victronconnect:beta
victronconnect:beta [2019-06-14 19:45]
jperez [v5.8beta3]
victronconnect:beta [2019-06-16 14:21] (current)
mvader [v5.8beta1]
Line 96: Line 96:
 Don't change settings or update firmware if your system uses assistants. If you need to update your Inverter/​Charger firmware please use VictronConnect to help us testing it but note that you'll need to have access to a computer with VEConfigure to load the assistants again. Don't change settings or update firmware if your system uses assistants. If you need to update your Inverter/​Charger firmware please use VictronConnect to help us testing it but note that you'll need to have access to a computer with VEConfigure to load the assistants again.
-In case of a firmware update failure it is always possible ​to restore it by using VEFlash.+Firmware version 200 is required ​to see data and make changes to settings.
 +Firmware version 200 and a product with large microprocessor(the ones starting by 26&27) is required to be able to do a firmware update.
 ==== v5.7 (Released officially) ==== ==== v5.7 (Released officially) ====
 ** 2019-05-08 ** ** 2019-05-08 **
victronconnect/beta.txt · Last modified: 2019-06-16 14:21 by mvader
