victronconnect:start
victronconnect:start [2018-10-30 14:37] – mvader | victronconnect:start [2020-10-18 05:52] – [10.8 Troubleshooting and FAQ] nlakatos | ||
====== VictronConnect manual ====== | ====== VictronConnect manual ====== | ||
- | Welcome to the VictronConnect Manual. You can use VictronConnect to configure, monitor and diagnose all our products which have built-in Bluetooth Smart or are equipped with a VE.Direct Port. | ||
- | *For a list of products compatible with VictronConnect | + | ===== 1. Introduction ===== |
+ | Welcome to the VictronConnect | ||
- | VictronConnect | + | VictronConnect |
- | {{: | + | It can connect to Victron products via Bluetooth, USB and WiFi/ |
- | VictronConnect is available to users of Windows PCs, macOS X, iOS and Android phones, as well as tablets. | ||
- | ===== 2. Connecting ===== | + | === Documentation === |
+ | See the table of contents for all general VictronConnect information covered in this document. | ||
+ | Other product specific relevant documents are: | ||
+ | ===== 2. Download and installation ===== | ||
+ | VictronConnect is available to users of Windows PCs, macOS X, iOS and Android phones, as well as tablets. | ||
+ | Also, [[https:// | ||
+ | See [[# | ||
+ | ===== 3. Connecting ===== | ||
There are three ways to connect to a Victron product: | There are three ways to connect to a Victron product: | ||
^ Method | ^ Method | ||
- | | Products with built-in | + | | Products with built-in |
| [[ve.direct: | | [[ve.direct: | ||
| [[https:// | | [[https:// | ||
Line 22: | Line 40: | ||
Use the [[# | Use the [[# | ||
- | ==== 2.1 Bluetooth Smart - Pairing and Connecting ==== | ||
- | - Open VictronConnect | + | ==== 3.1 Bluetooth Smart - Pairing and Connecting ==== |
- | - On your Phone or Tablet: pull down the screen to initiate a scan. | + | |
- | If connection was not successful please refer to section [[#9._Troubleshooting|9. Troubleshooting]] below. | + | To connect |
- | Note: Always connect from within VictronConnect. Do not connect from the device' | + | Here is how to connect: |
- | ==== 2.2 Changing | + | - Enable |
- | **To prevent unauthorised connections | + | - Open VictronConnect, |
+ | - On a phone or tablet, pull down the screen, or tap the refresh button | ||
+ | - On a computer or laptop: click the "Scan or Refresh" | ||
+ | - The first time you attempt to connect the phone will ask to pair with the Victron product. Enter the PIN code. The default | ||
+ | - The connection is complete. | ||
- | To change the PIN code: First complete your connection; then go to the **Product info** page. To access that page, click the button on the upper right. For some products it will be the settings icon: {{: | + | If the connection was not successful please refer to section [[# |
+ | ==== 3.2 Bluetooth Smart - Changing the PIN code ==== | ||
+ | To prevent unauthorised connections to your Victron product we recommend you change the PIN code. Avoid using obvious PIN codes such as 111111 or 123456. | ||
+ | To change the PIN code, first, | ||
- | ==== 2.3 Resetting the Bluetooth Smart pin code ==== | ||
- | If the dongle | + | On this page, select the change PIN code button. |
+ | Note that after changing the PIN code, all other phones connected to the Victron product need to have their pairing information refreshed; and first, the old pairing information needs to be removed. See [[#3.4 Bluetooth Smart - Removing from the list of paired devices | section 3.4]] to learn how to remove the pairing information. | ||
+ | ==== 3.3 Bluetooth Smart - Resetting the PIN code ==== | ||
+ | If the PIN code is lost, it can be reset to 000000. The way you reset depends on which product you are using: | ||
=== VE.Direct Bluetooth Smart dongle === | === VE.Direct Bluetooth Smart dongle === | ||
Line 51: | Line 79: | ||
=== Blue Smart Chargers IP22 === | === Blue Smart Chargers IP22 === | ||
- | On the device list: Press and hold the product description | + | On the device list: tap or click the three-dots menu on the right side of the product description. A menu will pop up offering a 'Reset PIN code' option. Click that, and enter the PUK code. The PUK code can be found on the product label, on the back of the product. |
It can also be done on the charger itself:\\ | It can also be done on the charger itself:\\ | ||
Line 59: | Line 85: | ||
=== Blue Smart Chargers IP67 === | === Blue Smart Chargers IP67 === | ||
- | On a desktop (Windows, Mac), 'right click' the product | + | === Smart Solar Charger === |
+ | On the device list: tap or click the three-dots menu on the right side of the product description. A menu will pop up offering | ||
- | === Blue Smart Solar Charger | + | === BMV-712 |
- | On a desktop (Windows, Mac), 'right click' the product | + | === Smart LiFePO4 Batteries === |
- | === BMV-712 Smart === | + | === SmartShunts |
+ | ==== 3.4 Bluetooth Smart - Removing from the list of paired devices ==== | ||
- | On a desktop (Windows, Mac), 'right click' | + | You may want or need to remove |
- | === Smart LiFePO4 Batteries === | + | To remove |
- | On a desktop (Windows, Mac), 'right click' the product description instead of pressing and holding. | + | === Remove Bluetooth pairing |
- | ===== 3. Compatibility notes on operating systems, phones and tablets ===== | + | (click to play, double-click to enter fullscreen mode) |
- | *(Downloads for VictronConnect for users of Windows XP / Vista are still available in archive | + | |
- | On Windows, VictronConnect cannot use Bluetooth Smart to connect to a product. Therefore the only way to connect a Windows computer to a product is to use the VE.Direct to USB interface. | + | {{victronconnect: |
- | The earliest supported macOS version is: 10.10 (OS X Yosemite). | + | === Remove Bluetooth pairing on Android: === |
- | | + | (click to play, double-click to enter fullscreen mode) |
- | To connect to a Victron device over Bluetooth, rather then via USB, the Mac needs to have Bluetooth 4.0 aka Bluetooth Smart. | + | {{victronconnect: |
- | The minimum required Android version to run VictronConnect is 4.1. | + | ===== 4. Phone, tablet and laptop compatibility ===== |
+ | ==== 4.1 Windows PC === | ||
- | The minimum required Android version to connect to a Victron product via Bluetooth is 4.3. | + | VictronConnect requires Windows 7, Windows 8 or Windows 10. For older Windows versions, XP and Vista, check our [[victronconnect: |
- | Required hardware is ARMv7 and later, as well as x86. | + | Note that on Windows, VictronConnect cannot use Bluetooth Smart to connect to a product. Other connection methods, such as USB, or LAN and WiFi do work properly. |
- | === Android 4.1 and 4.2 === | + | ==== 4.2 macOS X === |
- | You may find that USB On-The-Go | + | Todays version of VictronConnect requires macOS version is 10.12 (OS X Sierra), or later. |
- | Even though some devices have Bluetooth 4.0 aka Bluetooth Smart hardware, Android versions earlier than 4.3 are not implemented such that they can be used by VictronConnect. If you are using a device running on version | + | For the older macOS 10.11/10.10/10.9 versions, an (unsupported) previous |
- | === Android | + | To connect to a Victron product with Bluetooth, the Apple Laptop needs to have Bluetooth 4.0 aka Bluetooth Smart. |
+ | ==== 4.3 Android | ||
- | No known issues. | + | Android 5.0 is the minimum version required to run VictronConnect. |
- | === Android 5 === | + | An older version of VictronConnect that works for some users of Android |
- | The pairing does not work on some devices running | + | |
