victronconnect:start
victronconnect:start [2019-08-06 09:21] – [2.3 Resetting the Bluetooth Smart pin code] mvader | victronconnect:start [2019-08-15 11:48] – replace Venus-device with GX device guy_stewart | ||
Line 494: | Line 494: | ||
===== 9. Troubleshooting ===== | ===== 9. Troubleshooting ===== | ||
- | ==== 9.1 Cannot find my device (Bluetooth) === | + | ==== 9.1 Common |
- | | + | * If a firmware update failed, the device //Custom Name// might have reverted to its original name and serial number, check if that is the case. Once the update is completed, the //Custom Name// will be back. See more tips about troubleshooting firmware updates on [[start# |
- | If none of the above helps, and if your device is already paired | + | == I can see but not connect to my device == |
+ | * Only one device can be connected | ||
==== 9.2 Bluetooth connection issues on Android devices ==== | ==== 9.2 Bluetooth connection issues on Android devices ==== | ||
Line 776: | Line 782: | ||
