venus-os:start [2019-05-16 21:28] – [Comparison table] krenzke | venus-os:start [2024-04-10 14:04] (current) – [Comparison table] marmour |
====== Victron GX product range ====== | ===== Victron GX product range ====== |
GX products are Victron's state-of-the-art monitoring solution. The family consists of the different Venus-device models, and their accessories. | GX products are Victron's state-of-the-art monitoring solution. The family consists of the different GX products, and their accessories. |
The Venus-device lies at the heart of the system - providing monitoring, and operating as the communication-centre of your installation. All the other system-components - such as inverter/chargers, solar chargers, and batteries - are connected to it. The Venus-device ensures that they all work in harmony. Monitoring can be carried out locally ...or remotely - via our free-to-use Victron Remote Management portal ([[https://vrm.victronenergy.com|VRM]]). The Venus device also provides [[vrm_portal:remote-firmware-update|Remote firmware updates]] and even allows the settings to be [[vrm_portal:remote-veconfigure|Changed Remotely]]. | The GX-device lies at the heart of the system - providing monitoring, and operating as the communication-centre of your installation. All the other system-components - such as inverter/chargers, solar chargers, and batteries - are connected to it. Monitoring can be carried out locally and remotely - via our free-to-use Victron Remote Management portal ([[https://vrm.victronenergy.com|VRM]]). The GX device also provides [[vrm_portal:remote-firmware-update|Remote firmware updates]] and allows inverter/charger settings to be [[vrm_portal:remote-veconfigure|changed remotely]]. |
The Venus devices are: | The GX Family consists of these models: |
* [[https://www.victronenergy.com/panel-systems-remote-monitoring/color-control|Color Control GX]] | * [[https://nocache.victronenergy.com/panel-systems-remote-monitoring/ekrano-gx|Ekrano GX]] - Our latest GX product with integrated 7 inch touchscreen. |
* [[https://www.victronenergy.com/panel-systems-remote-monitoring/venus-gx|Venus GX]] | * [[https://nocache.victronenergy.com/panel-systems-remote-monitoring/cerbo-gx|Cerbo GX]] - Most commonly used GX product. |
* [[https://www.victronenergy.com/panel-systems-remote-monitoring/octo-gx|Octo GX]] - The Octo GX is particularly suited to installations which have many MPPT Solar Chargers, as it has 10 VE.Direct ports | * Cerbo GX MK2 - Most commonly used GX product - Hardware revision 2 with two VE.Can ports, 3 USB host ports and digital input pulse counting. |
* [[https://www.victronenergy.com/panel-systems-remote-monitoring/canvu-gx|The CANvu GX]] is best for harsh environments - when its IP67 rating is a must. | * [[https://nocache.victronenergy.com/panel-systems-remote-monitoring/cerbo-gx|Cerbo-S GX]] - Lower cost version, same as normal Cerbo GX but without BMS-Can port, Tank- and Temperature monitoring inputs. |
| * [[https://www.victronenergy.com/panel-systems-remote-monitoring/color-control|Color Control GX]] - Our first released GX product, the CCGX has a display and buttons. |
| * [[https://www.victronenergy.com/panel-systems-remote-monitoring/venus-gx|Venus GX]] - The Venus GX has more analog and digital IO, no LCD and is more cost effective than the CCGX. |
| * [[https://www.victronenergy.com/panel-systems-remote-monitoring/canvu-gx|CANvu GX]] - The CANvu GX is best for harsh environments - when its IP67 rating and touch LCD is a must. |
| * [[https://www.victronenergy.com/live/venus-os:octo-gx|Octo GX]] - The Octo GX is particularly suited to medium size installations which have many MPPT Solar Chargers, as it has 10 VE.Direct ports. (EOL) |