- | Unfortunately this is a bug in Android over which we have no control, and are therefore unable to fix. | + | The required hardware is ARMv7 and later, as well as x86 or ARM64bit. |
+ | === Notes for Android 5 === | ||
+ | Android 5 devices with a 64bit CPU will experience a crash at startup due to an issue in the libraries we use to develop VictronConnect. This is not expected to be fixed. A workaround for this issue is to manually install the VictronConnect APK that can be downloaded in the [[https:// | ||
+ | The pairing does not work on some phones running Android 5. The PIN code popup does not appear, or it appears without a text field to enter the PIN code. If you have this situation, your phone might report that it has been paired with the Victron product - but it has not. | ||
+ | Unfortunately, this is a bug in Android over which we have no control, and are therefore unable to fix. | ||
Line 117: | Line 148: | ||
* Medion tablet with Android 5.0 | * Medion tablet with Android 5.0 | ||
- | === Android 6 and later === | + | === Notes for Android 6 and later === |
- | No known issues. | + | No known issues, when Access to Locations services are enabled. |
- | === Access to location services required? === | + | === Why is Access to location services required? === |
- | Being sensitive to privacy issues at Victron ourselves, we are not happy with this requirement. But there is nothing we can do about it unfortunately. | + | Being sensitive to privacy issues at Victron ourselves, we are not happy with this requirement. But there is nothing we can do about it, unfortunately. More information |
Line 151: | Line 180: | ||
- | ==== 3.4 Apple iOS iPhones and iPads === | + | ==== 4.4 Apple iOS iPhones and iPads === |
- | VictronConnect works on the following iPhones and iPads, which have Bluetooth 4.0 (BT LE).\\ (iOS 8 or later required): | + | VictronConnect works on the following iPhones and iPads running |
- | * iPhone | + | * iPhone |
- | * iPad, 3rd generation and later | + | * iPad mini 2 and later |
+ | * iPad (5th generation) and later | ||
+ | * iPod touch (6th generation) and later | ||
Unfortunately Apple iPhone/iPad doesn' | Unfortunately Apple iPhone/iPad doesn' | ||
- | ===== 4. Application overview ===== | + | ==== 4.5 Linux ==== |
- | ==== 4.1 Screenshots (click to enlarge) ==== | + | Details [[https:// |
+ | ==== 4.6 Archive of previous versions ==== | ||
+ | It would be nice to forever support all existing versions of Android, iOS, Windows, and other systems. But unfortunately, | ||
+ | In such a situation, we recommend updating your phone to the latest OS. For situations where that is not possible we make these older versions available: | ||
+ | **Warning: | ||
+ | |**OS Version** | **Download link** | | ||
+ | | Windows XP and Windows Vista | [[https:// | ||
+ | | Android 4.3 to 4.4.4 armv7 architecture | [[https:// | ||
+ | | Android 4.3 to 4.4.4 x86 architecture | ||
+ | | macOS 10.9 (OS X Mavericks) | [[https:// | ||
+ | | macOS 10.10, 10.11 & 10.12 (OS X Yosemite / Sierra) | [[https:// | ||
+ | ===== 5. Application overview ===== | ||
+ | ==== 5.1 Screenshots (click to enlarge) ==== | ||
- | This page shows all the Victron products that have been discovered by your device, and to which a connection can be made. Click on the desired product. | ||
- | {{: | + | LOCAL - This page shows all the Victron products that have been discovered by your phone, and to which a connection can be made. Click on the desired product. |
+ | VRM - This page will show a GX product if it is connected to your VRM account. | ||
- | From ' | + | From ' |
**Solar Charge Controller pages**\\ | **Solar Charge Controller pages**\\ | ||
- | The ' | + | The ' |
- | To access | + | *To access |
+ | From here you can choose a preset charge algorithm, you can select the charge current; and you can choose to employ the charge algorithm for a Li-ion battery when that is appropriate. | ||
+ | *To access ' | ||
+ | From ' | ||
**Peak Power Pack**\\ | **Peak Power Pack**\\ | ||
- | Here is a VictronConnect app screenshot from a device | + | Here is a VictronConnect app screenshot from a PC using a version of the Microsoft Windows operating system |
Line 231: | Line 297: | ||
- | Here is a VictronConnect app screenshot from a device | + | Here is a VictronConnect app screenshot from a PC running the Mac Operating System |
- | ==== 4.2 Videos ==== | + | ==== 5.2 Videos ==== |
**Blue Smart IP65 Charger ** | **Blue Smart IP65 Charger ** | ||
- | This video will show you how to download the VictronConnect app onto a smart phone (in the video we use an iPhone). It will also show you how to use the app to view information and control the settings of a BlueSmart | + | This video will show you how to download the VictronConnect app onto a smart phone (in the video we use an iPhone). It will also show you how to use the app to view information and control the settings of a Blue Smart IP65 charger. |
Line 252: | Line 318: | ||
{{youtube> | {{youtube> | ||
- | ==== 4.3 Renaming your devices | + | ==== 5.3 Renaming your products |
Line 263: | Line 329: | ||
- | ===== 5. Product alarms & errors ===== | + | |
+ | ==== 5.4 How to disable and re-enable Bluetooth ==== | ||
+ | All our products that have Bluetooth built-in, have a feature that allows disabling Bluetooth. Typically the reason for doing so is security, even though the Bluetooth connection is protected by a PIN code, there is nothing more secure than disabling it. | ||
+ | In most cases, it's also possible to re-enable Bluetooth after disabling. For example by using a VE.Direct cable. | ||
+ | There are, however, a few exceptions: | ||
+ | * The [[# | ||
+ | * The [[# | ||
+ | === Finding the Bluetooth menu === | ||
+ | First, complete your connection; then go to the **Product info** page by clicking the button on the upper right: | ||
+ | * For some products, it will be the settings icon: {{: | ||
+ | * For other products you'll find the {{: | ||
+ | If the product has the feature that Bluetooth can be disabled, you will see the field " | ||
+ | For some products, a Disable button is shown instead of a toggle switch. | ||
+ | === How to re-enable Bluetooth === | ||
+ | There are a few different ways to re-enable Bluetooth depending on your product, always check the manual of your product for more detailed instructions: | ||
+ | == Re-enable Bluetooth using VE.Direct == | ||
+ | Connect the product with a VE.Direct to USB cable to your phone and use VictronConnect to re-enable Bluetooth in the **Product Info** page (see [[# | ||
+ | == Re-enable Bluetooth using the MODE button on the product == | ||
+ | Press and hold the MODE button on the product for 10 seconds will perform a Bluetooth reset. This means that the following actions will be executed: | ||
+ | * Bluetooth will be re-enabled | ||
+ | * The connected Bluetooth product will be disconnected | ||
+ | * The PIN code is reset to its [[# | ||
+ | * The pairing information is cleared; this requires [[victronconnect: | ||
+ | == Lithium Smart batteries == | ||
+ | The product page can be found [[https:// | ||
+ | Once Bluetooth is disabled, it is disabled **permanently** and is **irreversible**. This means that VictronConnect will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth, enter the code displayed, and choose " | ||
+ | == Phoenix Smart IP43 Chargers == | ||
+ | Once Bluetooth is disabled, there are multiple ways to re-enable it again: | ||
+ | - Using the [[# | ||
+ | - Using a [[# | ||
+ | == Blue Smart IP22 Chargers == | ||
