venus-os:start
venus-os:start [2019-05-13 10:12] – [Comparison table] mvadervenus-os:start [2019-05-16 21:28] – [Comparison table] krenzke
Line 16: Line 16:
 ===== Available accessories ===== ===== Available accessories =====
-  * [[https://nocache.victronenergy.com/panel-systems-remote-monitoring/gx-gsm|GX GSM]] - A cellular modem. It connects to Venus-device via USB, and takes a simcard+  * [[https://www.victronenergy.com/accessories/gx-gsm|GX GSM]] - A cellular modem. It connects to Venus-device via USB, and takes a simcard
   * [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|WiFi USB sticks]]   * [[https://www.victronenergy.com/live/ccgx:start#internet_connectivity|WiFi USB sticks]]
   * [[energy-meters:start|Energy Meters]] - Measures PV Inverter Output where PV Inverters cannot be read-out directly. Also used as a grid meter in an [[ess:start|Energy Storage System (ESS)]].   * [[energy-meters:start|Energy Meters]] - Measures PV Inverter Output where PV Inverters cannot be read-out directly. Also used as a grid meter in an [[ess:start|Energy Storage System (ESS)]].
Line 24: Line 24:
 ^ __User interface__        CCGX    ^  Venus GX                              ^  Octo GX  ^  CANvu GX  ^  Maxi GX  ^ ^ __User interface__        CCGX    ^  Venus GX                              ^  Octo GX  ^  CANvu GX  ^  Maxi GX  ^
 | Appearance    {{ :ccgx:ccgx_product.png?direct&100 |}}      {{ :ccgx:venusgx_product.png?direct&100 |}}                        |  {{ :ccgx:octogx_product.png?direct&100 |}}  |  {{ :ccgx:canvu_product.png?direct&100 |}}  | | Appearance    {{ :ccgx:ccgx_product.png?direct&100 |}}      {{ :ccgx:venusgx_product.png?direct&100 |}}                        |  {{ :ccgx:octogx_product.png?direct&100 |}}  |  {{ :ccgx:canvu_product.png?direct&100 |}}  |
-| Display  |  LCD Display & 7 buttons      no display                        |  no display  |  4.3" touch-screen  |  no display  |+| Display  |  LCD Display & 7 buttons      no display  |  no display  |  4.3" touch-screen  |  2x16 character display  |
 | Remote Console            yes  ||||| | Remote Console            yes  |||||
-| Buzzer                    yes      yes                                    no  |  yes  |  ??  |+| Buzzer                    yes      yes                                    no  |  yes  |  no  |
 ^ __Documentation__        CCGX    ^  Venus GX                              ^  Octo GX  ^  CANvu GX  ^  Maxi GX  ^ ^ __Documentation__        CCGX    ^  Venus GX                              ^  Octo GX  ^  CANvu GX  ^  Maxi GX  ^
 | Manual                  |  [[ccgx:start|CCGX manual]]  |  [[venus-gx:start|VGX manual]]  |  [[venus-os:octo-gx|OGX manual]]  |  [[venus-os:canvu-gx|CANvu manual]]  |  tbd  | | Manual                  |  [[ccgx:start|CCGX manual]]  |  [[venus-gx:start|VGX manual]]  |  [[venus-os:octo-gx|OGX manual]]  |  [[venus-os:canvu-gx|CANvu manual]]  |  tbd  |
Line 40: Line 40:
 ^ __Communication__      ^  CCGX                    ^  Venus GX                        ^  Octo GX  ^  CANvu GX  ^  Maxi GX  ^ ^ __Communication__      ^  CCGX                    ^  Venus GX                        ^  Octo GX  ^  CANvu GX  ^  Maxi GX  ^
 | USB                    |  2 USB Host ports – not isolated                           ||  1 USB Host port - not isolated  ||| | USB                    |  2 USB Host ports – not isolated                           ||  1 USB Host port - not isolated  |||
