victronconnect:mppt-solarchargers [2020-02-03 15:48] – tabreu | victronconnect:mppt-solarchargers [2021-01-15 14:36] – marmour | ||
- | * **Solar ' | + | |
- | * **Battery - Voltage** The voltage measurement is taken at the battery terminals of the Solar charger. | + | |
- | * Bulk: During this stage the Controller delivers as much charge current as possible to rapidly charge the batteries. When the battery voltage reaches the Absorption voltage setting, the Controller activates the Absorption stage. | + | |
- | * Absorption: During this stage the Controller switches to the constant voltage mode, where a pre-set absorption voltage, suitable to the battery type (See section 4.1 Battery Settings below), is applied. When the charge current decreases below the Tail current and/or the pre-set Absorption time has elapsed, the battery is fully charged. The Controller switches to the Float stage. The Tail current is 1A for models 100/20 and smaller; and 2A for larger models. (When an automatic equalisation is being performed this will also be reported as ' | + | |
- | * Float: During this stage the float voltage is applied to the battery to maintain a fully-charged state. When the battery voltage drops below float voltage during at least 1 minute, a new charge cycle will be triggered. | + | |
- | * Equalization: | + | |
- | It is possible to export the history as a comma separated file (.csv) by clicking the three connected dots at the top right of the history screen: | + | |
- | This is an example of the exported data for 3 of 30 days: | + | |
- | ^Days ago^Yield(Wh)^Max. PV power(W)^Max. PV voltage(V)^Min. battery voltage(V)^Max. battery voltage(V)^Time in bulk(m)^Time in absorption(m)^Time in float(m)^Last error^2nd last error^3rd last error^4th last error^ | + | |
- | |0|14500|2167|118.80|51.34|52.99|748|0|0|0|0|0|0| | + | |
- | |1|15450|2326|118.81|51.68|53.97|869|0|0|0|0|0|0| | + | |
- | |2|12350|2925|126.67|51.73|55.42|872|0|0|0|0|0|0| | + | |
- | **Errors**\\ | + | |
- | Shows the number of errors (if any) for the day, to see the error codes click on the orange point. See [[: | + | |
- | **Total **\\ | + | |
- | By selecting //Edit Presets//, or on the Settings screen (with expert mode on or not), custom parameters can be set as follows: | + | |
- | === Absorption voltage === | + | |
- | === Adaptive absorption time === | + | |
- | Select with adaptive absorption time or fixed absorption time will be used. Both are better explained below: | + | |
- | //Fixed absorption time:// | + | |
- | The same length of absorption is applied every day (when there is enough solar power) by using the maximum absorption time setting. Be aware that this option can result in overcharging your batteries, especially for lead batteries and system with shallow daily discharges. See your battery manufacturer for recommended settings. | + | |
- | //Adaptive absorption time:// | + | |
- | The charge algorithm can use an adaptive absorption time: it automatically adapts to the state of charge in the morning. The maximum duration of the absorption period for the day is determined by the battery voltage as measured just before the solar charger begins operation each morning (12V battery assumed): | + | |
- | | Vb < 11.9V | + | |
- | | Vb > 12.6V | + | |
- | The multiplier is applied to the maximum absorption time setting and this results in the maximum duration of the absorption period used by the charger. | + | |
- | The maximum absorption times shown in the last column of the table are based on the default maximum absorption time setting of 6 hours. | + | |
- | === Maximum absorption time (hh:mm) === | + | |
- | === Re-bulk voltage offset === | + | |
- | Set the voltage offset that will be used over the float voltage setting that will determine the threshold that the charge cycle will restart. | + | |
- | E.g.: For a Re-bulk voltage offset off 0.1V and a float voltage setting of 13.8V, the voltage threshold that will be use to restart the charge cycle will be 13.7V. In other words, if the battery voltage drops below 13.7V for one minute, the charge cycle will restart. | + | |
- | === Equalization current percentage | + | |
- | Set the percentage of the Max charge current setting that will be used when equalisation is performed. | + | |
- | === Automatic Equalization === | + | |
- | * 1 = daily | + | |
- | When the Automatic equalization cycle has initiated, the charger applies an equalization voltage to the battery as long as the current level stays below the equalization current percentage setting of the bulk current. | + | |
- | === Equalisation stop mode === | + | |
- | Set how the equalisation will end. There are two possibilities, | + | |
- | === Maximum equalisation duration === | + | |
- | Set the maximum time that the equalisation phase will last. | + | |
- | === Tail current === | + | |
- | Set the current threshold that will be used to finish absorption phase before the maximum absorption time expires. When the battery current gets below the tail current for one minute, the absorption phase will end. This setting can be disabled by setting it to zero. | + | |
- | The configured coefficient is in mV per degree Celsius for the whole battery bank, not per cell. The base temperature for the compensation is 25°C (77°F), as shown in the chart below. | + | |
- | With a [[: | + | |
- | In case there is no external source for battery temperature; | + | |