+ | Once Bluetooth is disabled, it can be re-enabled with the [[# | ||
+ | == Blue Smart IP65 Chargers == | ||
+ | == Blue Smart IP67 Chargers == | ||
+ | For these chargers there are two options: | ||
+ | * Disable Bluetooth **permanently**. This option is **irreversible** and VictronConnect will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth, enter the code displayed and choose " | ||
+ | * Enable Bluetooth for 30 seconds at power-up. This allows you to connect to the product and to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | ||
+ | == SmartSolar MPPTs == | ||
+ | Bluetooth can be re-enabled by connecting a VE.Direct to USB cable to your phone and following [[# | ||
+ | **Smart Battery Protect**\\ | ||
+ | Bluetooth can be disabled/ | ||
+ | **Smart BMV-712**\\ | ||
+ | The BMV-712' | ||
+ | **Smart BMS**\\ | ||
+ | Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | ||
+ | **Smart Shunt**\\ | ||
+ | ==== 5.5 Importing and converting a GX Product Family database File ==== | ||
+ | VictronConnect for Mac OSX and Windows allows you to import and convert the database log file (that is created by the VenusOS on the GX Product Family) to a Microsoft Excel XLSX file. This can be useful if the site is remote and without an internet connection to upload the file to the [[https:// | ||
+ | This feature is not available in the iOS and Android mobile versions of VictronConnect. | ||
+ | ===== 6. Product alarms & errors ===== | ||
Behind the scenes VictronConnect has a full monitoring system which checks for alarms and errors on the connected product. As soon as an alarm or error is reported by the product, the alarm/error and its description is shown on the live data page.\\ | Behind the scenes VictronConnect has a full monitoring system which checks for alarms and errors on the connected product. As soon as an alarm or error is reported by the product, the alarm/error and its description is shown on the live data page.\\ | ||
(Note that alarms and errors are only shown when the app is active.) | (Note that alarms and errors are only shown when the app is active.) | ||
Line 270: | Line 431: | ||
- | ===== 6. Settings files ===== | + | ===== 7. Settings files ===== |
+ | ==== 7.1 Save, load, share and manage settings ==== | ||
This feature allows you to save product settings to a file so that they can be loaded onto the Victron product you are connected to ...or another product, at a later time. | This feature allows you to save product settings to a file so that they can be loaded onto the Victron product you are connected to ...or another product, at a later time. | ||
Line 282: | Line 446: | ||
- | When the file is loaded the changes | + | When the file is loaded, the changes |
Line 293: | Line 457: | ||
** Settings file manager ** | ** Settings file manager ** | ||
- | The Settings file manager is located in the main menu. | + | The Settings file manager is located in the main menu, and shows all stored settings: |
- | From here files can be opened, shared or removed. | + | From here files can be opened, shared or removed: |
- | ** Open settings file ** | ||
- | When opening a file from the settings file manager a snapshot of the product at the point the setting file was saved is shown. | + | ==== 7.2 Settings files and the demo library ==== |
- | There is a constraint | + | The demo library can be a great tool for an installer to create a set of settings, and then share it to a customer whom can then apply it to their product. |
- | This constraint only applies when opening files from the settings file manager | + | Note that whilst saving settings from the demo library is possible, loading settings from within the demo library is not possible. |
+ | ==== 7.3 Limitation in opening | ||
+ | There are two methods to open a previously stored settings-file: | ||
+ | - From the settings file manager, as in the above screenshot, to see the settings without having to be connected to the product. A snapshot of all data, including voltage readings, history data, and so forth, will be loaded and visible to inspect. | ||
+ | - From the product settings | ||
+ | Note that the first method only works when the settings file is created with the exact same VictronConnect version | ||
+ | ===== 8. Demo feature ===== | ||
VictronConnect contains a library with demonstration settings for all the supported products. | VictronConnect contains a library with demonstration settings for all the supported products. | ||
Line 319: | Line 493: | ||
Line 325: | Line 499: | ||
** Loading demos ** | ** Loading demos ** | ||
- | The Demo library can be accessed | + | The Demo library can be accessed |
Line 331: | Line 505: | ||
- | ===== 8. Firmware updates===== | + | ===== 9. Firmware updates===== |
+ | ==== 9.1 Introduction & automatic updates ==== | ||
+ | __What about updating Firmware on VE.Bus products such as MultiPlus and Quattro? | ||
+ | Please follow this [[https:// | ||
+ | __How can I see what firmware version is available? | ||
+ | First, connect to the product, then go to the **Product info** page. Under the Firmware version if you will see a text informing you if you are using the latest available version or if there is an update available. If a new version is available you can start the update process by pressing the " | ||
+ | Some firmware versions are mandatory, when you connect to the product VictronConnect will prompt to update immediately in case there is a mandatory version available. | ||
+ | __Do I need to be connected to the internet for updating firmware? | ||
+ | No. Updating firmware does **not** require an internet connection, the latest Firmware files are already loaded inside VictronConnect, | ||
+ | __How does it work?__ | ||
+ | After connecting your product, VictronConnect will automatically check whether a mandatory update is available, and in that case, you will be guided through the update procedure before doing anything else. | ||
+ | If an update is available but is not mandatory, you will be able to see your product' | ||
+ | A firmware update - when available - will need to be completed in order to change settings on your Victron product using VictronConnect. | ||
+ | __Will I need to reconfigure my MPPT or BMV after the update?__ | ||
+ | No. The settings of your VE.direct and Bluetooth products will not be affected by the firmware update ...and so you will not need to reconfigure your product after the update. Also, the History data of BMVs and MPPTs will be preserved throughout a firmware update. | ||
+ | ==== 9.2 Updating to a self-supplied firmware file ==== | ||
- | ==== 8.1 Automatic updates==== | + | The previous chapter explained how VictronConnect will automatically update to the latest firmware version. Besides that, it is also possible to update a product with a file that you supply yourself. |
- | After connecting your product, VictronConnect will automatically check whether your product | + | This is not needed very often. Some reasons to do so could be: |
- | The settings of your product will not be affected by the firmware update | + | * Update to a very recent version, that's already available on [[https:// |
+ | * Update a product | ||
- | The History data of BMVs and MPPTs will also be preserved throughout a firmware update. | ||
- | Note that a firmware update - when available - will need to be completed in order to continue using VictronConnect. | + | === Instructions for Windows and MacOS computers |
- | ==== 8.2 Manual updates==== | + | |
- | It is also possible to update a product manually. | + | |
