victronconnect:start
victronconnect:start [2019-10-01 12:30] – guy_stewart | victronconnect:start [2019-10-21 09:53] – [10.7 How to create a VictronConnect Service Report] jperez | ||
Line 129: | Line 129: | ||
Android 5.0 is the minimum version required to run VictronConnect. | Android 5.0 is the minimum version required to run VictronConnect. | ||
- | (An older version of VictronConnect for users of Android 4.x is still available in [[https:// | + | (An older version of VictronConnect |
Required hardware is ARMv7 and later, as well as x86 or ARM64bit. | Required hardware is ARMv7 and later, as well as x86 or ARM64bit. | ||
Line 751: | Line 751: | ||
+ | ==== 10.8 VE.Bus firmware update fails at 5% on macOS ==== | ||
+ | There is a known issue that makes VE.Bus firmware updates randomly fail on some macOS systems. We are working on it and soon, a new VictronConnect version fixing it will be released. Meanwhile theres is a workaround for this: | ||
+ | Proceed to update as usual and quickly minimise VictronConnect window when progress bar is shown because the update starts. After ~20 seconds you can maximise VictronConnect to see the update status. | ||
+ | This issue was introduced in VictronConnect v5.9. | ||
===== 11. Compatible Victron products ===== | ===== 11. Compatible Victron products ===== | ||