| * [[https://www.victronenergy.com/panel-systems-remote-monitoring/maxi%20gx|Maxi GX]] - Compared to the other GX devices, the Maxi GX has most CPU power and most VE.Direct ports: 25. This is the GX device to use for large systems with many VE.Direct MPPT Solar Chargers. (EOL) |
| Lastly, there is a GX device built into our [[https://www.victronenergy.com/inverters-chargers/multiplus-ii-gx|MultiPlus-II GX]] and [[https://www.victronenergy.com/inverters-chargers/easysolar-ii-gx|EasySolar-II GX]] Inverter/chargers. |
===== Available accessories ===== | ===== Available accessories ===== |
* [[https://www.victronenergy.com/accessories/gx-gsm|GX GSM]] - A cellular modem. It connects to Venus-device via USB, and takes a simcard | * [[https://www.victronenergy.com/panel-systems-remote-monitoring/gx-touch-50|GX Touch]] - Touch screen display accessory for the Cerbo GX and Cerbo GX MK2 |
| * [[https://www.victronenergy.com/accessories/gx-gsm|GX GSM]] - A 2G and 3G cellular modem. It connects to GX device via USB, and takes a simcard |
| * [[https://www.victronenergy.com/accessories/gx-lte-4g|GX LTE 4G]] - A 2G, 3G and 4G cellular modem. It connects to GX device via USB and takes a simcard |
* [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|WiFi USB sticks]] | * [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|WiFi USB sticks]] |
* [[energy-meters:start|Energy Meters]] - Measures PV Inverter Output where PV Inverters cannot be read-out directly. Also used as a grid meter in an [[ess:start|Energy Storage System (ESS)]]. | * [[energy-meters:start|Energy Meters]] - Measures PV Inverter Output where PV Inverters cannot be read-out directly. Also used as a grid meter in an [[ess:start|Energy Storage System (ESS)]]. |
* [[https://www.victronenergy.com/accessories/ve-can-resistive-tank-sender-adapter|VE.Can resistive tank sender adapter]] Allows a standard resistive tank-level sender to be connected to the Venus-device. | * [[https://www.victronenergy.com/accessories/ve-can-resistive-tank-sender-adapter|VE.Can resistive tank sender adapter]] - Allows a standard resistive tank-level sender to be connected to the GX device. Note that some GX Devices feature resistive tank-level inputs themselves. |
===== Comparison table ===== | ===== Comparison table ===== |
^ __User interface__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX ^ Maxi GX ^ | ^ __User interface__ ^ Ekrano GX ^ Cerbo GX ^ Cerbo GX MK2 ^ CCGX ^ Venus GX ^ CANvu GX ^ MultiPlus-II GX and EasySolar-II GX ^ |
| Appearance | {{ :ccgx:ccgx_product.png?direct&100 |}} | {{ :ccgx:venusgx_product.png?direct&100 |}} | {{ :ccgx:octogx_product.png?direct&100 |}} | {{ :ccgx:canvu_product.png?direct&100 |}} | | | Appearance | {{:venus-os:ekrano_gx_top.jpg?direct&80|}} | {{:venus-os:cerbo_gx_top.jpg?direct&80|}} | {{:venus-os:cerbo_gx_top.jpg?direct&80|}} | {{ :ccgx:ccgx_product.png?direct&80 |}} | {{ :ccgx:venusgx_product.png?direct&80|}} | {{:ccgx:canvu_product.png?direct&80|}} | {{ :ccgx:multiplus-ii-gx.jpg?direct&80 |}} | |
| Display | LCD Display & 7 buttons | no display | no display | 4.3" touch-screen | 2x16 character display | | | Display | {{:venus-os:ekrano_gx_side.jpg?direct&90|}} \\ 1024 x 600 LCD \\ built-in 7" touchscreen | {{:venus-os:gx-touch-50-_front-with-screen_copy.jpg?direct&90|}} \\ [[https://www.victronenergy.com/panel-systems-remote-monitoring/gx-touch-50|GX Touch]] \\ optional touch display <sup>(16)</sup> \\ GX Touch 50: 800 x 480 \\ GX Touch 70: 1024 x 600 || 480 x 272 LCD Display & 7 buttons | no display | 4.3" touch-screen | {{:venus-os:gx_display.jpg?direct&200|}} 2x16 character display | |