- | ===Windows | + | With your phone and Victron product connected to VictronConnect, |
- | With your device and Victron product paired via VictronConnect, go to the " | + | There is no need to worry about using a wrong file - VictronConnect |
- | ===Android and iOS=== | + | === Instructions for Android and iOS phones and tablets |
- | Due to limitations on a mobile device the process is slightly different from the Windows/Mac routine, | + | The process is slightly different from the Windows/macOS routine, |
- | Firstly, you need to add the desired firmware | + | |
- | **iOS**: The current version | + | Firstly, you need to add the desired firmware file to the VictronConnect firmware library. Firmware files can be added to the library from an email attachment, web browser, Dropbox, file browser, and any kind of app that can handle files. For both iOS and Android the procedure |
- | Go to the app that contains | + | If the message doesn' |
+ | In case you are not sure which file to use, it is not a problem to add multiple files to the library. In the next step, VictronConnect will automatically only show the files that match with the connected product. | ||
+ | Open VictronConnect and, without closing it, switch to the app containing the file, select | ||
+ | Here are screenshot showing the detailed steps: | ||
Line 368: | Line 578: | ||
- | VictronConnect will be opened and should read: "File added to the firmware | + | Now, after adding the firmware file to the library, go to the " |
- | Go to the " | + | |
- | ==== 8.3 Troubleshooting firmware updates ==== | ||
- | A troubleshooting guide relevant to firmware updates can be found in chapter | + | ==== 9.3 Troubleshooting firmware updates ==== |
- | ==== 8.4 Error codes ==== | + | A troubleshooting guide relevant to firmware updates can be found in [[# |
+ | ==== 9.4 Error codes ==== | ||
+ | In spite of our painstaking efforts, sometimes errors occur. | ||
+ | In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible and check that the Bluetooth function is enabled on your phone. | ||
+ | Sometimes you may need to [[# | ||
+ | In the following list, you can check possible errors and descriptions. | ||
+ | Check [[# | ||
**VE.Direct products** | **VE.Direct products** | ||
^Error | ^Error | ||
- | | 3 | No VE.Direct product(s) found. | | + | | D3 | No VE.Direct product(s) found. | |
- | | 4 | Unknown error occurred. Try again and check the product settings once updated. | | + | | D4 | Unknown error occurred. Try again and check the product settings once updated. | |
- | | 10 | Error closing com port. | | + | | D10 | Error closing com port. | |
- | | 20 | Could not start updating, no updatable product found. | | + | | D20 | Could not start updating, no updatable product found. | |
- | | 26 | Updating failed, communication lost. Product | + | | D26 | Updating failed, communication lost. The product |
- | | 29 | Could not start updating, the firmware file is corrupt. | | + | | D29 | Could not start updating, the firmware file is corrupt. | |
- | | 31 | Updating failed, product is unusable. Try again and check the product settings once updated. | | + | | D31 | Updating failed, |
- | | 32 | Could not start updating, entering boot mode failed. | | + | | D32 | Could not start updating, entering boot mode failed. | |
- | | 33 | Could not start updating, the firmware file is not found. | | + | | D33 | Could not start updating, the firmware file is not found. | |
- | | 90 | Could not start updating, firmware is not for this product. | | + | | D90 | Could not start updating, |
- | | 91 | Could not start updating, unknown product found. | | + | | D91 | Could not start updating, |
- | | 92 | Updating failed, erasing firmware failed. | + | | D92 | Updating failed, erasing firmware failed. |
- | | 93 | Error starting firmware after updating. Power cycle (off/on) your product and if that does not help\\ try updating again, and check the product settings once updated. | | + | | D93 | Error starting firmware after updating. Power cycle (off/on) your product and if that does not help\\ try updating again, and check the product settings once updated. | |
- | | 94 | Could not start updating, error reading | + | | D94 | Product updated successfully, but an error occurred |
- | | 95 | Product updated successfully, | + | | D95 | Product updated successfully, |
- | | 96 | Updating failed due to version | + | | D96 | Updating failed due to version |
- | | 97 | Dup executable too old. | | + | | D97 | Dup executable too old. | |
- | | 98 | Firmware file is not a valid dup file. | | + | | D98 | Firmware file is not a valid dup file. | |
- | | 99 | Product updated successfully, | + | | D99 | Product updated successfully, |
- | | 100 | Cannot migrate settings because the application is not active. Manual action required. | | + | | D100 | Cannot migrate settings because the application is not active. Manual action required. | |
** Blue Smart Charger, SmartLithium, | ** Blue Smart Charger, SmartLithium, | ||
^Error ^Description^ | ^Error ^Description^ | ||
- | | 1 | Error reading file. | | + | | B1 | Error reading file. | |
- | | 2 | Victron BLE service not found. Please remove the product from the list of paired devices and retry. | | + | | B2 | Victron BLE service not found. Please remove the product from the list of paired devices and retry. | |
- | | 3 | Dfu BLE service not found. Please remove the product from the list of paired devices and retry. | | + | | B3 | Dfu BLE service not found. Please remove the product from the list of paired devices and retry. | |
- | | 4 | The product disconnected unexpectedly. Perhaps the bond information is no longer valid? Please remove\\ | + | | B4 | The product disconnected unexpectedly. Perhaps the bond information is no longer valid? Please remove\\ |
- | | 5 | A write to the device failed. | | + | | B5 | A write to the device failed. | |
- | | 6 | The product did not activate its bootloader - although it should have. | | + | | B6 | The product did not activate its bootloader - although it should have. | |
- | | 7 | The product did not disconnect - although it should. | | + | | B7 | The product did not disconnect - although it should. | |
- | | 8 | Timeout waiting for access to the Victron BLE service. | | + | | B8 | Timeout waiting for access to the Victron BLE service. | |
- | | 9 | Timeout waiting for access to the Dfu BLE service. | | + | | B9 | Timeout waiting for access to the Dfu BLE service. | |
- | | 10 | Timeout waiting for a response. | | + | | B10 | Timeout waiting for a response. | |
- | | 11 | Timeout while writing to product. Perhaps a pairing | + | | B11 | Timeout while writing to the product. Perhaps a pairing |
- | | 96 | An internal error occurred (Opcode not supported). Please send a service report to Victron Energy. | | + | | B12 | Device was no longer found. Perhaps out of range? Please retry. | |
- | | 97 | The requested encryption is not supported by the product. Please send a service report to Victron Energy. | | + | | B96 | An internal error occurred (Opcode not supported). Please send a service report to Victron Energy. | |
- | | 98 | An internal error occured | + | | B97 | The requested encryption is not supported by the product. Please send a service report to Victron Energy. | |
- | | 99 | The product could not store the firmware in its memory. Please retry, and if the problem persists, please contact Victron Energy. | | + | | B98 | An internal error occurred |
