| victronconnect:mppt-solarchargers [2020-01-02 07:17] – [3. HISTORY - Thirty-day Graphic] guy_stewart | victronconnect:mppt-solarchargers [2021-09-30 05:16] (current) – guystewart | ||
| Line 1: | Line 1: | ||
| - | ====== VictronConnect - MPPT Solar Charge Controllers ====== | + | Moved to: https:// |
| - | ===== 1. Introduction ===== | + | |
| - | Thank you for using VictronConnect. This guide will help you get the most out of your MPPT Solar Charge Controller. The information available here applies | + | |
| - | More general information about the VictonConnect App - how to install it; how to pair it with your device; and how to update firmware, for example - can be found by referring to the overall [[victronconnect: | + | |
| - | Note: Where battery voltage is referred to in these instructions, | + | |
| - | ===== 2. STATUS - Live Data Information ===== | + | |
| - | * **MPPT [Model Number]** | + | |
| - | * **Solar ' | + | |
| - | * **Battery | + | |
| - | * **Battery - Current** This reading shows the current flowing-to, or drawn-from the battery terminals of the Solar charger. Note that in the case of the 100/20 Solar chargers and smaller - which have a dedicated load output - a Positive notation alongside the current reading means that current is flowing to the battery; whereas a Negative notation means that current is being drawn from the battery. | + | |
| - | * **Battery - State**: | + | |
| - | * Bulk: During this stage the Controller delivers as much charge | + | |
| - | * Absorption: During this stage the Controller switches to the constant voltage mode, where a pre-set absorption voltage, suitable to the battery type (See section 4.1 Battery Settings below), is applied. When the charge current decreases below the Tail current and/or the pre-set Absorption time has elapsed, the battery is fully charged. The Controller switches to the Float stage. The Tail current is 1A for models | + | |
| - | * Float: During this stage the float voltage is applied to the battery to maintain a fully-charged state. When the battery voltage drops below float voltage during at least 1 minute, a new charge cycle will be triggered. | + | |
| - | * Equalization: | + | |
| - | === * Menu items only available on models with load output (100/20 and smaller.) === | + | |
| - | * **Load output on/ | + | |
| - | * **Load current** | + | |
| - | Note that for the load output reading to be reliable, all loads must be wired directly to the load output ...including their negative terminals. See manual or consult your installer for details. | + | |
| - | Note that some loads (especially inverters) are best connected directly to the battery. In such cases the load output does not show a reliable reading - the current drawn by the inverter, for example, will not be included. Consider adding a [[https:// | + | |
| - | **Is my battery being charged? | + | |
| - | The battery will be charged whenever the power available from the PV panels exceeds the power being drawn by the loads (lights, fridge, inverter, etc.). | + | |
| - | You can only tell if that is the case with Charge Controllers which have all loads connected to the load output terminals. Remember: any loads connected directly to the battery can't be monitored by the Solar Charger. | + | |
| - | ===== 3. HISTORY - Thirty-day Graphic ===== | + | |
| - | (The fragmented square icon (top left) allows you to toggle between ' | + | |
| - | A summary of activity for the last 30 days is presented graphically. Swipe the bar left or right to show any of the previous 30 days. | + | |
| - | The daily log shows: | + | |
| - | * **Yield**: The energy converted for that day. | + | |
| - | * **P max**: The maximum power recorded during the day. | + | |
| - | * **V max**: The highest voltage from the PV array during the day. | + | |
| - | Clicking on any day/bar in the graph will expand the information to show charge-status times - both as hrs/m; and also as a percentage of the ' | + | |
| - | Tip! You can use the charge times to see if the PV array is properly sized for your requirements. A system which never reaches ' | + | |
| - | (If you are operating an [[http:// | + | |
| - | It is possible to export the history as a comma separated file (.csv) by clicking the three connected dots at the top right of the history screen: | + | |
| - | This is an example of the exported data for 3 of 30 days: | + | |