- | This setting is available when a VE.Smart network is set-up and the battery temperature is available (e.g. by for example using a Smart Battery Sense or a Smart BMV with the optional temperature sensor). It can be used to disable charging at low temperatures as required by Lithium batteries. | + | |
- | === Manual Equalization - Start now === | + | |
- | Selecting 'Start now' on ' | + | |
- | - **Always off** | + | |
- | - **Always on** | + | |
- | Note that, by default, the models with a load output have their algorithm selected with a jumper in the VE.Direct port. This can be disabled using the VE.Direct Rx pin configuration (see **4.5** below). Or remove the jumper from the VE.Direct port when using VictronConnect to configure the load ouput operation mode, the drawing below shows where the jumper is located. | + | |
- | === Introduction === | + | |
- | The Streetlight function allows you to automatically control night lighting - it's duration, and brilliance. When the Streetlight function is enabled a timer program can be created whereby Sunset, Sunrise as well as Midnight can be used as the anchor points for the timer program. These anchor points will automatically adjust itself to the duration of night-time as it changes with the seasons. | + | |
- | === Streetlight, | + | |
- | For our smaller chargers, that have a set of dedicated load output terminals, the light can be powered from those terminals. For larger chargers, the TX can be used, as a ' | + | |
- | Note that, both for the real load output, and TX pin or Relay as ' | + | |
- | If streetlight is disabled, then the (virtual) load output is controlled only by the configuration as made in the load output menu. | + | |
- | If streetlight is enabled, then its an AND function: the load output will be on when both the condition made in the Load output menu are satisfied as well as the streetlight settings. Otherwise, its off. | + | |
- | Therefore, in a streetlight application, | + | |
- | === Setting the Sunset action === | + | |
- | * __Keep the lights off__ | + | |
- | * __Switch on for a fixed time__. This option will turn the light on at sunset, and then off after a configurable interval. When the dimming feature is enabled < | + | |
- | * __Switch on till midnight__. This option turns the light on at sunset, and then off at midnight. When the dimming feature is enabled < | + | |
- | * __Switch on till sunrise__. This options turns the light on at sunset, and then off at sunrise. When this option is selected; there is no need to also select an action at sunrise, and therefore the sunrise control option will be hidden. When the dimming feature is enabled < | + | |
- | === Setting the Sunrise action === | + | |
- | * __Switch off__: Turns the light off at sunrise. | + | |
- | * __Switch on before sunrise__: This option switches the light on at a configurable time interval before sunrise; and then switches the light off at sunrise. In case the dimming feature is enabled < | + | |
- | === Midnight is Solar midnight, and not 12 o' clock === | + | |
- | The charger has no real time clock, and does not know when it is 12 o' clock at night. All references to midnight refer to what we call solar midnight: the mid-point between sunset and sunrise. | + | |
- | === Midnight and Sunrise synchronisation === | + | |
- | The (solar-) midnight and sunrise anchor points in the timer program need the charger to have its internal clock synchronised with the cycle of the sun. | + | |
- | After making your settings and powering up the charger, the charger will start unsynchronised: | + | |
- | During synchronisation, | + | |
- | Note that a loss of power will make the charger loose its synchronisation; | + | |
- | === Sunset and sunrise detection === | + | |
- | The Sunset and Sunrise detection voltage settings can be used to adjust the detection to match the panel configuration. The Sunrise detection voltage must be 0.5V higher than the Sunset detection level. The lowest detectable voltage is 11.4V. Set this option to 0 to use the built-in defaults, which are: | + | |
- | * Sunset = Vpanel < 11.4V | + | |
- | * Sunrise = Vpanel > 11.9V | + | |
- | The default setting is 0, which uses built-in default voltages. | + | |
- | Use the ' | + | |
- | The gradual dimming option can be used to slow down the response of the timer program. This is useful when multiple streetlights are used in a row, and helps to mask the fact that each timer uses its own detection and the transition moment which will vary from unit to unit. | + | |
- | *A setting of ' | + | |
- | === Example configuration === | + | |
- | The selections which have been made on below screen image (click to enlarge) result in this program: | + | |
- | Also; | + | |
- | Notes: | + | |
- | The Rx pin on the VE.Direct connector can be used for other functions. This functionality was introduced in firmware version 1.17. | + | |
- | - **Load output configuration (This is the default setting on the following models: 75/10, 75/15, 100/15 and 100/20)**. The Tx pin can be used to place a jumper to select load output operation. See Load output chapter (**4.2** above) for details. This only applies to the 10A, 15A and 20A chargers with a load output. | + | |
- | - C (Common) | + | |
- | ==== 6. VE.Smart Networking ==== | + | |
- | This option is only available when the connection between the charger and VictronConnect is done over Bluetooth. This menu offers the possibility for the user to create or join an existing VE.Smart Network. By doing that, the user allow data to be exchanged between chargers and sensors. Please, refer to the [[victronconnect: | + | |
