Both sides previous revisionPrevious revision | Next revisionBoth sides next revision |
victronconnect:start [2019-10-30 14:06] – [10.1 Common Bluetooth problems and how to solve them] evandromr | victronconnect:start [2019-11-06 05:39] – [10.1 Common Bluetooth problems and how to solve them] guy_stewart |
== I can see but not connect to my device == | == I can see but not connect to my device == |
* Make sure you are trying to connect to the right device. See [[start#renaming_your_devices | section 4.3]] to learn how you can give your device a //Custom Name//. | - Make sure you are trying to connect to the right device. See [[start#renaming_your_devices | section 4.3]] to learn how you can give your device a //Custom Name//. |
* Make sure your device is in range. It can be that you are close enough to see the device but not close enough to connect to it. | - Make sure your device is in range. It can be that you are close enough to see the device but not close enough to connect to it. |
* Make sure that Bluetooth is still enabled in your phone/tablet/laptop. If Bluetooth was disabled after scanning, you may be able to see your device listed but you won't be able to connect to it. | - Make sure that Bluetooth is still enabled in your phone/tablet/laptop. If Bluetooth was disabled after scanning, you may be able to see your device listed but you won't be able to connect to it. |
* The Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the device, or if your Victron device has been connected to too many phones/tablets/Laptops. The device will only remember the last 10 phones/tablets/laptops connected to it. To solve this, remove the pairing completely from your phone/tablet/laptop system menu. Then open VictronConnect and re-pair the product and your device. Watch these instructional videos to learn how to remove the pairing on {{victronconnect:video_unpair_android_cropped.mp4?linkOnly | Android}} or {{victronconnect:video_unpair_ios.mp4?linkOnly | iOS}} devices. | - The Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the device, or if your Victron device has been connected to too many phones/tablets/Laptops. The device will only remember the last 10 phones/tablets/laptops connected to it. To solve this, remove the pairing completely from your phone/tablet/laptop system menu. Then open VictronConnect and re-pair the product and your device. Watch these instructional videos to learn how to remove the pairing on {{victronconnect:video_unpair_android_cropped.mp4?linkOnly | Android}} or {{victronconnect:video_unpair_ios.mp4?linkOnly | iOS}} devices. |
* If you are using an Android phone/tablet, check [[start#bluetooth_connection_issues_on_android_devices| section 9.2]] below for issues particular to Android. | - If you are using an Android phone/tablet, check [[start#bluetooth_connection_issues_on_android_devices| section 9.2]] below for issues particular to Android. |
| === Connection fails around 20% === |
| [[https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_removing_from_the_list_of_paired_devices|Remove the device from the paired devices list]] in the phones Bluetooth settings. [[https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_changing_the_pin_code|Then change the PIN code.]] |
==== 10.2 Bluetooth connection issues on Android devices ==== | ==== 10.2 Bluetooth connection issues on Android devices ==== |
For systems with a [[venus-os:start|GX device]] installed, and running firmware version 415 or newer, switching between on/off/charger-only and setting the input current limit IS possible. | For systems with a [[venus-os:start|GX device]] installed, and running firmware version 415 or newer, switching between on/off/charger-only and setting the input current limit IS possible. |