| - | ^Days ago^Yield(Wh)^Max. PV power(W)^Max. PV voltage(V)^Min. battery voltage(V)^Max. battery voltage(V)^Time in bulk(m)^Time in absorption(m)^Time in float(m)^Last error^2nd last error^3rd last error^4th last error^ | + | |
| - | |0|14500|2167|118.80|51.34|52.99|748|0|0|0|0|0|0| | + | |
| - | |1|15450|2326|118.81|51.68|53.97|869|0|0|0|0|0|0| | + | |
| - | |2|12350|2925|126.67|51.73|55.42|872|0|0|0|0|0|0| | + | |
| - | **Battery Voltage**\\ | + | |
| - | The first figure shows the maximum battery voltage for the day ...the figure below is the minimum battery voltage. | + | |
| - | **Consumption (only on 100/20 models and smaller)**\\ | + | |
| - | Shows the energy consumed by loads connected to the load output terminal. | + | |
| - | **Errors**\\ | + | |
| - | Shows the number of errors (if any) for the day, to see the error codes click on the orange point. See [[:mppt-error-codes|]].\\ (You may need to slide the display on your device up to see the errors.) | + | |
| - | **Total **\\ | + | |
| - | This shows the total energy converted by the installation and is not re-settable. | + | |
| - | **Since Cleared**\\ | + | |
| - | This shows how much energy has been converted by the installation since the last reset. | + | |
| - | ===== 4. Settings ===== | + | |
| - | The settings page is accessed by clicking on the Cog icon at the top right of the Home page. The settings page provides access to view or change the settings of the Battery; Load; Streetlight; | + | |
| - | ==== 4.1 Battery settings ==== | + | |
| - | For small MPPT Solar Charger models there is only one preset. Larger models feature a rotary switch, the battery page shows the setting of the rotary switch. | + | |
| - | We recommend using the rotary switch to select one of the pre-programmed charge algorithms. | + | |
| - | === Battery voltage === | + | |
| - | Set the battery voltage to a fixed voltage (12, 24, 36, 48). | + | |
| - | The battery voltage is automatically selected at the very first power-up of the charger. The detected figure is stored, and further automatic detection is disabled. If, however, the battery voltage is absent (or below 7 volts) the unit operates as a 12V model and automatic detection is rescheduled for the next power-up. | + | |
| - | Note that 36 and 48 volt operation is only available on models which support these voltages - such as the MPPT 150/35. Note also that 36 volts cannot be detected automatically. Systems operating at this voltage must always be set manually. | + | |
| - | Hint: if you just want to update the firmware of a device while still keeping the automatic voltage detection active (e.g. before shipping a unit to the end customer), update the firmware as you normally would do. When the firmware update is complete, at the "Live Data Information" | + | |
| - | === Max charge current === | + | |
| - | Allows the user to set a lower maximum charge current. | + | |
| - | === Charger enabled === | + | |
| - | Toggling this setting turns the Solar Charger off. The batteries will not be charged. This setting is intended only for use when carrying-out work on the installation. | + | |
| - | === Charger settings - Battery preset === | + | |
| - | Battery preset allows you to select the battery type; accept factory defaults; or enter your own preset values to be used for the battery charge algorithm. | + | |
| - | User-defined presets will be stored in the preset library - in this way installers will not have to define all the values each time they are configuring a new installation. | + | |
| - | By selecting //Edit Presets//, or on the Settings screen (with expert mode on or not), custom parameters can be set as follows: | + | |
| - | === Absorption voltage === | + | |
| - | Set the absorption voltage. | + | |
| - | === Adaptive absorption time === | + | |
| - | Select with adaptive absorption time or fixed absorption time will be used. Both are better explained below: | + | |
| - | //Fixed absorption time:// | + | |
| - | The same length of absorption is applied every day (when there is enough solar power) by using the maximum absorption time setting. Be aware that this option can result in overcharging your batteries, especially for lead batteries and system with shallow daily discharges. See your battery manufacturer for recommended settings. | + | |
| - | //Adaptive absorption time:// | + | |