| Remote Console | yes ||||| | | Remote Console | yes |||||| |
| Buzzer | yes | yes | no | yes | no | | | Buzzer | yes ||||| no | |
^ __Documentation__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX ^ Maxi GX ^ | ^ __Product detail page &\\ manual download__ ^ [[https://www.victronenergy.com/panel-systems-remote-monitoring/ekrano-gx|Ekrano GX]] ^ [[https://nocache.victronenergy.com/panel-systems-remote-monitoring/cerbo-gx|Cerbo GX]] ^ tbd ^ [[https://www.victronenergy.com/panel-systems-remote-monitoring/color-control|CCGX]] ^ [[https://www.victronenergy.com/panel-systems-remote-monitoring/venus-gx|Venus GX]] ^ [[https://www.victronenergy.com/accessories/canvu-gx|CANvu GX]] ^ [[https://www.victronenergy.com/inverters-chargers|MP-II & ES-II GX]] ^ |
| Manual | [[ccgx:start|CCGX manual]] | [[venus-gx:start|VGX manual]] | [[venus-os:octo-gx|OGX manual]] | [[venus-os:canvu-gx|CANvu manual]] | tbd | | ^ __Victron comm. ports__ ^ Ekrano GX ^ Cerbo GX ^ Cerbo GX MK2 ^ CCGX ^ Venus GX ^ CANvu GX<sup>(12)</sup> ^ MultiPlus-II GX and EasySolar-II GX ^ |
| Product detail page | [[https://www.victronenergy.com/panel-systems-remote-monitoring/color-control|CCGX product]] | [[https://www.victronenergy.com/panel-systems-remote-monitoring/venus-gx|VGX product]] | [[https://www.victronenergy.com/panel-systems-remote-monitoring/octo-gx|OGX product]] | [[https://www.victronenergy.com/accessories/canvu-gx|CANvu product]] | tbd | | | VE.Direct ports\\ (always isolated) | 3 <sup>(1)</sup> ||| 2 <sup>(1)</sup> || 3 <sup>(1)</sup> | 1 | |
^ __Victron comm. ports__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX<sup>(12)</sup> ^ Maxi GX ^ | | VE.Bus\\ (always isolated) | 2 paralleled RJ45 sockets ||||||| |
| VE.Direct ports | 2 <sup>(1)</sup> || 10 <sup>(1)</sup> | 3 <sup>(1)</sup> | 25 | | | VE.Can | yes\\ VE.Can 1 isolated\\ VE.Can 2 non-isolated | yes - non-isolated | yes\\ VE.Can 1 isolated\\ VE.Can 2 non-isolated | 2 paralleled RJ45 sockets – isolated ||| depends <sup>(14, 23)</sup> 2 paralleled RJ45 sockets – isolated ||| depends <sup>(14, 23)</sup> | |
| VE.Can | 2 paralleled RJ45 sockets – isolated ||||| | ^ __Other comm. ports__ ^ Ekrano GX ^ Cerbo GX ^ Cerbo GX MK2 ^ CCGX ^ Venus GX ^ CANvu GX ^ MultiPlus-II GX and EasySolar-II GX ^ |
| VE.Bus | 2 paralleled RJ45 sockets – isolated |||| 1 isolated RJ45 socket | | | USB | 2 USB Host ports | 2 USB Host ports\\ & 1 power only port <sup>(21)</sup> | 3 USB Host ports | 2 USB Host ports || 1 USB Host port || |
^ __Non Victron-products__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX ^ Maxi GX ^ | | Ethernet | 10/100 RJ45 socket - isolated except shield ||||| 10/100 RJ45 socket <sup>(12)</sup> | 10/100 RJ45 socket | |
| Canbus-BMS batteries | Many battery brands. See [[battery_compatibility:start|here ]] for details ||||| | | WiFi | built-in ||| optional <sup>(2)</sup> | built-in, but see <sup>(3)</sup> | optional <sup>(2)</sup> | built-in | |
| Fronius PV Inverters | See [[ccgx:ccgx_fronius|here]] for details ||||| | | Bluetooth Smart | yes <sup>(17)</sup> ||| no ||| depends <sup>(23)</sup> | |
| SMA PV Inverters | See [[ccgx:ccgx_sma|here]] for details ||||| | | Micro SDcard slot | SDHC cards up to max. of 32GB <sup>(5)</sup> ||||| no | no | |
^ __Communication__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX ^ Maxi GX ^ | | Second CAN-bus port \\ (BMS-Can) <sup>(18)</sup> | yes - see VE.Can | no | yes - see VE.Can | no | yes - non-isolated | no | no | |
| USB | 2 USB Host ports – not isolated || 1 USB Host port - not isolated ||| | | BMS-Can port <sup>(15)</sup> | no | yes | no | no ||| depends <sup>(14, 23)</sup> | |
