victronconnect:start
victronconnect:start [2019-11-12 15:27] – [5.4 How to disable Bluetooth] evandromr | victronconnect:start [2019-12-09 19:42] – [4.2 macOS X] mvader | ||
Line 127: | Line 127: | ||
==== 4.2 macOS X === | ==== 4.2 macOS X === | ||
- | VictronConnect requires macOS version is 10.12 (OS X Sierra), or later. | + | Todays version of VictronConnect requires macOS version is 10.12 (OS X Sierra), or later. |
For the older macOS 10.11/ | For the older macOS 10.11/ | ||
Line 452: | Line 452: | ||
===== 9. Firmware updates===== | ===== 9. Firmware updates===== | ||
+ | __What about updating Firmware on VE.Bus devices such as MultiPlus and Quattro?__ | ||
+ | Please follow this [[https:// | ||
Line 469: | Line 473: | ||
A firmware update - when available - will need to be completed in order to continue using VictronConnect. | A firmware update - when available - will need to be completed in order to continue using VictronConnect. | ||
- | __Will I need to reconfigure my device | + | __Will I need to reconfigure my MPPT or BMV after the update?__ |
+ | No. The settings of your VE.direct and Bluetooth products will not be affected by the firmware update ...and so you will not need to reconfigure your product after the update. Also, the History data of BMVs and MPPTs will be preserved throughout a firmware update. | ||
==== 9.2 Updating to a self-supplied firmware file ==== | ==== 9.2 Updating to a self-supplied firmware file ==== |
