victronconnect:mppt-solarchargers [2019-06-24 10:04] – mvader | victronconnect:mppt-solarchargers [2019-06-25 16:06] – mvader | ||
Line 163: | Line 163: | ||
=== Start Equalization now === | === Start Equalization now === | ||
- | Selecting 'Start Equalization now' allows manual initiation of an Equalization cycle. To allow the charger to equalize the battery properly use the manual equalize option only during absorption and float periods, and when there is sufficient sunlight. Current and voltage limits are identical to the automatic equalize function. The duration of the equalisation cycle is limited to a maximum of 1 hour when triggered manually. Manual equalization can be stopped at any time by selecting 'Stop Equalize' | + | Selecting 'Start Equalization now' allows manual initiation of an Equalization cycle. To allow the charger to equalize the battery properly use the manual equalize option only during absorption and float periods, and when there is sufficient sunlight. Current and voltage limits are identical to the automatic equalize function. The duration of the equalisation cycle is limited to a maximum of 1 hour when triggered manually. Manual equalization can be stopped at any time by selecting 'Stop Equalize' |
=== Temperature compensation === | === Temperature compensation === |
