victronconnect:start
victronconnect:start [2019-10-30 14:06] – [10.1 Common Bluetooth problems and how to solve them] evandromrvictronconnect:start [2019-12-09 19:42] – [4.2 macOS X] mvader
Line 127: Line 127:
 ==== 4.2 macOS X === ==== 4.2 macOS X ===
-VictronConnect requires macOS version is 10.12 (OS X Sierra), or later.+Todays version of VictronConnect requires macOS version is 10.12 (OS X Sierra), or later.
 For the older macOS 10.11/10.10/10.9 versions, an (unsupported) previous version of VictronConnect is still available in the Apple Store. For the older macOS 10.11/10.10/10.9 versions, an (unsupported) previous version of VictronConnect is still available in the Apple Store.
Line 356: Line 356:
   - This applies to:   - This applies to:
     - Phoenix Smart IP43     - Phoenix Smart IP43
-    - Skylla-S
     - Blue Smart IP22     - Blue Smart IP22
     - Blue Smart IP65     - Blue Smart IP65
Line 453: Line 452:
 ===== 9. Firmware updates===== ===== 9. Firmware updates=====
 ==== 9.1 Introduction & automatic updates ==== ==== 9.1 Introduction & automatic updates ====
 +__What about updating Firmware on VE.Bus devices such as MultiPlus and Quattro?__
 +Please follow this [[https://docs.victronenergy.com/victronconnect-vebus.html#firmware-updates|seperate Firmware guide for updating products such as MultiPlus and Quattro that use a VE.Bus connection]] via an MK3-USB adaptor, instead of VE.direct or Bluetooth.
 __How can I see what firmware version is available?__ __How can I see what firmware version is available?__
Line 470: Line 473:
 A firmware update - when available - will need to be completed in order to continue using VictronConnect. A firmware update - when available - will need to be completed in order to continue using VictronConnect.
-__Will I need to reconfigure my device after the update?__ +__Will I need to reconfigure my MPPT or BMV after the update?__
-No. The settings of your product will not be affected by the firmware update ...and so you will not need to reconfigure your product after the update. Also, the History data of BMVs and MPPTs will be preserved throughout a firmware update. +
 +No. The settings of your VE.direct and Bluetooth products will not be affected by the firmware update ...and so you will not need to reconfigure your product after the update. Also, the History data of BMVs and MPPTs will be preserved throughout a firmware update.
 ==== 9.2 Updating to a self-supplied firmware file ==== ==== 9.2 Updating to a self-supplied firmware file ====
Line 686: Line 687:
 == I can see but not connect to my device ==  == I can see but not connect to my device ==
-  Make sure you are trying to connect to the right device. See [[start#renaming_your_devices | section 4.3]] to learn how you can give your device a //Custom Name//. +  Make sure you are trying to connect to the right device. See [[start#renaming_your_devices | section 4.3]] to learn how you can give your device a //Custom Name//.
-  Make sure your device is in range. It can be that you are close enough to see the device but not close enough to connect to it. +  Make sure your device is in range. It can be that you are close enough to see the device but not close enough to connect to it.
-  Make sure that Bluetooth is still enabled in your phone/tablet/laptop. If Bluetooth was disabled after scanning, you may be able to see your device listed but you won't be able to connect to it. +  Make sure that Bluetooth is still enabled in your phone/tablet/laptop. If Bluetooth was disabled after scanning, you may be able to see your device listed but you won't be able to connect to it.
-  The Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the device, or if your Victron device has been connected to too many phones/tablets/Laptops. The device will only remember the last 10 phones/tablets/laptops connected to it. To solve this, remove the pairing completely from your phone/tablet/laptop system menu. Then open VictronConnect and re-pair the product and your device. Watch these instructional videos to learn how to remove the pairing on {{victronconnect:video_unpair_android_cropped.mp4?linkOnly | Android}} or {{victronconnect:video_unpair_ios.mp4?linkOnly | iOS}} devices. +  The Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the device, or if your Victron device has been connected to too many phones/tablets/Laptops. The device will only remember the last 10 phones/tablets/laptops connected to it. To solve this, remove the pairing completely from your phone/tablet/laptop system menu. Then open VictronConnect and re-pair the product and your device. Watch these instructional videos to learn how to remove the pairing on {{victronconnect:video_unpair_android_cropped.mp4?linkOnly | Android}} or {{victronconnect:video_unpair_ios.mp4?linkOnly | iOS}} devices.
-  If you are using an Android phone/tablet, check [[start#bluetooth_connection_issues_on_android_devices| section 9.2]] below for issues particular to Android.+  If you are using an Android phone/tablet, check [[start#bluetooth_connection_issues_on_android_devices| section 9.2]] below for issues particular to Android.
 +=== Connection fails around 20% ===
 +[[https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_removing_from_the_list_of_paired_devices|Remove the device from the paired devices list]] in the phones Bluetooth settings. [[https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_changing_the_pin_code|Then change the PIN code.]]
 ==== 10.2 Bluetooth connection issues on Android devices ==== ==== 10.2 Bluetooth connection issues on Android devices ====
Line 969: Line 972:
 For systems with a [[venus-os:start|GX device]] installed, and running firmware version 415 or newer, switching between on/off/charger-only and setting the input current limit IS possible. For systems with a [[venus-os:start|GX device]] installed, and running firmware version 415 or newer, switching between on/off/charger-only and setting the input current limit IS possible.
