venus-os:v2.60
venus-os:v2.60 [2020-06-29 22:21] – [B) Changes to the NMEA2000-out chapter] mvader | venus-os:v2.60 [2020-12-15 16:49] (current) – mvader | ||
Line 17: | Line 17: | ||
- (optional - only when using ModbusTCP protocol): only enable ModbusTCP on one of the GX Devices | - (optional - only when using ModbusTCP protocol): only enable ModbusTCP on one of the GX Devices | ||
- Only connect the main GX Device to VRM; it will also transmit tank levels received from the secondary units. | - Only connect the main GX Device to VRM; it will also transmit tank levels received from the secondary units. | ||
- | - And so forth. | + | - We recommend to connect all VE.Bus and VE.Direct products to the main GX Device. Connecting the via a secondary device will work, but has limitations. For example that Remote configuration doesn’t work, DVCC control will not work, and neither will remote firmware updates. Expanding the VE.Direct ports through USB does give full functionality, |
==== Steps to configure ==== | ==== Steps to configure ==== | ||
Line 47: | Line 47: | ||
tbd. Include the new min /max, as well as ten point calibration and so forth. Include screenshots. | tbd. Include the new min /max, as well as ten point calibration and so forth. Include screenshots. | ||
+ | ===== D) Reset button seems to have gone missing in Cerbo manual ==== | ||
+ | (make sure to also check Venus GX new manual!!) | ||
+ | https:// | ||
+ | ===== E) Add frequencies to the manual, (required by some countries) ===== | ||
+ | Operating Frequencies: | ||
+ | Frequency Range Power Output | ||
+ | 2.402-2.48 GHz | ||
+ | 2.412-2.462 GHz 2.4 GHz WiFi 88.1 mW | ||
venus-os/v2.60.txt · Last modified: 2020-12-15 16:49 by mvader
