victronconnect:start
victronconnect:start [2019-02-09 12:06] – [2.1 Bluetooth Smart - Pairing and Connecting] guy_stewart | victronconnect:start [2019-07-30 11:08] – [9.1 Cannot find my device (Bluetooth)] evandromr | ||
Line 121: | Line 121: | ||
=== Android 6 and later === | === Android 6 and later === | ||
- | No known issues. | + | No known issues, when Access to Locations services are enabled. |
=== Access to location services required? === | === Access to location services required? === | ||
Line 237: | Line 237: | ||
- | Here is a VictronConnect app screenshot from a device using a version of the Microsoft Windows operating system. | + | Here is a VictronConnect app screenshot from a device using a version of the Microsoft Windows operating system |
Line 243: | Line 243: | ||
- | Here is a VictronConnect app screenshot from a device running the Mac Operating System. | + | Here is a VictronConnect app screenshot from a device running the Mac Operating System |
Line 374: | Line 374: | ||
- | No. Updating firmware does **not** require an internet connection, the latest Firmware files already loaded inside VictronConnect, | + | No. Updating firmware does **not** require an internet connection, the latest Firmware files are already loaded inside VictronConnect, |
Line 492: | Line 492: | ||
==== 9.1 Cannot find my device (Bluetooth) === | ==== 9.1 Cannot find my device (Bluetooth) === | ||
+ | * Make sure that you have a " | ||
* Only one device can be connected to a product. Make sure that no other device: phone/ | * Only one device can be connected to a product. Make sure that no other device: phone/ | ||
Line 497: | Line 498: | ||
If none of the above helps, and if your device is already paired to a product, remove the pairing completely from your phone/ | If none of the above helps, and if your device is already paired to a product, remove the pairing completely from your phone/ | ||
==== 9.2 Bluetooth connection issues on Android devices ==== | ==== 9.2 Bluetooth connection issues on Android devices ==== | ||
Line 521: | Line 524: | ||
=== Step 5. Search & connect from within VictronConnect ...NOT from the system Bluetooth menu === | === Step 5. Search & connect from within VictronConnect ...NOT from the system Bluetooth menu === | ||
- | === Step 6. Try another phone at first === | + | === Step 6. Pin-code pop-up never shows === |
+ | On some Android phones, the pin-code pop-up dialog doesn' | ||
+ | Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code. | ||
+ | The default pin-code is 000000, six times zero. | ||
+ | === Step 7. Try another phone at first === | ||
If you are still experiencing difficulties, | If you are still experiencing difficulties, | ||
Line 585: | Line 596: | ||
Open VictronConnect and without closing it switch to the app containing the file, select it an choose to open it with VictronConnect. | Open VictronConnect and without closing it switch to the app containing the file, select it an choose to open it with VictronConnect. | ||
+ | ==== 9.7 How to create a VictronConnect Service Report ==== | ||
+ | If you are experiencing issues with VictronConnect or your Victron product, you may be asked to create a " | ||
+ | To do this, | ||
+ | - Open VictronConnect | ||
+ | - Perform the action that leads to the bug or issue | ||
+ | - Return to the main menu | ||
+ | - Select the three lines menu | ||
+ | - Select Settings | ||
+ | - Click or tap CREATE SERVICE REPORT | ||
+ | - Save, email or copy the file to Victron, via email or the Victron Community. | ||
===== 10. Compatible Victron products ===== | ===== 10. Compatible Victron products ===== | ||
Line 748: | Line 776: | ||