| - | The charge algorithm can use an adaptive absorption time: it automatically adapts to the state of charge in the morning. The maximum duration of the absorption period for the day is determined by the battery voltage as measured just before the solar charger begins operation each morning (12V battery assumed): | + | |
| - | ^Battery voltage Vb (@start-up) ^ Multiplier ^ Maximum absorption times ^ | + | |
| - | | Vb < 11.9V | + | |
| - | | > 11.9V Vb < 12.2V | + | |
| - | | > 12.2V Vb < 12.6V | + | |
| - | | Vb > 12.6V | + | |
| - | The multiplier is applied to the maximum absorption time setting and this results in the maximum duration of the absorption period used by the charger. | + | |
| - | The maximum absorption times shown in the last column of the table are based on the default maximum absorption time setting of 6 hours. | + | |
| - | === Maximum absorption time (hh:mm) === | + | |
| - | Set the absorption time limit. Only available when using a custom charge profile. | + | |
| - | Enter the time value in the notation hh:mm, where hours are between 0 and 12; and minutes are between 0 and 59. | + | |
| - | === Float voltage === | + | |
| - | Set the float voltage. | + | |
| - | === Re-bulk voltage offset === | + | |
| - | Set the voltage offset that will be used over the float voltage setting that will determine the threshold that the charge cycle will restart. | + | |
| - | E.g.: For a Re-bulk voltage offset off 0.1V and a float voltage setting of 13.8V, the voltage threshold that will be use to restart the charge cycle will be 13.7V. In other words, if the battery voltage drops below 13.7V for one minute, the charge cycle will restart. | + | |
| - | === Equalization voltage === | + | |
| - | Set the equalization voltage. | + | |
| - | === Equalization current percentage | + | |
| - | Set the percentage of the Max charge current setting that will be used when equalisation is performed. | + | |
| - | === Automatic Equalization === | + | |
| - | Set-up the frequency of the auto equalize function. Available options are between 1 and 250 days: | + | |
| - | * 1 = daily | + | |
| - | * 2 = every other day | + | |
| - | * 250 = every 250 days | + | |
| - | Equalization is typically used to balance the cells in a lead battery, and also to prevent stratification of the electrolyte in flooded batteries. Whether (automatic) equalization is necessary, or not, depends on the type of batteries, and their usage. Consult your battery supplier for guidelines. | + | |
| - | When the Automatic equalization cycle has initiated, the charger applies an equalization voltage to the battery as long as the current level stays below the equalization current percentage setting of the bulk current. | + | |
| - | __Duration of the Automatic equalization cycle__ | + | |
| - | In the case of all VRLA batteries and some flooded batteries (algorithm number 0, 1, 2 and 3) automatic equalization ends when the voltage limit (maxV) has been reached, or after a period equal to (absorption time/8) - whichever comes first. | + | |
| - | For all tubular plate batteries (algorithm numbers 4, 5 & 6); and also for the user-defined battery type, automatic equalization will end after a period equal to (absorption time/2). | + | |
| - | For the Lithium battery type (algorithm number 7), equalization is not available. | + | |
| - | When an automatic equalization cycle is not completed in one day, it will not resume the next day. The next equalization session will take place according to the interval set in the 'Auto Equalization' | + | |
| - | For units without a rotary switch (75/10; 75/15; 100/15 & 100/20) the default battery type is a VRLA battery and any user-defined battery will behave as a tubular plate battery with regard to equalization. | + | |
| - | === Equalisation stop mode === | + | |
| - | Set how the equalisation will end. There are two possibilities, | + | |
| - | === Maximum equalisation duration === | + | |
| - | Set the maximum time that the equalisation phase will last. | + | |
| - | === Tail current === | + | |
| - | Set the current threshold that will be used to finish absorption phase before the maximum absorption time expires. When the battery current gets below the tail current for one minute, the absorption phase will end. This setting can be disabled by setting it to zero. | + | |