- | | 100 | An internal error occurred (CRC error). Please send a service report to Victron Energy. | | + | | B99 | The product could not store the firmware in its memory. Please retry, and if the problem persists, please contact Victron Energy. | |
- | | 101 | An internal error occurred (Data length error). Please send a service report to Victron Energy. | | + | | B100 | An internal error occurred (CRC error). Please send a service report to Victron Energy. | |
- | | 102 | An internal error occurred (Not allowed). Please send a service report to Victron Energy. | | + | | B101 | An internal error occurred (Data length error). Please send a service report to Victron Energy. | |
+ | | B102 | An internal error occurred (Not allowed). Please send a service report to Victron Energy. | | ||
- | ===== 9. Troubleshooting ===== | + | ** VE.Bus Products ** |
- | ==== 9.1 Cannot find my device | + | ^Error ^Description^ |
+ | |V2 | No product detected. Please check all the cable connections and try again.| | ||
+ | |V3 | An unexpected timeout was triggered. Please check all the cable connections and try again.| | ||
+ | |V4 | Incomplete vff file. Nonce missing. Please make sure you selected a valid update file and try again.| | ||
+ | |V5 | Incomplete vff file. EEPROM lines missing. Please make sure you selected a valid update file and try again.| | ||
+ | |V6 | The vff file contains more eeprom data than supported. Please make sure you selected a valid update file and try again.| | ||
+ | |V7 | The calibration map in the file exceeds the device | ||
+ | |V8 | Device calibration data size bigger than expected. Please make sure you selected a valid update file and try again.| | ||
+ | |V9 | Bootloader did not respond to bootloader setup. Please check all the cable connections and try again.| | ||
+ | |V10 | Bootloader response to version request failed.| | ||
+ | |V11 | Incompatible bootblock. Function version invalid.| | ||
+ | |V12 | Incompatible bootblock. Version invalid.| | ||
+ | |V13 | Bootloader did not start after bootblock update.| | ||
+ | |V14 | Incompatible bootblock type.| | ||
+ | |V15 | No or unexpected response to target id query.| | ||
+ | |V16 | No or unexpected response to eeprom read action.| | ||
+ | |V17 | No or unexpected response to calibration map query.| | ||
+ | |V18 | The supplied firmware contains new unsupported calibration values. \\ The updater does not know how to handle them.| | ||
+ | |V19 | No response received to eeprom write command. Please check all the cable connections and try again.| | ||
+ | |V20 | Invalid response received to eeprom write command. Please check all the cable connections and try again.| | ||
+ | |V21 | No response received to code write command. Please check all the cable connections and try again.| | ||
+ | |V22 | Invalid response received to code write command.| | ||
+ | |V23 | The MK2/MK3 did not respond. Please check all the cable connections and try again.| | ||
+ | |V24 | The connected product does not match the specified model in the file. \\ Please make sure you selected a valid update file and try again.| | ||
+ | |V25 | The hardware revision specific eeprom defaults data is corrupt. \\ Please make sure you selected a valid update file and try again.| | ||
+ | |V26 | Updates can not be performed with a VEBUS BMS connected.| | ||
+ | |V27 | Updates can not be performed with a DMC connected.| | ||
+ | |V40 | Failed to start Update. could not allocate memory. Malloc error.| | ||
+ | |V50 | Failed to start Update. File open error. Please check the file location and access permissions.\\ Make sure you selected a valid update file and try again.| | ||
+ | |V51 | Failed to start Update. File write error. Please check file location and access permissions.\\ Make sure you selected a valid update file and try again.| | ||
+ | |V52 | Failed to start Update. File read error. Please check file location and access permissions.\\ Make sure you selected a valid update file and try again.| | ||
+ | |V53 | Failed to start Update. File checksum error. File corrupted or not a valid VFF file.\\ Please make sure you selected a valid update file and try again.| | ||
+ | |V54 | Failed to start Update. File has an incompatible version number.\\ Please make sure you selected a valid update file and try again.| | ||
+ | |V55 | Failed to start Update. File section not found. File corrupted or not a valid VFF file.\\ Please make sure you selected a valid update file and try again.| | ||
+ | |V56 | Failed to start Update. Format error. File corrupted or not a valid VFF file.\\ Please make sure you selected a valid update file and try again.| | ||
- | * Make sure your device | + | ** All other products (XUP update files)** |
- | * Only one device | + | ^Error ^Description^ |
- | * Make sure you are attempting to connect from //within// VictronConnect - not from the system menu of your phone/tablet/laptop. | + | |X3 |Invalid updater state. Please try again.| |
+ | |X4 |Firmware not for Product (Id). Please make sure you selected a valid update file and try again.| | ||
+ | |X5 |Updater (version) too old. | | ||
+ | |X6 |Communication Error. No Callback handler connected. Please check the connection and try again.| | ||
+ | |X7 |Communication Error. Vreg ack-ed with an unexpected error. | ||
+ | |X8 |Update (xup) file format not supported. Please make sure you selected a valid update file and try again.| | ||
+ | |X9 |File Error. No Instance Blob could be found in the update file. Please make sure you selected a valid update file and try again.| | ||
+ | |X10 |File Error. Invalid instance Blob attribute. Please make sure you selected a valid update file and try again.| | ||
+ | |X11 |File Error. Instance Blob defined more than once. Please make sure you selected a valid update file and try again.| | ||
+ | |X12 |File Error. No Firmware Version for instance found in the update file. Please make sure you selected a valid update file and try again.| | ||
+ | |X13 |Communication Error. Unexpected Vreg Ack received. Please check the connection and try again.| | ||
+ | |X14 |Communication Error. The instance could not be reached. Please check the connection and try again.| | ||
+ | |X15 |Fail on Minimum Firmware Version check. Please make sure you selected a valid update file and try again.| | ||
+ | |X16 |Failed to Begin Update. Please check the connection and try again.| | ||
+ | |X17 |File Error. No/invalid Firmware data found for instance in the update file. Please make sure you selected a valid update file and try again.| | ||
+ | |X18 |Update Error. Invalid ack on non-final Update Data. Please check the connection and try again.| | ||
+ | |X19 |Update Error. Invalid sequence# in Update Data Ack. Please check the connection and try again.| | ||
+ | |X20 |Update Error. Invalid instance# in Update Data Ack. Please check the connection and try again.| | ||
+ | |X21 |Update Error. Invalid ack on final Update Data. Please check the connection and try again.| | ||
+ | |X22 |Verification Error. Invalid Firmware Version Ack. Please check the connection and try again.| | ||
+ | |X23 |Verification Error. Invalid UDF Version Ack. Please check the connection and try again.| | ||
+ | |X24 |Verification Error. Invalid instance field in Minimum Firmware Version Ack. Please check the connection and try again.| | ||
+ | |X25 |Verification Error. Invalid instance field in Firmware Version Ack. Please check the connection and try again.| | ||
+ | |X26 |Verification Error. Invalid instance field in UDF Version Ack.\\ Please check the connection and try again.| | ||
+ | |X27 |Failed to verify Minimum Firmware Version.\\ Please check the connection and try again.| | ||
