victronconnect:start
victronconnect:start [2019-09-22 11:42] – [4.3 Android devices] guy_stewart | victronconnect:start [2020-10-27 14:40] – marmour | ||
- | Welcome | + | |
- | See the table of contents for all information covered in this document. | + | |
- | Other relevant documents are: | + | |
- | * [[https:// | + | |
- | * [[https://docs.victronenergy.com/ | + | |
- | ^ Method | + | |
- | | [[ve.direct: | + | |
- | | [[https:// | + | |
- | Use the [[# | + | |
- | - Enable the Bluetooth setting on your device, but do not pair outside of VictronConnect. | + | |
- | **To prevent unauthorised connections to your device we recommend you change the PIN code. Avoid using obvious PIN codes such as 111111 or 123456.** | + | |
- | Note that after changing the pin code, all other phones, tablets, and laptops connected to the Victron product need to have their pairing information refreshed; and first, the old pairing information needs to be removed. See [[start# | + | |
- | {{victronconnect: | + | |
- | *(Downloads for VictronConnect for users of Windows XP / Vista are still available in [[https:// | + | |
- | (An older version of VictronConnect for users of Android 4.x is still available in [[https:// | + | |
- | Required hardware is ARMv7 and later, as well as x86 or ARM64bit. | + | |
- | === Android 5 === | + | |
- | | Huawei | + | |
- | | Lenovo | + | |
- | | Samsung | + | |
- | **Device list**\\ | + | |
- | Clicking on ' | + | |
- | *To access ' | + | |
- | From ' | + | |
- | The ' | + | |
- | From ' | + | |
- | **Windows**\\ | + | |
- | **macOS X**\\ | + | |
- | {{youtube> | + | |
- | ==== 5.4 Importing and converting a GX Product Family database File ==== | + | |
- | This feature is not available in the iOS mobile version of VictronConnect. | + | |
- | Go to the " | + | |
- | Check [[# | + | |
- | ^Error | + | |
- | ==== 10.1 Common Bluetooth problems and how to solve them === | + | |
- | * Make sure you are trying to connect to the right device. See [[start# | + | |
- | * Make sure your device is in range. It can be that you are close enough to see the device but not close enough to connect to it. | + | |
- | * Make sure that Bluetooth is still enabled in your phone/ | + | |
- | * The Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the device, or if your Victron device has been connected to too many phones/ | + | |
- | * If you are using an Android phone/ | + | |
- | ==== 10.2 Bluetooth connection issues on Android devices ==== | + | |
- | See section [[# | + | |
- | ==== 10.4 VE.Direct USB driver problem on macOS X 10.9 (Mavericks) ==== | + | |
- | cd / | + | |
- | http:// | + | |
- | ==== 10.5 VictronConnect on Windows doesn' | + | |
- | ==== 10.6 VictronConnect on Android doesn' | + | |
- | ==== 10.7 How to create a VictronConnect Service Report ==== | + | |
- | To do this, | + | |
- | - Select Settings | + | |
- | ===== 11. Compatible Victron products ===== | + | |
- | | MPPT 100/ | + | |
- | | MPPT 150/ | + | |
- | | All Blue Smart IP22 Chargers | No | Yes - Built in | | + | |
- | | All Blue Smart IP65 Chargers | + | |
- | | BMV-700 | + | |
- | | BMV-702 | + | |
- | | BMV-712 | + | |
- | For systems with a [[venus-os: | + | |