| - | === Temperature compensation === | + | |
| - | Many types of battery require a lower charge voltage in warm operating conditions, and a higher charge voltage in cold operating conditions. | + | |
| - | The configured coefficient is in mV per degree Celsius for the whole battery bank, not per cell. The base temperature for the compensation is 25°C (77°F), as shown in the chart below. | + | |
| - | With a [[: | + | |
| - | In case there is no external source for battery temperature; | + | |
| - | === Low temperature cut-off === | + | |
| - | This setting is available when a VE.Smart network is set-up and the battery temperature is available (e.g. by for example using a Smart Battery Sense or a Smart BMV with the optional temperature sensor). It can be used to disable charging at low temperatures as required by Lithium batteries. | + | |
| - | For Lithium Iron Phosphate batteries this setting is preset at 5 degrees Celsius, for the other battery types it is disabled. When creating a user defined battery the cut-off temperature level can be adjusted manually. | + | |
| - | See the [[victronconnect: | + | |
| - | === Manual Equalization - Start now === | + | |
| - | Selecting 'Start now' on ' | + | |
| - | ==== 4.2 Load output | + | |
| - | This section applies to all products. These settings are typically used on the smaller models which have a dedicated load output (75/10, 75/15, 100/15 and 100/20). | + | |
| - | For larger models without a load output, the load settings can be used to drive the TX pin in the VE.Direct port, which can then be used to drive a [[https:// | + | |
| - | The available programs are: | + | |
| - | - **Always off** | + | |
| - | - **BatteryLife algorithm**: | + | |
| - | - **Conventional algorithm 1**: Off when Vbatt < 11.10V. And On when Vbatt > 13.10V. (12V battery assumed) | + | |
| - | - **Conventional algorithm 2**: Off when Vbatt < 11.80V. And On when Vbatt > 14.00V. | + | |
| - | - **Always on** | + | |
| - | - **User defined algorithm 1**: Off when Vbatt < Vlow. And On when Vbatt > Vhigh. | + | |
| - | - **User defined algorithm 2**: Off when Vbatt < Vlow or Vbatt > Vhigh. And On when Vbatt between Vlow and Vhigh. | + | |
| - | - **Automatic Energy Selector**: Off when Vbatt < Vlow. And On when Vbatt > Vhigh. When conditions are met Load will be on for a pre-selected time. Note; This mode is only available on SmartSolar Models. | + | |
| - | Note that, by default, the models with a load output have their algorithm selected with a jumper in the VE.Direct port. This can be disabled using the VE.Direct Rx pin configuration (see **4.5** below). Or remove the jumper from the VE.Direct port when using VictronConnect to configure the load ouput operation mode, the drawing below shows where the jumper is located. | + | |
| - | Keep in mind that modes 1 (always off) and 5 (always on) will respond immediately. The other modes, sensing the battery voltage, have a delay of 2 minutes before the load output changes. This is so that the charger does not respond too quickly when, for example, an inrush current briefly lowers the battery voltage below the threshold. | + | |
| - | Larger models offer a ' | + | |
| - | The load output (on the smaller MPPT models) always acts as a switch - off when load output is off or streetlight dimming is at 0%; and on when load output is on and streetlight dimming is between 1 and 100% (see **4.3** below: //Gradual Dimming speed//). | + | |
| - | Use the optional [[https:// | + | |
| - | ==== 4.3 Streetlight settings ==== | + | |
| - | === Introduction === | + | |
| - | The Streetlight function allows you to automatically control night lighting - it's duration, and brilliance. When the Streetlight function is enabled a timer program can be created whereby Sunset, Sunrise as well as Midnight can be used as the anchor points for the timer program. These anchor points will automatically adjust itself to the duration of night-time as it changes with the seasons. | + | |
| - | === Streetlight, | + | |
| - | For our smaller chargers, that have a set of dedicated load output terminals, the light can be powered from those terminals. For larger chargers, the TX can be used, as a ' | + | |
| - | Note that, both for the real load output, and TX pin or Relay as ' | + | |
| - | If streetlight is disabled, then the (virtual) load output is controlled only by the configuration as made in the load output menu. | + | |
