victronconnect:mppt-solarchargers [2018-01-24 16:22] – [5. Programmable relay] rvanzundert | victronconnect:mppt-solarchargers [2021-09-30 07:16] (current) – guystewart | ||
- | More general information about the VictonConnect App - how to install it; how to pair it with your device; and how to update firmware, for example - can be found by referring to the [[victronconnect: | + | |
- | * **Solar ' | + | |
- | * **Battery | + | |
- | * Bulk: During this stage the Controller delivers as much charge | + | |
- | * Absorption: During this stage the Controller switches to the constant voltage mode, where a pre-set absorption voltage, suitable to the battery type (See section 4.1 Battery Settings below), is applied. When the charge current decreases below the Tail current and/or the pre-set Absorption time has elapsed, the battery is fully charged. The Controller switches to the Float stage. The Tail current is 1A for models | + | |
- | * Float: During this stage the float voltage is applied to the battery to maintain a fully-charged state. | + | |
- | * Equalization: | + | |
- | **Errors**\\ | + | |
- | Shows the number of errors (if any) for the day, to see the error codes click on the orange point. See [[:mppt-error-codes|]].\\ (You may need to slide the display on your device up to see the errors.) | + | |
- | **Total **\\ | + | |
- | By selecting //Edit Presets//, custom parameters can be set as follows: | + | |
- | === Absorption Voltage === | + | |
- | === Absorption time limit (hh:mm) === | + | |
- | The maximum duration of the absorption period is determined by the battery voltage as measured just before the solar charger begins operation each morning (12V battery assumed): | + | |
- | | Vb < 11.9V | + | |
- | | Vb > 12.6V | + | |
- | The maximum absorption times shown in the last column are based on the default absorption time limit of 6 hours. | + | |
- | === Auto Equalization === | + | |
- | * 1 = daily | + | |
- | When the Automatic equalization cycle has initiated, the charger applies an equalization voltage to the battery as long as the current level stays below 8% (Gel or AGM) or 25% (tubular plate) of the bulk current. | + | |
- | === Start Equalization now === | + | |
- | Selecting 'Start Equalization now' allows manual initiation of an Equalization cycle. To allow the charger to equalize the battery properly use the manual equalize option only during absorption and float periods, and when there is sufficient sunlight. Current and voltage limits are identical to the automatic equalize function. The duration of the equalisation cycle is limited to a maximum of 1 hour when triggered manually. Manual equalization can be stopped at any time by selecting 'Stop Equalize' | + | |
- | The configured coefficient is in mV per degree Celsius for the whole battery bank, not per cell. | + | |
- | Note that the temperature compensation is not dynamic during operation. The charger uses its internal temperature for battery temperature compensation when the charger has been idle for at least one hour, i.e. when the charger is not actively charging a battery or supplying a load. | + | |
- | - **Always off** | + | |
- | - **Always on** | + | |
- | Note that, by default, the models with a load output have their algorithm selected with a jumper in the VE.Direct port.See VE.Direct Rx pin configuration (**4.5** below) for information on how to disable that. | + | |
- | The Streetlight function allows you to automatically control night lighting - it's duration, and brilliance. When the Streetlight function is enabled a timer program can be created whereby ' | + | |
- | - Take no action (light remains off). | + | |
- | - Turn the light on, and then off after a chosen number of hours. Two dim-levels can be entered ...one for the " | + | |
- | - Turn the light on ...and then off at (solar) midnight. (Note that 12 o' clock midnight differs from the solar midnight - which is the mid-point between sunset and sunrise. The charger will need to operate for several days to synchronize with the solar activity in your area.) Two dim-levels can be entered: one for the " | + | |
- | - Turn the light on, and then off at sunrise. Note when this option is chosen the sunrise control actions are no longer shown. | + | |
- | - Turn the light off at sunrise. | + | |
- | - Turn the light on for a chosen number of hours before sunrise; and then turn the light off at sunrise. Note that the charger needs to synchronize with the solar activity in order to predict the time of sunrise. This takes several days. | + | |
- | For example, completing the '// | + | |
- | ^At Sunset. | + | |
- | ^Dim level at sunset. | + | |
- | ^Keep lights on during. | + | |
- | ^Dim level at end. | |// | + | |
- | ^At Sunrise. | + | |
- | NB: This dim-levels menu only appears when the TX port function is set to PWM (see **4.4** below). | + | |
- | After making your settings the charger will use 'local time' for 5 days whilst synchronising with solar activity. During this period the charger should remain powered-up. If not, it will work on the assumption that midnight occurs 6 hours after sunset and will continue with this assumption until local synchronisation has taken-place. | + | |
- | The lighting controller (timer) program is written to non-volatile memory, so the program will remain intact when the charger is disconnected from the battery. | + | |
- | When entering a ' | + | |
- | === Night and day detection === | + | |
- | The default setting is 0 (use built-in default voltages) | + | |
- | Using the ' | + | |
- | The gradual dimming option can be used to slow down the response of the timer program. This is useful when multiple chargers are used in a row, and helps to mask the fact that each timer uses its own detection and the transition moment which will vary from unit to unit. | + | |
- | *A setting of ' | + | |
- | Notes: | + | |
- | The Rx pin on the VE.Direct connector can be used for other functions. This functionality was introduced in firmware version 1.17 and applies to the 10A, 15A and 20A chargers with a load output. | + | |
- | - **Load output configuration (This is the default setting on the following models: 75/10, 75/15, 100/15 and 100/20)**. The Tx pin can be used to place a jumper to select load output operation. See Load output chapter (**4.2** above) for details. | + | |
- | - C (Common) | + | |
victronconnect/mppt-solarchargers.1516807366.txt.gz · Last modified: 2018-01-24 16:22 by rvanzundert
