victronconnect:start
victronconnect:start [2019-04-10 14:01] – [8. john_r | victronconnect:start [2019-08-06 17:01] – [9.1 Cannot find my device (Bluetooth)] evandromr | ||
Line 39: | Line 39: | ||
**To prevent unauthorised connections to your device we recommend you change the PIN code. Avoid using obvious PIN codes such as 111111 or 123456.** | **To prevent unauthorised connections to your device we recommend you change the PIN code. Avoid using obvious PIN codes such as 111111 or 123456.** | ||
- | To change the PIN code: First complete your connection; then go to the **Product info** page. To access that page, click the button on the upper right. For some products it will be the settings icon: {{: | + | To change the PIN code, first complete your connection. Then go to the **Product info** page. To access that page, click the button on the upper right. For some products it will be the settings icon: {{: |
+ | On this page, select the change pin code button. | ||
+ | Note that after changing the pin code, all other phones, tablets and laptops connected to the Victron product need to be repaired as well; and first their pairing needs to be removed. See videos (TODO - improve this text and add links to those videos or to the right section in the manual.). | ||
==== 2.3 Resetting the Bluetooth Smart pin code ==== | ==== 2.3 Resetting the Bluetooth Smart pin code ==== | ||
Line 65: | Line 69: | ||
On a desktop (Windows, Mac), 'right click' the product description instead of pressing and holding. | On a desktop (Windows, Mac), 'right click' the product description instead of pressing and holding. | ||
- | === Blue Smart Solar Charger === | + | === Smart Solar Charger === |
On the device list: Press and hold the product description for which you would like to reset the PIN code. A menu will pop up offering a 'Reset PIN code' option. Click that, and enter the PUK code. The PUK code can be found on the product label, on the back of the product. | On the device list: Press and hold the product description for which you would like to reset the PIN code. A menu will pop up offering a 'Reset PIN code' option. Click that, and enter the PUK code. The PUK code can be found on the product label, on the back of the product. | ||
Line 121: | Line 125: | ||
=== Android 6 and later === | === Android 6 and later === | ||
- | No known issues. | + | No known issues, when Access to Locations services are enabled. |
=== Access to location services required? === | === Access to location services required? === | ||
Line 490: | Line 494: | ||
===== 9. Troubleshooting ===== | ===== 9. Troubleshooting ===== | ||
- | ==== 9.1 Cannot find my device (Bluetooth) === | + | ==== 9.1 Common |
+ | * Make sure that you have a " | ||
- | * Only one device can be connected to a product. Make sure that no other device: phone/tablet/laptop | + | * If a firmware update failed, the device //Custom Name// might have reverted to its original name and serial number, check if that is the case. Once the update is completed, the //Custom Name// will be back. See more tips about troubleshooting firmware updates on [[start# |
- | If none of the above helps, and if your device is already paired | + | == I can see but not connect to my device == |
+ | * Only one device can be connected | ||
==== 9.2 Bluetooth connection issues on Android devices ==== | ==== 9.2 Bluetooth connection issues on Android devices ==== | ||
Line 521: | Line 533: | ||
=== Step 5. Search & connect from within VictronConnect ...NOT from the system Bluetooth menu === | === Step 5. Search & connect from within VictronConnect ...NOT from the system Bluetooth menu === | ||
- | === Step 6. Try another phone at first === | + | === Step 6. Pin-code pop-up never shows === |
+ | On some Android phones, the pin-code pop-up dialog doesn' | ||
+ | Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code. | ||
+ | The default pin-code is 000000, six times zero. | ||
+ | === Step 7. Try another phone at first === | ||
If you are still experiencing difficulties, | If you are still experiencing difficulties, | ||
Line 530: | Line 550: | ||
First of all, its good to know that you can always restart the firmware update procedure. The update process will be restarted each time you connect to the product. | First of all, its good to know that you can always restart the firmware update procedure. The update process will be restarted each time you connect to the product. | ||
- | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. Keep your mobile device as close to the product as possible. If the update fails even after many attempts, try using another phone or tablet ...if possible an Apple iOS device - they usually work without any issues. After the update, you may find you can use the phone with which you were having difficulty. | + | Keep your mobile device as close to the product as possible. If the update fails due to Bluetooth connectivity problems, and if your device is already paired to a product, try and remove the pairing completely from your phone/ |
+ | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. If the update fails even after many attempts, try using another phone or tablet ...if possible an Apple iOS device - they usually work without any issues. After the update, you may find you can use the phone with which you were having difficulty. | ||
Line 585: | Line 608: | ||
Open VictronConnect and without closing it switch to the app containing the file, select it an choose to open it with VictronConnect. | Open VictronConnect and without closing it switch to the app containing the file, select it an choose to open it with VictronConnect. | ||
+ | ==== 9.7 How to create a VictronConnect Service Report ==== | ||
+ | If you are experiencing issues with VictronConnect or your Victron product, you may be asked to create a " | ||
+ | To do this, | ||
+ | - Open VictronConnect | ||
+ | - Perform the action that leads to the bug or issue | ||
+ | - Return to the main menu | ||
+ | - Select the three lines menu | ||
+ | - Select Settings | ||
+ | - Click or tap CREATE SERVICE REPORT | ||
+ | - Save, email or copy the file to Victron, via email or the Victron Community. | ||
===== 10. Compatible Victron products ===== | ===== 10. Compatible Victron products ===== | ||
Line 748: | Line 788: | ||