+ | |X28 |Failed to verify Firmware Version. Please check the connection and try again.| | ||
+ | |X29 |Failed to verify UDF Version. Please check the connection and try again.| | ||
+ | |X30 |Failed on Minimum Firmware Version verification. Please check the connection and try again.| | ||
+ | |X31 |Failed on Firmware Version verification. Please check the connection and try again.| | ||
+ | |X32 |Still in Bootloader Mode after the update. Please try again.| | ||
+ | |X33 |File Error. No Product Id found in the update file. Please make sure you selected a valid update file and try again.| | ||
+ | |X34 |File Error. No VE.Direct baudrates found in the update file. Please make sure you selected a valid update file and try again.| | ||
+ | |X35 |File Error. No Xup Format Version found in the update file. Please make sure you selected a valid update file and try again.| | ||
+ | |X36 |File Error. No Minimum Updater Version found in the update file. Please make sure you selected a valid update file and try again.| | ||
+ | |X37 |File Error. No Firmware (product) Version found in the update file. Please make sure you selected a valid update file and try again.| | ||
+ | |X38 |File Error. The update file does not match XML standard. Please make sure you selected a valid update file and try again.| | ||
+ | |X39 |Communication Error. Vreg Ack timeout. Please check the connection and try again.| | ||
+ | |X40 |Communication Error. No product found. Please check the connection and try again.| | ||
+ | |X41 |Communication Error. Comm port error. Please check the connection and try again.| | ||
+ | |X42 |Update Error. Failed to set baudrate. Please check the connection and try again.| | ||
+ | |X43 |Update Error. Update in progress on another interface.| | ||
+ | |X44 |Update Error. Invalid instance# in Ack. Please check the connection and try again.| | ||
+ | |X45 |Update Error. Vreg Ack error: Invalid instance. Please check the connection and try again.| | ||
+ | |X46 |Update Error. Vreg Ack error. Please check the connection and try again.| | ||
+ | ===== 10. VictonConnect-Remote (VC-R) – Configuration and monitoring via VRM ===== | ||
+ | ==== 10.1 Introduction ==== | ||
+ | VictronConnect-Remote functionality enables Victron products with a VE.Direct interface to be accessed remotely through a [[https:// | ||
+ | This powerful feature allows full product configuration and monitoring from practically anywhere in the world using the VictronConnect app. | ||
+ | The user interface experience is just like the products were connected locally using Bluetooth or a wired VE.Direct to USB interface. | ||
+ | A video demonstrating the feature is available here: | ||
+ | {{youtube> | ||
+ | ==== 10.2 Compatibility ==== | ||
+ | The VictronConnect-Remote feature is ONLY compatible with products connected to a GX product with a VE.Direct interface. | ||
+ | This includes; | ||
+ | * MPPT solar chargers with a VE.Direct interface (SmartSolar and BlueSolar) | ||
+ | * Battery monitors with a VE.Direct interface (BMV and SmartShunt) | ||
+ | * Specific inverters with a VE.Direct interface (Phoenix Inverter VE.Direct and Phoenix Inverter Smart) | ||
+ | * Specific mains chargers with a VE.Direct interface (Phoenix Smart IP43) | ||
+ | Products connected with a VE.Bus interface, such as Multiplus/ | ||
+ | Products connected using a VE.Can interface, such as Lynx Shunt, Skylla chargers, and MPPT solar chargers using a VE.Can interface are also NOT compatible and cannot be configured remotely. | ||
+ | ==== 10.3 Setup ==== | ||
+ | === 10.3.1 Minimum Requirements === | ||
+ | * VictronConnect SW: v5.20 | ||
+ | * GX Product- Venus OS FW: v2.40 (However v2.53 recommended for full functionality) | ||
+ | === 10.3.2 VictronConnect === | ||
+ | - Confirm that the phone has VictronConnect installed and that the software version meets or exceeds the minimum requirements - upgrade if necessary | ||
+ | - Authorize VictronConnect to access your VRM account; | ||
+ | * Open the VictronConnect app | ||
+ | * Swipe across to the VRM tab, then select ‘SIGN IN TO VRM’ | ||
+ | * Complete your email address and VRM password, then select ‘Authorize Victron Connect’ | ||
+ | * If using a tablet or PC your browser may also request permission to open VictronConnect, | ||
+ | === 10.3.3 GX Product === | ||
+ | 1- Confirm that the GX Product is running Venus OS firmware version that meets or exceeds the minimum requirements - upgrade if necessary | ||
+ | 2- Enable ‘VRM two-way communication’ under Device List > Settings > VRM Online Portal | ||
+ | ==== 10.4 Local Tab ==== | ||
+ | The local tab displays all products that are within local Bluetooth and wireless LAN range or physically connected to the phone with VictronConnect (such as with a VE.Direct to USB or MK3 to USB interface cable) | ||
+ | ==== 10.5 VRM Tab ==== | ||
+ | The VRM tab displays all VRM installations associated with the VRM user profile. | ||
+ | Any installation can be selected to access the VRM online portal or connected products. | ||
+ | When a VRM installation is selected it will take a few seconds for a connection to be made, once the connection is established two tabs will appear, an ‘OVERVIEW’ tab and a ‘DEVICES’ tab. | ||
+ | === 10.5.1 Overview Tab === | ||
+ | The ‘OVERVIEW’ tab has an image of the GX product, the name of the VRM installation, | ||
+ | === 10.5.2 Devices Tab === | ||
+ | The ‘DEVICES’ tab has a list of all compatible products that are physically connected to the GX product. | ||
+ | If using a tablet or PC, the ‘DEVICES’ tab is shown as a panel on the right side of the same screen. | ||
+ | ==== 10.6 Remote product access ==== | ||
+ | When a product is selected it will take a few seconds for a connection to be made, once the connection is established live product information/ | ||
+ | Immediately after initial connection settings and historical data will be downloaded, during this time a cloud symbol will remain in the upper right corner (this typically takes less than 30 seconds). | ||
+ | Settings cannot be accessed until the cloud symbol is replaced by the normal settings gear symbol. | ||
+ | ==== 10.7 Signing out ==== | ||
+ | To disable the link between VictronConnect-Remote and your VRM account, expand the main menu and then select ‘Settings’. | ||
+ | In the settings page select ‘SIGN OUT’ and then select ‘OK’ in the prompt window to confirm. | ||
+ | After signing out VictronConnect-Remote will no longer have access to the VRM account or any of the associated VRM installations. To reinstate access the log in procedure needs to be repeated. | ||
+ | ==== 10.8 Troubleshooting and FAQ ==== | ||
+ | == Product not found == | ||
+ | * VictronConnect-Remote is only compatible with products that use a VE.Direct interface to the GX product – see the ‘compatibility’ section. | ||
+ | * Ensure that that the missing product is physically connected to the GX product, with the VE.Direct cable properly installed at both ends. | ||
+ | * Ensure that the product is running a recent firmware version. | ||
+ | == Installation/ | ||
+ | * Confirm that the installation is currently online and communicating with the VRM online portal. | ||
+ | * Ensure that the installation is linked to the VRM account used during initial VictronConnect-Remote sign in to VRM. | ||
+ | * Ensure that ‘VRM two-way communication’ is enabled – see the ‘settings’ section. | ||
+ | * Ensure that the GX product is running the minimum compatible Venus OS firmware version – see the ‘settings’ section. | ||
