victronconnect:start
victronconnect:start [2019-09-22 11:42] – [4.3 Android devices] guy_stewart | victronconnect:start [2019-10-21 13:24] – [3.2 Bluetooth Smart - Changing the PIN code] bob | ||
Line 57: | Line 57: | ||
On this page, select the change pin code button. | On this page, select the change pin code button. | ||
- | Note that after changing the pin code, all other phones, tablets, and laptops connected to the Victron product need to have their pairing information refreshed; and first, the old pairing information needs to be removed. See [[start#removing_the_product_from_the_list_of_paired_devices | + | Note that after changing the pin code, all other phones, tablets, and laptops connected to the Victron product need to have their pairing information refreshed; and first, the old pairing information needs to be removed. See [[#3.4 Bluetooth Smart - Removing from the list of paired devices |
Line 129: | Line 129: | ||
Android 5.0 is the minimum version required to run VictronConnect. | Android 5.0 is the minimum version required to run VictronConnect. | ||
- | (An older version of VictronConnect for users of Android 4.x is still available in [[https:// | + | (An older version of VictronConnect |
Required hardware is ARMv7 and later, as well as x86 or ARM64bit. | Required hardware is ARMv7 and later, as well as x86 or ARM64bit. | ||
Line 751: | Line 751: | ||
+ | ==== 10.8 VE.Bus firmware update fails at 5% on macOS ==== | ||
+ | There is a known issue that makes VE.Bus firmware updates randomly fail on some macOS laptops. We are working on it; a new VictronConnect version fixing this issue is expected in the near future. Meanwhile this is the workaround for this: | ||
+ | Proceed to update as usual and quickly minimise the VictronConnect window when progress bar is shown because the update starts. After ~20 seconds you can maximise VictronConnect to see the update status. (1) | ||
+ | This issue was introduced in VictronConnect v5.9. | ||
+ | (1) For those with a technical background and wondering how, why and what minimising has to do with this: yes this really works, and relates to a power saving mode that has a side effect on serial communication. | ||
===== 11. Compatible Victron products ===== | ===== 11. Compatible Victron products ===== | ||
Line 791: | Line 800: | ||
^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | ^ ^ USB via VE.Direct port ^ Wireless Via Bluetooth ^ | ||
| All Blue Smart IP67 Chargers | | All Blue Smart IP67 Chargers | ||
+ | ==== Phoenix Smart IP43 Charger ==== | ||
+ | | All Phoenix Smart IP43 Chargers | ||