| - | If streetlight is enabled, then its an AND function: the load output will be on when both the condition made in the Load output menu are satisfied as well as the streetlight settings. Otherwise, its off. | + | |
| - | Therefore, in a streetlight application, | + | |
| - | === Setting the Sunset action === | + | |
| - | At sunset you can choose from the following actions: | + | |
| - | * __Keep the lights off__ | + | |
| - | * __Switch on for a fixed time__. This option will turn the light on at sunset, and then off after a configurable interval. When the dimming feature is enabled < | + | |
| - | * __Switch on till midnight__. This option turns the light on at sunset, and then off at midnight. When the dimming feature is enabled < | + | |
| - | * __Switch on till sunrise__. This options turns the light on at sunset, and then off at sunrise. When this option is selected; there is no need to also select an action at sunrise, and therefore the sunrise control option will be hidden. When the dimming feature is enabled < | + | |
| - | === Setting the Sunrise action === | + | |
| - | At sunrise you can choose to: | + | |
| - | * __Switch off__: Turns the light off at sunrise. | + | |
| - | * __Switch on before sunrise__: This option switches the light on at a configurable time interval before sunrise; and then switches the light off at sunrise. In case the dimming feature is enabled < | + | |
| - | === Midnight is Solar midnight, and not 12 o' clock === | + | |
| - | The charger has no real time clock, and does not know when it is 12 o' clock at night. All references to midnight refer to what we call solar midnight: the mid-point between sunset and sunrise. | + | |
| - | === Midnight and Sunrise synchronisation === | + | |
| - | The (solar-) midnight and sunrise anchor points in the timer program need the charger to have its internal clock synchronised with the cycle of the sun. | + | |
| - | After making your settings and powering up the charger, the charger will start unsynchronised: | + | |
| - | During synchronisation, | + | |
| - | Note that a loss of power will make the charger loose its synchronisation; | + | |
| - | === Sunset and sunrise detection === | + | |
| - | The Sunset and Sunrise detection voltage settings can be used to adjust the detection to match the panel configuration. The Sunrise detection voltage must be 0.5V higher than the Sunset detection level. The lowest detectable voltage is 11.4V. Set this option to 0 to use the built-in defaults, which are: | + | |
| - | * Sunset = Vpanel < 11.4V | + | |
| - | * Sunrise = Vpanel > 11.9V | + | |
| - | The default setting is 0, which uses built-in default voltages. | + | |
| - | Use the ' | + | |
| - | === Gradual dimming speed === | + | |
| - | The gradual dimming option can be used to slow down the response of the timer program. This is useful when multiple streetlights are used in a row, and helps to mask the fact that each timer uses its own detection and the transition moment which will vary from unit to unit. | + | |
| - | The dimming settings can be adjusted. You can input the number of seconds required to achieve each percentage-point of change (x seconds/per 1% of dimming). The available setting parameters are 0 ...99 | + | |
| - | * 0 = immediate response (gradual dimming disabled) | + | |
| - | *A setting of ' | + | |
| - | * 9 = dim from 0 to 100% in 15 minutes. | + | |
| - | *Setting the dimming speed to 9, for example, slows down the dimming speed to 15 minutes (9 seconds for each percentage point of dimming x 100 percentage points = 900 seconds or 15 minutes. | + | |
| - | Note: Make sure the TX port function is set to Light dimming mode (as described in the next chapter) and connect a VE.Direct TX digital output cable to the PWM dim input of your LED driver. | + | |
| - | === Mid-point shift === | + | |
| - | The time of midnight is estimated based on solar activity, and depends on your geographical location. Remember, too, that daylight saving times cause a further deviation between ' | + | |
| - | (Note that this setting is only relevant when your timer program uses ' | + | |
| - | For calculation we use a 1440-minute day. | + | |
| - | Where Sunset is at 19:00 (1140 minutes); and Sunrise is at 6:25 (385 minutes) | + | |
| - | * Night duration in minutes is: 1440m< | + | |