+ | == VictronConnect has no VRM tab == | ||
+ | * Ensure that the phone is running the minimum compatible VictronConnect software version – see the ‘settings’ section. | ||
+ | == VRM account == | ||
+ | * It is necessary to have an active VRM account linked to your installation and any others that you intend to monitor or configure using VictronConnect-Remote - creating a new account is quick and easy. | ||
+ | * For further information in relation to VRM (Victron Remote Management) see [[https:// | ||
+ | == Systems with no GX product == | ||
+ | * VictronConnect-Remote functionality is not possible unless the system includes a GX product. A GX product can be easily added to any system and there are a [[https:// | ||
+ | == Installations with no internet connection == | ||
+ | * VictronConnect-Remote functionality is not possible unless the GX product at the installation site has an active internet connection. | ||
+ | * For remote sites without an existing internet connection or with mobile installations, | ||
+ | == Large systems == | ||
+ | * The use of the VictronConnect-Remote feature will slightly increase the GX product CPU load. | ||
+ | * In some large/ | ||
+ | * It is important to select a GX product that has sufficient performance capability in relation to the system design, for example, a Cerbo GX has significantly more processing power than a Color Control GX and is much better suited to large/ | ||
+ | == VictronConnect Remote troubleshooting == | ||
+ | VictronConnect will report errors encountered during communication attempts with VRM in a message box with an error code (e.g. #R999, or #V2). The numeric part of the code can have one of the following value: | ||
+ | ^Error ^Description^ | ||
+ | |999 | Call to retrieve a list of child devices expired (60 seconds). The most common cause is a bad internet connection. | | ||
+ | | 1 | ||
+ | | 2 | VRM encountered temporary difficulties. Try again in a while. It could also indicate issues with your credentials. | | ||
+ | | 3 | Error accessing network. Please check your network connection. | | ||
+ | | 8 | An error occurred with the network (e.g., the network cable was accidentally plugged out). | | ||
+ | | 13 | Proxy authentication error. VictronConnect does not support communication over proxy. | | ||
+ | | 14 | Failed to establish a secure connection to VRM. | | ||
+ | |65538| VRM MQTT broker is not responding. Please try again in a while. | | ||
+ | There are also other error codes that could be reported. They are a result of internal errors in VictronConnect and/or VRM. In case these errors persist after a retry, please create a " | ||
+ | VictronConnect Remote is establishing communication with a range of services on the ' | ||
+ | ===== 11. Troubleshooting ===== | ||
+ | ==== 11.1 Common Bluetooth problems and how to solve them === | ||
+ | The #1 first step before attempting any of the specific troubleshooting advice below is to power down and then restart all related devices. This includes closing the software, restarting the phone, and Victron product. This will solve most issues. | ||
+ | For example, with Victron MPPTs you must isolate the MPPT from both battery and solar voltage so that no lights appear, before reconnecting it again. | ||
+ | == I cannot find my product listed == | ||
+ | * Make sure that you have a " | ||
+ | * If a firmware update failed, the product //Custom Name// might have reverted to its original name and serial number, check if that is the case. Once the update is completed, the //Custom Name// will be back. See more tips about troubleshooting firmware updates on [[start# | ||
+ | * Only one phone can be connected to a product | ||
+ | * Make sure you are attempting to connect from //within// VictronConnect - not from the system menu of your phone. If you have connected from the system menu: close VictronConnect, | ||
+ | == I can see but not connect to my product == | ||
+ | - Make sure you are trying to connect to the right product. See [[start# | ||
+ | - Make sure your product is in range. It can be that you are close enough to see the product but not close enough to connect to it. If you are using a Smart model with built in Bluetooth, and you are unable to move it, or get closer to it with your phone, it may be possible to increase the Bluetooth range by using an additional VE.Direct to Bluetooth dongle accessory and placing that closer to you. | ||
+ | - Make sure that Bluetooth is still enabled on your phone. If Bluetooth was disabled after scanning, you may be able to see your product listed but you won't be able to connect to it. | ||
+ | - Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the product, or if your Victron product has been connected to too many phones. The product will only remember the last 10 phones connected to it. To solve this, remove the pairing completely from your phone system menu. Then open VictronConnect and re-pair the product and your phone. Watch these instructional videos to learn how to remove the pairing on {{victronconnect: | ||
+ | - If you are using an Android phone, check [[start# | ||
+ | === Connection fails around 20% === | ||
+ | - Make sure you are up to date with the latest version of VictronConnect. | ||
+ | - [[https:// | ||
+ | - Then [[https:// | ||
+ | - Force close the VictronConnect app. Instructions: | ||
+ | - Reconnecting in VictronConnect using the default PIN 000000 | ||
- | If none of the above helps, and if your device is already paired to a product, remove the pairing completely from your phone/ | + | ==== 11.2 Bluetooth connection issues on Android ==== |
- | ==== 9.2 Bluetooth connection issues on Android | + | |
- | === Step 1: Check that your device | + | === Step 1: Check that your phone is supported === |
- | See section [[# | + | See section [[# |
=== Step 2: Check the Android version === | === Step 2: Check the Android version === | ||
Line 459: | Line 961: | ||
- | On Android 5 and later VictronConnect needs access to the device | + | On Android 5 and later VictronConnect needs access to the phone' |
Line 465: | Line 967: | ||
=== Step 4. Enable Location (or GPS) functionality in the system settings === | === Step 4. Enable Location (or GPS) functionality in the system settings === | ||
- | For Bluetooth scanning to work, the Location (or GPS) functionality on the device | + | For Bluetooth scanning to work, the Location (or GPS) functionality on the phone needs to be enabled. |
+ | === Step 5. Search & connect from within VictronConnect, | ||
+ | === Step 6. Pin-code pop-up never shows === | ||
+ | On some Android phones, the PIN code pop-up dialog doesn' | ||
+ | Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code. | ||
+ | On Android it is also possible that other apps prevent the PIN code pop-up from showing, even when pairing in the Android Bluetooth settings menu. One such an app is "FrSky Free Link", which even blocks pairing with Bluetooth headsets. In this case, the thing to do is remove the problematic app. This can be done by uninstalling apps one by one (starting with apps that use or connect to Bluetooth devices), removing all apps or even resetting the phone to factory defaults. When the Victron products are paired to the phone/ | ||
+ | The default pin-code is 000000, six times zero. | ||
+ | === Step 7. Try another phone at first === | ||
- | === Step 5. Search & connect from within VictronConnect ...NOT from the system Bluetooth menu === | + | If you are still experiencing difficulties, |