| Ethernet | 10/100 RJ45 socket - isolated except shield ||| 1 port. isolation?<sup>(12)</sup> | 10/100 RJ45 socket | | | Built-in RS485 | no |||||| |
| WiFi | optional <sup>(2)</sup> | built-in, but see <sup>(3)</sup> | built-in, external antenna <sup>(11)</sup> | optional <sup>(2)</sup> | no | | ^ __IO__ ^ Ekrano GX ^ Cerbo GX ^ Cerbo GX MK2 ^ CCGX ^ Venus GX ^ CANvu GX<sup>(12)</sup> ^ MultiPlus-II GX and EasySolar-II GX ^ |
| Bluetooth Smart | no ||||| | | Programmable relay <sup>(7)</sup> | 2 x NO/NC <sup>(8)</sup>\\ DC up to 30VDC: 3A\\ AC: 1A, 125VAC | 2 x NO/NC <sup>(8)</sup>\\ DC up to 30VDC: 6A\\ DC up to 70VDC: 1A\\ AC: 6A, 125VAC || 1 x NO | 1 x NO/NC <sup>(8)</sup> | 1x NO / NC | n/a | |
| Micro SDcard slot | SDHC cards up to max. of 32GB. <sup>(5)</sup> ||| no | yes | | | Resistive tank \\ level inputs | 3 <sup>(9)</sup> | 4 <sup>(9)</sup> || no | 3 <sup>(9)</sup> | no || |
| Second CAN-bus port | no | yes - non-isolated | yes - non-isolated | yes - non-isolated | no | | | Temperature sense \\ inputs | 2 <sup>(10)</sup> | 4 <sup>(10)</sup> || no | 2 <sup>(10)</sup> | no || |
| RS485 | no | no | yes - non-isolated | no || | | Digital Inputs | 2 <sup>(22)</sup> | 4 <sup>(22)</sup> || no | 5 <sup>(22)</sup> | 1 <sup>(22)</sup> | no | |
^ __IO__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX<sup>(12)</sup> ^ Maxi GX ^ | ^ __Third party compatibility__ ^ Ekrano GX ^ Cerbo GX ^ Cerbo GX MK2 ^ CCGX ^ Venus GX ^ CANvu GX ^ MultiPlus-II GX and EasySolar-II GX ^ |
| Programmable relay <sup>(7)</sup> | 1x NO | 1x NO / NC <sup>(8)</sup> | 1x NO / NC || 1x NO / NC <sup>(8)</sup> | | | Canbus-BMS batteries | Many battery brands. See [[battery_compatibility:start|here ]] for details ||||||| |
| Resistive tank level inputs | no | 3 <sup>(9)</sup> | no ||| | | Fronius PV Inverters | See [[ccgx:ccgx_fronius|here]] for details ||||||| |
| Temperature measurements | no | 2 <sup>(10)</sup> | no || | | SMA PV Inverters | See [[ccgx:ccgx_sma|here]] for details ||||||| |
| Digital Inputs | no | 5 | 3 | 1 | 4 | | | ABB/FIMER PV Inverters | See [[ccgx:abb_fimer|here]] for details ||||||| |
^ __Other__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX ^ Maxi GX ^ | | SolarEdge PV Inverters | See [[venus-os:gx_solaredge|here]] for details ||||||| |
| Supply voltage | 8 - 70 VDC ||| 8 - 32 VDC | 32 - 70 VDC | | | Marine MFD \\ App Support | [[https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-14ff5af9-63a5-1c2b-abfb-50bd9bcecd34|Generic MFD Manual]], [[https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-d5fa693e-1c4b-ec20-be20-e0baf8803e6e|Navico]], [[https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-1cf0fd18-cd34-92e7-6f08-cfec8fad0eca|Garmin]], [[https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-906e773b-f29c-2b77-56a8-d9ade87cc418|Raymarine]], [[https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-0e93850d-da2f-8bd9-9ce6-cc2546605459|Furuno]] ||||||| |
| Mounting | Panel Integration | Wall mounting | DIN Rail (35mm) | Panel | Wall mount IP65 | | | Mopeka Pro Check \\ LPG & Water Bluetooth \\ tank sensor <sup>(24)</sup> | See [[https://www.victronenergy.com/media/pg/Cerbo_GX/en/connecting-supported-non-victron-products.html#UUID-18d8a141-194d-f582-64ab-268f5072dfad|here]] for details ||||||| |
| Outer dimensions ( h x w x d ) | 130 x 120 x 28 mm | 45 x 143 x 96 mm | 61 x 108 x 90 mm | ? | 600 x 380 x 210 mm | | | RuuviTag Bluetooth \\ temperature sensor <sup>(24)</sup> | See [[https://www.victronenergy.com/media/pg/Cerbo_GX/en/connecting-supported-non-victron-products.html#UUID-d91da0a0-9a84-587b-18e8-abf55c6ac8a6|here]] for details ||||||| |
| Operating temperature | -20 to +50°C ||| -20 to +70°C | -20 to +50°C | | ^ __Performance__ ^ Ekrano GX ^ Cerbo GX ^ Cerbo GX MK2 ^ CCGX ^ Venus GX ^ CANvu GX ^ MultiPlus-II GX and EasySolar-II GX ^ |
