victronconnect:start
victronconnect:start [2019-01-22 10:16] – external edit 127.0.0.1 | victronconnect:start [2019-02-09 12:06] – [2.1 Bluetooth Smart - Pairing and Connecting] guy_stewart | ||
Line 25: | Line 25: | ||
==== 2.1 Bluetooth Smart - Pairing and Connecting ==== | ==== 2.1 Bluetooth Smart - Pairing and Connecting ==== | ||
+ | - Enable the Bluetooth setting on your device, but do not pair outside of VictronConnect. | ||
- Open VictronConnect | - Open VictronConnect | ||
- | - On your Phone or Tablet: pull down the screen to initiate a scan. | + | - On your Phone or Tablet: pull down the screen, or tap the refresh button |
- | - On your Computer or Laptop: click the " | + | - On your Computer or Laptop: click the " |
- The first time you attempt to connect the phone will ask to ' | - The first time you attempt to connect the phone will ask to ' | ||
- Connection is complete. | - Connection is complete. | ||
Line 36: | Line 37: | ||
==== 2.2 Changing the Bluetooth Smart PIN code ==== | ==== 2.2 Changing the Bluetooth Smart PIN code ==== | ||
- | **To prevent unauthorised connections to your device we recommended | + | **To prevent unauthorised connections to your device we recommend |
To change the PIN code: First complete your connection; then go to the **Product info** page. To access that page, click the button on the upper right. For some products it will be the settings icon: {{: | To change the PIN code: First complete your connection; then go to the **Product info** page. To access that page, click the button on the upper right. For some products it will be the settings icon: {{: | ||
Line 353: | Line 354: | ||
** Loading demos ** | ** Loading demos ** | ||
- | The Demo library can be accessed | + | The Demo library can be accessed |
