victronconnect:mppt-solarchargers [2019-02-20 08:32] – rvanzundert | victronconnect:mppt-solarchargers [2019-06-25 16:06] – mvader | ||
Line 10: | Line 10: | ||
===== 2. STATUS - Live Data Information ===== | ===== 2. STATUS - Live Data Information ===== | ||
* **MPPT [Model Number]** | * **MPPT [Model Number]** | ||
Line 37: | Line 37: | ||
You can only tell if that is the case with Charge Controllers which have all loads connected to the load output terminals. Remember: any loads connected directly to the battery can't be monitored by the Solar Charger. | You can only tell if that is the case with Charge Controllers which have all loads connected to the load output terminals. Remember: any loads connected directly to the battery can't be monitored by the Solar Charger. | ||
===== 3. HISTORY - Thirty-day Graphic ===== | ===== 3. HISTORY - Thirty-day Graphic ===== | ||
(The fragmented square icon (top left) allows you to toggle between ' | (The fragmented square icon (top left) allows you to toggle between ' | ||
Line 71: | Line 71: | ||
===== 4. Settings ===== | ===== 4. Settings ===== | ||
The settings page is accessed by clicking on the Cog icon at the top right of the Home page. The settings page provides access to view or change the settings of the Battery; Load; Streetlight; | The settings page is accessed by clicking on the Cog icon at the top right of the Home page. The settings page provides access to view or change the settings of the Battery; Load; Streetlight; | ||
==== 4.1 Battery settings ==== | ==== 4.1 Battery settings ==== | ||
For small MPPT Solar Charger models there is only one preset. Larger models feature a rotary switch, the battery page shows the setting of the rotary switch. | For small MPPT Solar Charger models there is only one preset. Larger models feature a rotary switch, the battery page shows the setting of the rotary switch. | ||
Line 118: | Line 118: | ||
Enter the time value in the notation hh:mm, where hours are between 0 and 12; and minutes are between 0 and 59. | Enter the time value in the notation hh:mm, where hours are between 0 and 12; and minutes are between 0 and 59. | ||
- | The maximum duration of the absorption period is determined by the battery voltage as measured just before the solar charger begins operation each morning (12V battery assumed): | + | The charge algorithm uses an adaptive absorption time: it automatically adapts to the state of charge in the morning. |
^Battery voltage Vb (@start-up) ^ Multiplier ^ Maximum absorption times ^ | ^Battery voltage Vb (@start-up) ^ Multiplier ^ Maximum absorption times ^ | ||
Line 163: | Line 163: | ||
=== Start Equalization now === | === Start Equalization now === | ||
- | Selecting 'Start Equalization now' allows manual initiation of an Equalization cycle. To allow the charger to equalize the battery properly use the manual equalize option only during absorption and float periods, and when there is sufficient sunlight. Current and voltage limits are identical to the automatic equalize function. The duration of the equalisation cycle is limited to a maximum of 1 hour when triggered manually. Manual equalization can be stopped at any time by selecting 'Stop Equalize' | + | Selecting 'Start Equalization now' allows manual initiation of an Equalization cycle. To allow the charger to equalize the battery properly use the manual equalize option only during absorption and float periods, and when there is sufficient sunlight. Current and voltage limits are identical to the automatic equalize function. The duration of the equalisation cycle is limited to a maximum of 1 hour when triggered manually. Manual equalization can be stopped at any time by selecting 'Stop Equalize' |
=== Temperature compensation === | === Temperature compensation === | ||
Line 187: | Line 187: | ||
For larger models without a load output, the load settings can be used to drive the TX pin in the VE.Direct port, which can then be used to drive a [[https:// | For larger models without a load output, the load settings can be used to drive the TX pin in the VE.Direct port, which can then be used to drive a [[https:// | ||
The available programs are: | The available programs are: | ||
Line 213: | Line 213: | ||
==== 4.3 Streetlight settings ==== | ==== 4.3 Streetlight settings ==== | ||
The Streetlight function allows you to automatically control night lighting - it's duration, and brilliance. When the Streetlight function is enabled a timer program can be created whereby ' | The Streetlight function allows you to automatically control night lighting - it's duration, and brilliance. When the Streetlight function is enabled a timer program can be created whereby ' | ||
Line 285: | Line 285: | ||
This setting defines the function of the Tx pin located inside the VE.Direct connector. Use the [[https:// | This setting defines the function of the Tx pin located inside the VE.Direct connector. Use the [[https:// | ||
Available options: | Available options: | ||
Line 312: | Line 312: | ||
==== 5. Programmable relay ==== | ==== 5. Programmable relay ==== | ||
A programmable relay switch is available on some SmartSolar models. The datasheet for your model will tell you whether or not it is available. | A programmable relay switch is available on some SmartSolar models. The datasheet for your model will tell you whether or not it is available. |
