venus-os:mfd-raymarine
venus-os:mfd-raymarine [2021-04-01 17:35] – [7. NMEA 2000] pbu | venus-os:mfd-raymarine [2021-04-30 20:44] – [7. NMEA 2000] pbu | ||
- | This document explains how to connect to Raymarine MFDs using an Ethernet connection. | + | This document explains how to connect to Raymarine MFDs using an Ethernet connection. |
The integration technology used is called [[http:// | The integration technology used is called [[http:// | ||
Line 64: | Line 65: | ||
===== 7. NMEA 2000 ===== | ===== 7. NMEA 2000 ===== | ||
- | The MFD can also be connected to the Victron system using NMEA 2000, see the [[ve.can: | + | A Raymarine |
- | In order to properly display | + | This chapter explains |
+ | If there are more than 1 (for example) SmartShunt in the NMEA2000 network then you change the Data instances of the Victron | ||
To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | ||
+ | If you have more than 1 battery be sure to adjust the settings of the Axiom to the correct amount of battery(banks). | ||
The following Victron related PGNs are supported: | The following Victron related PGNs are supported: | ||
Line 75: | Line 80: | ||
* 127508 - Battery Status (Battery Voltage, Battery Current) | * 127508 - Battery Status (Battery Voltage, Battery Current) | ||
- | If you have more than 1 battery be sure to adjust | + | When the NMEA2000/ |
Below list of Victron related PGNs are not supported by the Raymarine, ie. in our tests we could not get such data to show on the MFD using NMEA2000 (use the Marine MFD App instead to see the same data!): | Below list of Victron related PGNs are not supported by the Raymarine, ie. in our tests we could not get such data to show on the MFD using NMEA2000 (use the Marine MFD App instead to see the same data!): | ||
* J1939 - AC data | * J1939 - AC data |
