venus-os:start [2019-06-08 12:37] – [Introduction] mvader | venus-os:start [2019-06-12 16:30] – guy_stewart |
| Buzzer | yes | yes | no | yes | no || | | Buzzer | yes | yes | no | yes | no || |
^ __Documentation__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX ^ Maxi GX ^ MultiPlus-II GX and EasySolar-II GX ^ | ^ __Documentation__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX ^ Maxi GX ^ MultiPlus-II GX and EasySolar-II GX ^ |
| Manual | [[ccgx:start|CCGX manual]] | [[venus-gx:start|VGX manual]] | [[venus-os:octo-gx|OGX manual]] | [[venus-os:canvu-gx|CANvu manual]] | [[https://docs.victronenergy.com/gx/maxi-gx.html|Maxi GX manual]] | [[https://ve3.nl/multiplus-ii-gx|MultiPlus-II GX]] | | | Manual | [[ccgx:start|CCGX manual]] | [[venus-gx:start|VGX manual]] | [[venus-os:octo-gx|OGX manual]] | [[venus-os:canvu-gx|CANvu manual]] | [[https://docs.victronenergy.com/gx/maxi-gx.html|Maxi GX manual]] | [[https://ve3.nl/multiplus-ii-gx|MultiPlus-II GX manual]] | |
| Product detail page | [[https://www.victronenergy.com/panel-systems-remote-monitoring/color-control|CCGX product]] | [[https://www.victronenergy.com/panel-systems-remote-monitoring/venus-gx|VGX product]] | [[https://www.victronenergy.com/panel-systems-remote-monitoring/octo-gx|OGX product]] | [[https://www.victronenergy.com/accessories/canvu-gx|CANvu product]] | [[https://www.victronenergy.com/panel-systems-remote-monitoring/maxi%20gx|Maxi GX product]] | | | Product detail page | [[https://www.victronenergy.com/panel-systems-remote-monitoring/color-control|CCGX product]] | [[https://www.victronenergy.com/panel-systems-remote-monitoring/venus-gx|VGX product]] | [[https://www.victronenergy.com/panel-systems-remote-monitoring/octo-gx|OGX product]] | [[https://www.victronenergy.com/accessories/canvu-gx|CANvu product]] | [[https://www.victronenergy.com/panel-systems-remote-monitoring/maxi%20gx|Maxi GX product]] | [[https://www.victronenergy.com/inverters-chargers/multiplus-ii%20gx|MultiPlus-II GX product]] | |
^ __Victron comm. ports__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX<sup>(12)</sup> ^ Maxi GX ^ MultiPlus-II GX and EasySolar-II GX ^ | ^ __Victron comm. ports__ ^ CCGX ^ Venus GX ^ Octo GX ^ CANvu GX<sup>(12)</sup> ^ Maxi GX ^ MultiPlus-II GX and EasySolar-II GX ^ |
| VE.Direct ports (always isolated) | 2 <sup>(1)</sup> || 10 <sup>(1)</sup> | 3 <sup>(1)</sup> | 25 | 1 | | | VE.Direct ports (always isolated) | 2 <sup>(1)</sup> || 10 <sup>(1)</sup> | 3 <sup>(1)</sup> | 25 | 1 | |
===== Notes ===== | ===== Notes ===== |
- The listed maximum on the `Performance` section in above table is the total connected VE.Direct devices such as MPPT Solar Charge controllers. Total means all directly connected devices plus the devices connected over USB. The limit is mostly bound by CPU processing power. Note that also monitoring PV Inverters creates a load. Up to three or four three phase inverters can typically be monitored on a CCGX. Higher power CPU devices can monitor more. | - The listed maximum on the `Performance` section in above table is the total connected VE.Direct devices such as MPPT Solar Charge controllers. Total means all directly connected devices plus the devices connected over USB. The limit is mostly bound by CPU processing power. Note that there is also a limit to the other type of devices of which often multiple are connected: PV Inverters. Up to three or four three phase inverters can typically be monitored on a CCGX. Higher power CPU devices can monitor more. |
- Though the CCGX has no built-in WiFi that functionality can easily be added by attaching a USB-WiFi dongle. See [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|CCGX Manual, section 1.4.2]] for details. | - Though the CCGX has no built-in WiFi that functionality can easily be added by attaching a USB-WiFi dongle. See [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|CCGX Manual, section 1.4.2]] for details. |
- The built-in WiFi in the Venus GX has a very low signal strength - unfortunately. It is strong enough to connect to a phone, tablet or laptop in order to access setup and monitoring. But to connect the Venus GX to the internet either use the built-in Ethernet port or add a USB-WiFi dongle. See [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|CCGX Manual, section 1.4.2]] for details. Make sure the Venus GX is running v2.06 or later - early shipments of Venus GX units ran v2.05. | - The built-in WiFi in the Venus GX has a very low signal strength - unfortunately. It is strong enough to connect to a phone, tablet or laptop in order to access setup and monitoring. But to connect the Venus GX to the internet either use the built-in Ethernet port or add a USB-WiFi dongle. See [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|CCGX Manual, section 1.4.2]] for details. Make sure the Venus GX is running v2.06 or later - early shipments of Venus GX units ran v2.05. |