| Battery backupped clock | yes ||| no | yes | | | CPU | quad core | dual core || single core ||| quad core | |
^ __Standards__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX ^ Maxi GX ^ | | RAM | 1GB ||| 256MB | 512MB | 256MB | 512MB | |
| Safety | EN 60950 || ? | ? | ? | | | Max. VE.Direct \\ devices <sup>(1)</sup> | 25 | 15 || 5 | 6 | 4 | 25 | |
| EMC | EN 61000-6-3, EN 55014-1, EN 61000-6-2, EN 61000-6-1, EN 55014-2 ||||| | ^ __Other__ ^ Ekrano GX ^ Cerbo GX ^ Cerbo GX MK2 ^ CCGX ^ Venus GX ^ CANvu GX ^ MultiPlus-II GX and EasySolar-II GX ^ |
| Automotive | E4-10R-053535 | In progress | ? | ? | no | | | Supply voltage | 8 - 70 VDC ||||| 8 - 32 VDC | powered internally, no external supply | |
| | Power draw | 2,6 to 7.4 W <sup>(25)</sup> | 2,5 to 5 W <sup>(19)</sup> || tbd |||| |
| | Mounting | Flush panel mounting or\\ blind hole mounting | Wall or DIN rail (35mm)<sup>(20)</sup> || Panel Integration | Wall mounting | Panel | Built-in | |
| | Outer dimensions\\ ( h x w x d ) | 124 x 187 x 29.8 mm | 78 x 154 x 48 mm || 130 x 120 x 28 mm | 45 x 143 x 96 mm | tbd | |
| | Operating temperature | -20 to +50°C ||||| -20 to +70°C | |
| | Battery backup clock | yes ||||| no | yes | |
| | 5V output | no |||| 1 A <sup>(13)</sup> | no || |
| ^ __Standards__ ^ Ekrano GX ^ Cerbo GX ^ Cerbo GX MK2 ^ CCGX ^ Venus GX ^ CANvu GX ^ MultiPlus-II GX and EasySolar-II GX ^ |
| | Safety | IEC 62368-1 ||| EN 60950 || IEC 62368-1 | IEC 62109-1\\ IEC62109-2\\ IEC62040-1 | |
===== Notes ===== | ===== Notes ===== |
- The maximum number of VE.Direct devices which can be attached to a CCGX is 5 (2 direct, and 3 via USB); on a Venus GX the number is 6 (2 direct and 4 via USB); on an Octo GX it is 10 (all attached directly). VE.Direct ports on a Venus-device are isolated. | - The listed maximum VE.Direct devices on the `Performance` section in above table is the total connected VE.Direct devices such as MPPT Solar Charge controllers. Total means all directly connected devices plus the devices connected over USB. The limit is mostly bound by CPU processing power. In relation to that, note that (a) connecting solar chargers over VE.Can is more efficient than connected over VE.Direct - and besides more efficient also makes for better communication wiring. For example, a Cerbo GX can perfectly handle 25 pieces of VE.Can Solar Charger, combined with 6 pieces of Fronius three phase PV Inverter and of course a three phase Victron system. And note (b) that CPU load is not only caused by connecting VE.Direct devices; there are also other factors. Connecting multiple PV Inverters increases the CPU load, especially when they are three phase. Enabling ModbusTCP increases the CPU load as well. Up to three or four three phase inverters can typically be monitored on a CCGX. Higher power CPU devices can monitor more. |
- Though the CCGX has no built-in WiFi that functionality can easily be added by attaching a USB-WiFi dongle. See [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|CCGX Manual, section 1.4.2]] for details. | - Though the CCGX has no built-in WiFi that functionality can easily be added by attaching a USB-WiFi dongle. See [[https://www.victronenergy.com/media/pg/CCGX/en/internet-connectivity/wifi.html|CCGX Manual, WiFi section]] for details. |