| - | * Degree of shift = time of sunset (in minutes) +half the duration of night (in minutes) - length of day (in minutes) = 1140m +342m-1440m = 42 minutes | + | |
| - | === Example configuration === | + | |
| - | The selections which have been made on below screen image (click to enlarge) result in this program: | + | |
| - | *//At sunset// - the light will be switched on for a fixed time | + | |
| - | *//Dim level at sunset// - at Full brilliance (100%) | + | |
| - | *//Keep lights on during// - the duration has been set to 1h 0m | + | |
| - | *//Dim level at end// - at the end of one hour the brilliance will be reduced to half (50%) | + | |
| - | Also; | + | |
| - | *//At sunrise// - the lighting will be adjusted before sunrise | + | |
| - | *//Time before sunrise// - at 1h 0m before sunrise, the following adjustment will be made: | + | |
| - | *//Dim level// - full brilliance will be restored (100%) | + | |
| - | ==== 4.4 Tx port function ==== | + | |
| - | This setting defines the function of the Tx pin located inside the VE.Direct connector. Use the [[https:// | + | |
| - | Available options: | + | |
| - | - **Normal communication (default)**. Use this when connecting to a Color Control GX, a VE.Direct Bluetooth Smart dongle, or any other device that needs to communicate with the MPPT. | + | |
| - | - **Pulse every 0.01 kWh**. Selecting this option causes a pulse to be emitted for every 0.01kWh of energy harvested, the TX port is normally high and will be driven low for approximately 250ms for every 0.01kWh harvested. This function is useful in combination with an energy meter. | + | |
| - | - **Light dimming (pwm normal)**. Use this function in combination with the Streetlight algorithm. PWM will be at 100% duty cycle when full light intensity is required. | + | |
| - | - **Light dimming (pwm inverted)**. Use this function in combination with the Streetlight algorithm. PWM signal will be 0% duty cycle when full light intensity is required. | + | |
| - | - **Virtual load output**. The TX pin will switch in harmony with the load output port. The purpose of this is to use the BatteryLife algorithm, or Streetlight algorithm, on the larger models which do not have a dedicated load output. Connect the VE.Direct TX digital output cable to a [[https:// | + | |
| - | Notes: | + | |
| - | * The PWM signal output (when using options 3 and 4) operates at a fixed frequency of 160Hz and has a fixed voltage level of 5V. | + | |
| - | * Using options 2 through to 5 does not disable the ability of the unit to communicate - what happens is that the unit will automatically detect incoming data, and whilst that data is being received it will resume normal communication (as in option 1) for the duration of that data-reception. When the unit detects that the data-reception has been completed, it will automatically resume whichever option (2 -5) has been manually selected. | + | |
| - | ==== 4.5 Rx port function ==== | + | |
| - | The Rx pin on the VE.Direct connector can be used for other functions. This functionality was introduced in firmware version 1.17. | + | |
| - | - **Remote on/off (This is the default setting on all larger models)**. This setting allows remote on/off control: (0V = switch charger off, +5V (or a signal sent via VE.Direct communication) = switch charger on). An example of this operation is when the unit is connected to a [[https:// | + | |
| - | - **Load output configuration (This is the default setting on the following models: 75/10, 75/15, 100/15 and 100/20)**. The Tx pin can be used to place a jumper to select load output operation. See Load output chapter (**4.2** above) for details. This only applies to the 10A, 15A and 20A chargers with a load output. | + | |
| - | - **Load output on/off inverted** This setting reverses the load output on/off control: (0V = switch load output on, +5V = switch load output off) | + | |
| - | - **Load output on/off normal** This setting allows load output on/off control: (0V = switch load output off, +5V = switch load output on) | + | |
| - | Note: These settings work in a similar way to a remote on/off switch, | + | |
| - | ==== 5. Programmable relay ==== | + | |
| - | A programmable relay switch is available on some SmartSolar models. The datasheet for your model will tell you whether or not it is available. | + | |
| - | The relay offers three connections: | + | |
