venus-os:start
venus-os:start [2019-03-05 11:28] – [Introduction] marmour | venus-os:start [2019-03-07 18:02] – [Comparison table] krenzke | ||
Line 30: | Line 30: | ||
| Manual | | Manual | ||
| Product detail page | | Product detail page | ||
- | ^ __Victron comm. ports__ | + | ^ __Victron comm. ports__ |
| VE.Direct ports | 2 < | | VE.Direct ports | 2 < | ||
| VE.Can | | VE.Can | ||
Line 40: | Line 40: | ||
^ __Communication__ | ^ __Communication__ | ||
| USB | 2 USB Host ports – not isolated | | USB | 2 USB Host ports – not isolated | ||
- | | Ethernet | + | | Ethernet |
| WiFi | | WiFi | ||
| Bluetooth Smart | no |||| | | Bluetooth Smart | no |||| | ||
- | | Micro SDcard slot | SDHC cards up to max. of 32GB. < | + | | Micro SDcard slot | SDHC cards up to max. of 32GB. < |
| Second CAN-bus port | no | yes - non-isolated | | Second CAN-bus port | no | yes - non-isolated | ||
| RS485 | no | no | | RS485 | no | no | ||
- | ^ __IO__ | + | ^ __IO__ |
| Programmable relay < | | Programmable relay < | ||
| Resistive tank level inputs | | Resistive tank level inputs | ||
Line 52: | Line 52: | ||
| Digital Inputs | | Digital Inputs | ||
^ __Other__ | ^ __Other__ | ||
+ | | Supply voltage | 8 - 70 VDC ||| 8 - 32 VDC | | ||
| Mounting | | Mounting | ||
| Outer dimensions ( h x w x d ) | | Outer dimensions ( h x w x d ) | ||
Line 76: | Line 77: | ||
- The Venus GX has two temperature terminals which can be used to measure & monitor all kinds of temperature-inputs. Temperature senders are not included. The required sensor is ASS000001000 - Temperature Sensor QUA/ | - The Venus GX has two temperature terminals which can be used to measure & monitor all kinds of temperature-inputs. Temperature senders are not included. The required sensor is ASS000001000 - Temperature Sensor QUA/ | ||
- Octo GX comes with a small Wifi antenna. You may remove and replace it with any other Wifi antenna having an RP-SMA connector. | - Octo GX comes with a small Wifi antenna. You may remove and replace it with any other Wifi antenna having an RP-SMA connector. | ||
+ | - Requires the [[https:// | ||
venus-os/start.txt · Last modified: 2024-04-10 14:04 by marmour