-| Ethernet                10/100 RJ45 socket - isolated except shield               |||  1 port. isolation?<sup>(12)</sup>  |  tbd  | +| Ethernet                10/100 RJ45 socket - isolated except shield               |||  1 port. isolation?<sup>(12)</sup>  |  10/100 RJ45 socket  |
-| WiFi                    optional <sup>(2)</sup>  |  built-in, but see <sup>(3)</sup>  |  built-in, external antenna <sup>(11)</sup>  |  optional <sup>(2)</sup>  |  built-in  |+| WiFi                    optional <sup>(2)</sup>  |  built-in, but see <sup>(3)</sup>  |  built-in, external antenna <sup>(11)</sup>  |  optional <sup>(2)</sup>  |  no  |
 | Bluetooth Smart        |  no                      ||||| | Bluetooth Smart        |  no                      |||||
 | Micro SDcard slot      |  SDHC cards up to max. of 32GB. <sup>(5)</sup>              |||  no  |  yes  | | Micro SDcard slot      |  SDHC cards up to max. of 32GB. <sup>(5)</sup>              |||  no  |  yes  |
Line 50: Line 50:
 | Resistive tank level inputs      |  no          |  3 <sup>(9)</sup>                |  no  ||| | Resistive tank level inputs      |  no          |  3 <sup>(9)</sup>                |  no  |||
 | Temperature measurements          no          |  2 <sup>(10)</sup>                no  || | Temperature measurements          no          |  2 <sup>(10)</sup>                no  ||
-| Digital Inputs                        no          |  5                            3  |  1  |  no  |+| Digital Inputs                        no          |  5                            3  |  1  |   |
 ^ __Other__                        ^  CCGX        ^  Venus GX                        ^  Octo GX  ^  CANvu GX  ^  Maxi GX  ^ ^ __Other__                        ^  CCGX        ^  Venus GX                        ^  Octo GX  ^  CANvu GX  ^  Maxi GX  ^
 | Supply voltage |  8 - 70 VDC  |||  8 - 32 VDC  |  32 - 70 VDC  | | Supply voltage |  8 - 70 VDC  |||  8 - 32 VDC  |  32 - 70 VDC  |
 | Mounting                      Panel Integration  |  Wall mounting        DIN Rail (35mm)  |  Panel  |  Wall mount IP65  | | Mounting                      Panel Integration  |  Wall mounting        DIN Rail (35mm)  |  Panel  |  Wall mount IP65  |
-| Outer dimensions ( h x w x d )    130 x 120 x 28 mm  |  45 x 143 x 96 mm          61 x 108 x 90 mm  |  ?  |   |+| Outer dimensions ( h x w x d )    130 x 120 x 28 mm  |  45 x 143 x 96 mm          61 x 108 x 90 mm  |  ?  |  600 x 380 x 210 mm  |
 | Operating temperature            |  -20 to +50°C  |||  -20 to +70°C |  -20 to +50°C  | | Operating temperature            |  -20 to +50°C  |||  -20 to +70°C |  -20 to +50°C  |
 | Battery backupped clock          |  yes  |||  no  |  yes  | | Battery backupped clock          |  yes  |||  no  |  yes  |
Line 60: Line 60:
 | Safety                      |  EN 60950                                       ||  ?  |  ?  |  ?  | | Safety                      |  EN 60950                                       ||  ?  |  ?  |  ?  |
 | EMC                          EN 61000-6-3, EN 55014-1, EN 61000-6-2, EN 61000-6-1, EN 55014-2  ||||| | EMC                          EN 61000-6-3, EN 55014-1, EN 61000-6-2, EN 61000-6-1, EN 55014-2  |||||
-| Automotive                  |  E4-10R-053535  |  In progress                    ?  |  ?  |  na.  |+| Automotive                  |  E4-10R-053535  |  In progress                    ?  |  ?  |  no  |
 ===== Notes ===== ===== Notes =====
venus-os/start.txt · Last modified: 2024-05-21 14:14 by mvader
