venus-os:start
venus-os:start [2019-09-10 16:20] – [Notes] mvader | venus-os:start [2019-10-10 12:29] – guy_stewart | ||
Line 43: | Line 43: | ||
| ABB PV Inverters | | ABB PV Inverters | ||
| SolarEdge PV Inverters | | SolarEdge PV Inverters | ||
+ | | [[https:// | ||
^ __Communication__ | ^ __Communication__ | ||
| USB | 2 USB Host ports – not isolated | | USB | 2 USB Host ports – not isolated | ||
Line 89: | Line 90: | ||
- Requires the [[https:// | - Requires the [[https:// | ||
- The 5V output on the Venus GX can be used to power, for example, a USB hub. Note that its output is not current limited or otherwise protected, and it shares the internal power supply in the Venus GX: overdrawing from it will result in shutdown(s) of the Venus GX. It is recommended to install a fuse for prevention. | - The 5V output on the Venus GX can be used to power, for example, a USB hub. Note that its output is not current limited or otherwise protected, and it shares the internal power supply in the Venus GX: overdrawing from it will result in shutdown(s) of the Venus GX. It is recommended to install a fuse for prevention. | ||
- | - Though the Maxi GX, MultiPlus-II GX and EasySolar-II GX all have a dual set of RJ-45 sockets labelled VE.Can, this port is actually a dedicated BMS-Can port. It can only be used to connected to managed batteries like Freedomwon, BYD, Pylontoch | + | - Though the Maxi GX, MultiPlus-II GX and EasySolar-II GX all have a dual set of RJ-45 sockets labelled VE.Can, this port is actually a dedicated BMS-Can port. It can only be used to connected to managed batteries like Freedomwon, BYD, Pylontech |
- A BMS-Can port is a port dedicated to be used for connecting managed batteries, like BYD, Pylontech, Freedomwon and others, only. It is not possible to connect Victron VE.Can products to that port. To connect such managed battery, use our [special cables](https:// | - A BMS-Can port is a port dedicated to be used for connecting managed batteries, like BYD, Pylontech, Freedomwon and others, only. It is not possible to connect Victron VE.Can products to that port. To connect such managed battery, use our [special cables](https:// |
venus-os/start.txt · Last modified: 2024-04-10 14:04 by marmour