| - | - NO (Normally Open) | + | |
| - | - C (Common) | + | |
| - | - NC (Normally Closed) | + | |
| - | ^ Relay state ^ Connection between ^ | + | |
| - | | Switched ON | C and NO | | + | |
| - | | Switched OFF | C and NC | | + | |
| - | The conditions for switching the relay depend on the relay mode setting, note that the conditions for switching over must be present for at least 10 seconds before the relay will change position. | + | |
| - | === Relay mode === | + | |
| - | - **Relay always off**. This option switches the relay OFF. It will disable the other relay options. Use this option if you do not plan to use the relay function. | + | |
| - | - **Panel voltage high**. This option switches the relay ON when the panel voltage becomes too high. See //Panel voltage high mode settings// below. | + | |
| - | - **High temperature (Dimming)**. This option switches the relay ON when the charger output current is reduced due to high temperatures. Use this option to for example switch an external fan. | + | |
| - | - **Battery voltage Low**. This option switches the relay in ON when the battery voltage falls too low, see //Battery voltage Low settings// below. This is the default setting when the relay function is active. | + | |
| - | - **Equalization active**. This option switches the relay ON when the manual equalization mode is active. | + | |
| - | - **Error state**. This option switches the relay ON when there is an error. | + | |
| - | - **Defrost option (Temp < -20?)**. This option switches the relay ON when the Charger temperature falls below -20 degrees Centigrade. | + | |
| - | - **Battery voltage high**. This option switches the relay ON when the battery voltage is too high, see //Battery voltage High settings// below. | + | |
| - | - **Float or Storage state**. This option switches the relay ON when the charger is in the float state. | + | |
| - | - **Day detection (Panels irradiated)**. This option switches the relay ON whilst the solar panels are providing energy (Day/Night detection). | + | |
| - | - **Load output**. This option switches the relay ON and OFF according to the settings chosen in 'Load Output' | + | |
| - | === Panel voltage High settings === | + | |
| - | - Panel high voltage. (User-defined Voltage) | + | |
| - | - Clear panel high voltage. (User-defined Voltage) | + | |
| - | This option switches the relay ON when the panel voltage rises above the chosen "Panel high voltage" | + | |
| - | Ensure, of course, that the "Panel high voltage" | + | |
| - | These settings must never exceed the maximum voltage-rating allowed by your MPPT charger. | + | |
| - | === Battery voltage Low settings === | + | |
| - | - Battery low-voltage relay. (The default setting for this is 10.00V) (12V battery assumed) | + | |
| - | - Clear battery low-voltage relay. (The default setting for this is 10.50V) | + | |
| - | These settings, which can be user-defined, | + | |
| - | Ensure, of course, that the " | + | |
| - | An application for this feature, for example, is to automatically disconnect a load in order to prevent a battery from becoming too deeply discharged. | + | |
| - | === Battery voltage High settings === | + | |
| - | - Battery high-voltage relay. (The default setting for this is 16.50V) (12V battery assumed) | + | |
| - | - Clear battery high-voltage relay. (The default setting for this is 16.00V) | + | |
| - | An application for this feature, for example, is to disconnect a load in order to protect it from an over-voltage. | + | |
| - | === General settings === | + | |
| - | - Minimum closed time. (The default setting for this is 0 minutes) | + | |
| - | This option sets a minimum-time for the ON condition to prevail once the relay has been switched ON. | + | |
| - | An application for this feature, for example, is to set a minimum generator run-time. | + | |
| - | ==== 6. VE.Smart Networking ==== | + | |
| - | This option is only available when the connection between the charger and VictronConnect is done over Bluetooth. This menu offers the possibility for the user to create or join an existing VE.Smart Network. By doing that, the user allow data to be exchanged between chargers and sensors. Please, refer to the [[victronconnect: | + | |
| - | ===== DISQUS ===== | + | |
| - | ~~DISQUS~~ | + | |
victronconnect/mppt-solarchargers.1577949476.txt.gz · Last modified: by guy_stewart