- The built-in WiFi in the Venus GX has a very low signal strength - unfortunately. It is strong enough to connect to a phone, tablet or laptop in order to access setup and monitoring. But to connect the Venus GX to the internet either use the built-in Ethernet port or add a USB-WiFi dongle. See [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|CCGX Manual, section 1.4.2]] for details. Make sure the Venus GX is running v2.06 or later - early shipments of Venus GX units ran v2.05. | - The built-in WiFi in the Venus GX has a very low signal strength - unfortunately. It is strong enough to connect to a phone, tablet or laptop in order to access setup and monitoring. But to connect the Venus GX to the internet either use the built-in Ethernet port or add a USB-WiFi dongle. See [[https://www.victronenergy.com/media/pg/Venus_GX/en/internet-connectivity/wifi.html|Venus GX Manual, WiFi section]] for details. Make sure the Venus GX is running v2.06 or later - early shipments of Venus GX units ran v2.05. |
- The hardware of the Venus GX and Octo GX includes a built-in Bluetooth Smart chipset which hasn't proved satisfactory. Bluetooth Smart for Venus-devices is coming soon but will not use built-in chipsets. | - The hardware of the Venus GX and Octo GX includes a built-in Bluetooth Smart chipset which hasn't proved satisfactory. Bluetooth Smart for GX devices is coming soon but will not use built-in chipsets. |
- Octo GX comes with a small Wifi antenna. You may remove and replace it with any other Wifi antenna having an RP-SMA connector. | - Octo GX comes with a small Wifi antenna. You may remove and replace it with any other Wifi antenna having an RP-SMA connector. |
- Requires the [[https://www.victronenergy.com/accessories/canvu%20gx%20io%20extender%20and%20wiring%20kit|CANvu GX IO Extender and wiring kit]] | - Requires the [[https://www.victronenergy.com/accessories/canvu%20gx%20io%20extender%20and%20wiring%20kit|CANvu GX IO Extender and wiring kit]] |
| - The CAN-Bus port of the Maxi GX, MultiPlus-II GX and EasySolar-II GX is a BMS-Can port. It can only be used to connect to managed batteries such as Freedomwon, BYD, Pylontech, BlueNova, MG Energy Systems and others, at 500kbps. Note that some early production batches had a labelling mistake: the port was labelled VE.Can. Which -unfortunately- is wrong. The hardware does not meet the requirements for a VE.Can port; and therefor is BMS-Can only. |
| - A BMS-Can port is a port dedicated to be used for connecting managed batteries, such as Freedomwon, BYD, Pylontech, BlueNova, MG Energy Systems and others, only. It is not possible to connect Victron VE.Can products to that port. To connect such managed battery, use our [[https://www.victronenergy.com/cables/ve-can-to-can-bus-bms|VE.Can to CAN-bus BMS cable]], and see [[https://www.victronenergy.com/live/battery_compatibility:start|Battery Compatibility documentation]]. Connect the side labelled 'VE.Can' into the BMS-Can/VE.Can port on the GX Device. And connect the other side to the battery. The baudrate of a BMS-Can port is fixed to 500kbps. |
| - The secondary CAN port, available on some GX devices as per table above, can be configured to be used as a BMS-Can port, as well as other profiles. For details, see manual. |
| - Late 2021 / early 2022, the hardware of the MultiPlus-II GX and EasySolar-II GX product range has been updated. The update adds Bluetooth and changes the CAN-communications port from a limited 500kbps BMS-Can only type to a full featured VE.Can port (non-isolated). Status per model, updated 2022-10-04: |
| - MultiPlus-II GX 24 3kVA; per HQ2231. Not shipping yet |
| - MultiPlus-II GX 48V 3kVA; per HQ2124, Ships from Australia, Spain, Netherlands and South Africa warehouses. |
| - MultiPlus-II GX 48V 5kVA; per HQ2220. Not shipping yet. |
| - EasySolar-II GX 24V 3kVA; introduced per HQ2203. Ships only from the Dutch warehouse |
| - EasySolar-II GX 48V 3kVA; per HQ2229. Ships only from Spain and SA warehouses |
