victronconnect:start
victronconnect:start [2019-12-20 16:17] – [10.6 VictronConnect on Android doesn't show files oppened from email or file manager apps] marmour | victronconnect:start [2020-02-04 12:00] – [IMPULSE-II Smart Charger] mbosma | ||
Line 205: | Line 205: | ||
| Android 4.3 to 4.4.4 x86 architecture | | Android 4.3 to 4.4.4 x86 architecture | ||
| macOS 10.9 (OS X Mavericks) | [[https:// | | macOS 10.9 (OS X Mavericks) | [[https:// | ||
+ | | macOS 10.10, 10.11 & 10.12 (OS X Yosemite / Sierra) | [[https:// | ||
Line 345: | Line 347: | ||
**Via VE.Direct: | **Via VE.Direct: | ||
- | **Smart Chargers:** In all smart chargers, Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled. | + | **[[https:// |
- | //Chargers | + | **[[https://www.victronenergy.com/ |
+ | **Chargers with a MODE button:** | ||
Press and hold the MODE button for 10s will reset Bluetooth: | Press and hold the MODE button for 10s will reset Bluetooth: | ||
- Disconnect active device | - Disconnect active device | ||
Line 699: | Line 702: | ||
=== Connection fails around 20% === | === Connection fails around 20% === | ||
- | [[https:// | + | 1. Make sure you are up to date with the latest version of VictronConnect. |
+ | 2. [[https:// | ||
+ | 3. Then [[https:// | ||
+ | 4. Force close the VictronConnect app, and then try reconnecting in VictronConnect using the default PIN 000000 | ||
+ | 5. Then [[https:// | ||
==== 10.2 Bluetooth connection issues on Android devices ==== | ==== 10.2 Bluetooth connection issues on Android devices ==== | ||
Line 856: | Line 867: | ||
==== Blue Smart IP22 Chargers ==== | ==== Blue Smart IP22 Chargers ==== | ||
- | ^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | + | ^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth |
- | | All Blue Smart IP22 Chargers | No | Yes - Built in | | + | | All Blue Smart IP22 Chargers | No | Yes - Built in | No | No | |
==== Blue Smart IP65 Chargers ==== | ==== Blue Smart IP65 Chargers ==== | ||
- | | All Blue Smart IP65 Chargers | + | | Blue Smart IP65 12/25 Charger |
+ | | Blue Smart IP65 24/13 Charger | ||
+ | | Other Blue Smart IP65 Chargers | No | Yes - Built in | No | No | ||
==== Blue Smart IP67 Chargers ==== | ==== Blue Smart IP67 Chargers ==== | ||
- | | All Blue Smart IP67 Chargers | + | | All Blue Smart IP67 Chargers |
- | ==== Orion-Tr Smart DC-DC Charger Isolated ==== | ||
- | ^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | ||
- | | All Orion-Tr Smart DC-DC Isolated Chargers | ||
==== Phoenix Smart IP43 Charger ==== | ==== Phoenix Smart IP43 Charger ==== | ||
- | | All Phoenix Smart IP43 Chargers | + | | All Phoenix Smart IP43 Chargers |
+ | ==== IMPULSE-II Smart Charger ==== | ||
+ | ^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ Charge cycle history ^ Advanced settings ^ | ||
+ | | All IMPULSE-II Smart Chargers | ||
==== Battery Monitors ==== | ==== Battery Monitors ==== |
