
- | The minimal required version of the VE.Bus | + | The minimal required version of the VE.Bus |
Line 971: | Line 1223: | ||