- | === Step 6. Try another phone at first === | + | When successfully connected using another phone, VictronConnect will automatically update the firmware in the Victron Bluetooth product. After the firmware has been updated you may find that you can use the Android phone with which you were experiencing difficulties. |
- | If you are still experiencing difficulties, | + | ==== 11.3 Problems during firmware updating ==== |
- | When successfully connected using another device, VictronConnect will automatically update | + | First of all, it's good to know that you can always restart |
- | First of all, its good to know that you can always restart | + | Keep your phone as close to the product as possible. If the update |
- | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. Keep your mobile device as close to the product as possible. If the update fails even after many attempts, try using another phone or tablet | + | If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. If the update fails even after many attempts, try using another phone or tablet, if possible an Apple iOS phone - they usually work without any issues. After the update, you may find that you can use the phone with which you were having difficulty. |
- | When the firmware update fails at 4% or less, VictronConnect cannot make the device | + | When the firmware update fails at 4% or less, VictronConnect cannot make the product |
__ Solution for Blue Smart IP65 Chargers __ | __ Solution for Blue Smart IP65 Chargers __ | ||
Line 500: | Line 1017: | ||
* The firmware update screen will appear again. You should now be able to update the dongle to the latest firmware version. | * The firmware update screen will appear again. You should now be able to update the dongle to the latest firmware version. | ||
- | ==== 9.4 VE.Direct USB driver problem on macOS X 10.9 (Mavericks) ==== | + | ==== 11.4 VE.Direct USB driver problem on macOS X 10.9 (Mavericks) ==== |
The driver included in macOS X 10.9 " | The driver included in macOS X 10.9 " | ||
Line 521: | Line 1038: | ||
- | ==== 9.5 VictronConnect on Windows doesn' | + | ==== 11.5 VictronConnect on Windows doesn' |
Line 527: | Line 1044: | ||
The necessary drivers are available in the [[https:// | The necessary drivers are available in the [[https:// | ||
- | ==== 9.6 VictronConnect on Android doesn' | + | ==== 11.6 VictronConnect on Android doesn' |
- | VictronConnect needs to be running before | + | VictronConnect needs to be running before |
- | Open VictronConnect and without closing it switch to the app containing the file, select it an choose to open it with VictronConnect. | + | Open VictronConnect and without closing it switch to the app containing the file, select it and choose to open it with VictronConnect. |
- | ===== 10. Compatible Victron products ===== | + | ==== 11.7 How to create a VictronConnect Service Report |
- | ==== SmartSolar MPPT Charge controllers | + | If you are experiencing issues with VictronConnect or your Victron product, you may be asked to create a " |
+ | Please note that this service report is for Victron internal use and is not able to be read or used for any other purpose than developer troubleshooting. | ||
+ | To do this, | ||
+ | - Open VictronConnect | ||
+ | - Perform the action that leads to the bug or issue | ||
+ | - Return to the main menu | ||
+ | - Select the three lines menu | ||
+ | - Select Settings | ||
+ | - Click or tap CREATE SERVICE REPORT | ||
+ | - Save, email, or copy the file to Victron, via email or the Victron Community. | ||
+ | If you require more detailed power system diagnostic information, | ||
+ | ==== 11.8 VE.Bus firmware update fails at 5% on macOS ==== | ||
+ | There is a known issue that makes VE.Bus firmware updates randomly fail on some macOS laptops. We are working on it; a new VictronConnect version fixing this issue is expected in the near future. Meanwhile this is the workaround for this: | ||
+ | Proceed to update as usual and quickly minimise the VictronConnect window when progress bar is shown because the update starts. After ~20 seconds you can maximise VictronConnect to see the update status. (1) | ||
+ | This issue was introduced in VictronConnect v5.9. | ||
+ | (1) For those with a technical background and wondering how, why and what minimising has to do with this: yes this really works, and relates to a power saving mode that has a side effect on serial communication. | ||
+ | ===== 12. Compatible Victron products ===== | ||
+ | ==== Solar Chargers ==== | ||
+ | === SmartSolar MPPT Charge controllers === | ||
^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | ^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | ||
| MPPT 75/10 | [[https:// | | MPPT 75/10 | [[https:// | ||
Line 563: | Line 1111: | ||
The same models, but then with a different part number do support using both the VE.Direct port and the built-in Bluetooth Smart function at the same time. As do all other SmartSolar MPPT models. | The same models, but then with a different part number do support using both the VE.Direct port and the built-in Bluetooth Smart function at the same time. As do all other SmartSolar MPPT models. | ||
- | ==== Blue Smart IP22 Chargers ==== | + | === BlueSolar MPPT Charge controllers === |
- | | BMV-700 | + | |
- | | BMV-702 | + | |
- | | BMV-712 | + | |
- | ==== BlueSolar MPPT Charge controllers | + | |
| MPPT 70/15 | Not compatible || | | MPPT 70/15 | Not compatible || | ||
Line 613: | Line 1125: | ||
| MPPT 150/70 Tr and MC4 VE.Direct (*) | [[https:// | | MPPT 150/70 Tr and MC4 VE.Direct (*) | [[https:// | ||
| MPPT 150/85 Tr and MC4 VE.Direct | | MPPT 150/85 Tr and MC4 VE.Direct | ||
+ | | MPPT 150/70 CAN-bus | Not compatible || | ||
+ | | MPPT 150/85 CAN-bus | Not compatible || | ||
| MPPT 150/100 Tr and MC4 | [[https:// | | MPPT 150/100 Tr and MC4 | [[https:// | ||
- | (*) Note that we have two different models of 150/70 and 150/85 Solar Chargers: | ||
+ | ==== Battery Chargers ==== | ||
+ | ^ Blue Smart IP22 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All Blue Smart IP22 Chargers | ||
+ | ^ Blue Smart IP65 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | Blue Smart IP65 12/25 Charger | ||
+ | | Blue Smart IP65 24/13 Charger | ||
+ | | Other Blue Smart IP65 Chargers | ||
+ | ^ Blue Smart IP67 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All Blue Smart IP67 Chargers | ||
+ | ^ Phoenix Smart IP43 ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All Phoenix Smart IP43 Chargers | Yes | Yes - Built in | Yes | No | No | | ||
+ | ^ IMPULSE-II Smart ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Bluetooth on/ | ||
+ | | All IMPULSE-II Smart Chargers | ||
+ | | BMV-700 | ||
+ | | BMV-702 | ||
+ | | BMV-712 | ||
Line 658: | Line 1196: | ||
Line 672: | Line 1206: | ||
- | This section applies to MultiPlus, MultiPlus-II, | ||
- | In order to keep this section | + | This section |
- | The minimal required version of the VE.Bus | + | In order to keep this section short, all these products are referred to as VE.Bus products. |
+ | The minimal required version of the VE.Bus | ||
- | Mixed systems (1954208 in parallel to 2654208) are not supported by vebus-interface, | + | Mixed systems (1954208 in parallel to 2654208) are not supported by vebus-interface, |
- | To connect via USB, an [[https:// | + | Inverter/ |
- | To connect wirelessly, the [[https:// | + | - Using USB, this requires the [[https:// |
- | + | - Wirelessly, over Bluetooth. Requires | |
- | The supplied | + | |
- | For systems with a Venus-device | + | For systems with a [[venus-os:start|GX product]] |
- | ===== 11. DISQUS ===== | + | |
