venus-os:start
venus-os:start [2019-06-12 16:30] – guy_stewart | venus-os:start [2019-08-07 11:49] – [Notes] krenzke | ||
Line 66: | Line 66: | ||
| Operating temperature | | Operating temperature | ||
| Battery backupped clock | yes ||| no | yes | yes | | | Battery backupped clock | yes ||| no | yes | yes | | ||
+ | | 5V output | ||
^ __Standards__ | ^ __Standards__ | ||
| Safety | | Safety | ||
Line 86: | Line 87: | ||
- Octo GX comes with a small Wifi antenna. You may remove and replace it with any other Wifi antenna having an RP-SMA connector. | - Octo GX comes with a small Wifi antenna. You may remove and replace it with any other Wifi antenna having an RP-SMA connector. | ||
- Requires the [[https:// | - Requires the [[https:// | ||
+ | - The 5V output on the Venus GX can be used to power, for example, a USB hub. Note that its output is not current limited or otherwise protected, and it shares the internal power supply in the Venus GX: overdrawing from it will result in shutdown(s) of the Venus GX. It is recommended to install a fuse for prevention. |
venus-os/start.txt · Last modified: 2024-04-10 14:04 by marmour
